Dcoe 40 weber non turbo Specs ( Update) It's here
Page: Previous  1, 2
DarthWeber
DarthWeber is offline
PostPosted: Tue May 22, 2012 8:33 pm    Post subject: Reply with quote
Hot Air wrote:
What stacks will fit this . do I have to look for 40 weber or will other stacks fit.
I will post some pic tomorrow.
Also if anybody knows what would be a good size for a stock motor.
Many choices:
http://www.piercemanifolds.com/product_p/52840.010.htm
http://www.piercemanifolds.com/product_p/09-9040.htm
http://www.piercemanifolds.com/product_p/52840.012.htm
http://www.piercemanifolds.com/product_p/99217.225.htm
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
Hot Air
Hot Air is offline
PostPosted: Wed May 23, 2012 5:12 am    Post subject: Reply with quote
Well I just installed the center mount set up. Still need to get some stackes and rebuild it. I am just not sure who to send it too.here are some pics.
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
73' Bug
85' Porsche 911 Carrera 3.2
esde
esde is offline
PostPosted: Wed May 23, 2012 5:52 am    Post subject: Reply with quote
If that's a shortened buggy you could probably swap jets without leaving the driver seat! Looks perfect for the buggy, be interested to hear how it runs. If the carb isn't too dirty, could you do with a soak, blow it out, and overhaul kit yourself?
DarthWeber
PostPosted: Wed May 23, 2012 6:59 am    Post subject: Reply with quote
Send it to Mark Harney http://www.carburetorclinic.com/
For velocity stacks see my post above or let Mark take care of it.
Hot Air
Hot Air is offline
PostPosted: Wed May 23, 2012 9:41 am    Post subject: Reply with quote
Thanks for the info Darthweber, I sent a pm to him..I also found ACE ( air cooled engineering) they had great feedback also. So we will see what they say, Thanks again got my fingers crossed .
You were correct on the 28 venturies.
73' Bug
Hot Air
Hot Air is offline
PostPosted: Thu May 24, 2012 7:26 am    Post subject: Reply with quote
Is there a number for Mark Harney http://www.carburetorclinic.com/ I would like to talk to him, I hate typing what I have to say If it is possible.
73' Bug
Page: Previous  1, 2
Page 2 of 2
