gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Sat May 19, 2012 5:00 pm Post subject: Differences between VW & 356 clutches |
Hello
Can anyone's explain how the clutch on a 356 differs from the clutch on a VW? I seem to remember reading that one was deeper than the other. Also, I've read that a 356 disc has more material on it (thicker) than a VW clutch. Are any of the parts interchangeable?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2451 Location: San Clemente, Ca.
Posted: Sat May 19, 2012 5:10 pm Post subject: |
180mm clutches have the same thickness VW/356. 356 always used sprung center discs. 200 mm VW disc thickness are at the lower worn limit when brand new for 356 _________________ Jack Staggs
Actual name |
bbspdstr Samba Member
Posted: Sun May 20, 2012 9:26 am Post subject: VW vs 356 clutches |
To add to what Jack supplied:
Actually, if the flywheel of your 356 engine needs work (surfacing, lightening, neck surface truing, dowel land milling, etc), have the depth ground for VW specs and use those VW parts. It's basically a 1mm difference when it's "like new" and most old original flywheels need some help anyway.
It is not necessarily a one-way trip, either.
For the same reason many other 356 items are compromised now that we eschewed in the past, the better quality OEM 356 clutch stuff is less needed due to less miles driven than when the cars were 'only' 20 or 30 years old. (pick a smiley, any smiley, happy or sad or both) |
bcrazy Samba Member
Posted: Mon May 21, 2012 6:10 am Post subject: |
Or you can mill the required distance off the mounting face on the pressure plate. That way no modification needed on the flywheel.
I did this on my 912 engine and it works fine. |
Posted: Mon May 21, 2012 11:18 am Post subject: |
bcrazy wrote: |
That's another way, thank you, but I'd rather take some thickness off the bulk of the flywheel than the mounting perimeter of the clutch cover plate.
It may actually be less expensive to spend the extra money for the correct 356 spec parts if just the driven plate needs replacement and the cover and flywheel are OK. |
Braukuche Samba Member
Posted: Mon May 21, 2012 11:57 am Post subject: |
Jacks wrote: |
180mm clutches have the same thickness VW/356. 356 always used sprung center discs. 200 mm VW disc thickness are at the lower worn limit when brand new for 356 |
I always thought it was the other way around? _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
