Swapping back to original Dist - where to put vac lines?
Globespotter
Globespotter is offline
PostPosted: Mon May 28, 2012 4:44 pm    Post subject: Swapping back to original Dist - where to put vac lines? Reply with quote
My 1971 SB has a Porsche 912 Dizzy apparently - 0231 129 031
Which is weird because when the car was serviced I was told it had a 009.
I have the original (I believe SVDA) dizzy - 113 905 205 AJ and thinking it would be good to replace the Porsche one with it.
I am running a 34 PICT 3 Carb.
Where do I connect the vacuum lines from the Dizzy to the Carb - as marked in the pics - carb ports 1, 2 or 3 Dizzy ports A & B?
Any tips on replacing - I assume it is as easy as aligning it to cyl 1 and removing the old and inserting the new and then set timing?
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon May 28, 2012 4:53 pm    Post subject: Reply with quote
B goes to 1
A goes to 3
You're lucky you didn't cook your engine with the 031. It's has 32 degrees so your initial would of had to be 0 degrees if not a few ATDC.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Globespotter
PostPosted: Mon May 28, 2012 5:14 pm    Post subject: Reply with quote
Thanks Glenn! For interest - what is the other port on the carb for?
Mr. 010
Glenn is offline
PostPosted: Mon May 28, 2012 5:16 pm    Post subject: Reply with quote
For the EGR valve.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Globespotter
PostPosted: Mon May 28, 2012 5:32 pm    Post subject: Reply with quote
Thanks Glenn. So for replacement - easiest to turn the engine to have dist point to cyl 1 then just pull and replace with the new dist in the same position, then set new timing?
Oh, and what is the timing on the original dist?
vw_hank
vw_hank is offline
PostPosted: Mon May 28, 2012 5:40 pm    Post subject: Reply with quote
your in good hands with Glenn,, hes the dizzy guy Wink
LOL Glenns A dizy guy
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Mr. 010
Glenn is offline
PostPosted: Mon May 28, 2012 5:43 pm    Post subject: Reply with quote
Timing Set At:: 5deg ATDC @ 800-950rpm w/strobe, vacuum hose(s) connected.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Globespotter
PostPosted: Mon May 28, 2012 5:44 pm    Post subject: Reply with quote
Thanks Glenn - much appreciated!!!!
HRVW
HRVW is offline
PostPosted: Mon May 28, 2012 9:30 pm    Post subject: Reply with quote
Smile I have a 1968-9 912 dist (points are backwards comparewd to the 009.
Inherited it in a VW bug I once bought ages ago...still have it today along with extra ppints etc. The 912 dist has a nice advance with the vac over the VW 009 dist.
Do believe going to a dual vac dist over the 912 unit would be a waste.
How much do you want for that OLD 912 dist?
Cadaver
Cadaver is offline
PostPosted: Tue May 29, 2012 6:01 am    Post subject: Reply with quote
there are 2 issues.
is your carb stock? orig. , seems so. and good.
then the disty which is always first to check out.
if you bought a Bentleys, you get this below and the curves.
i'd never run any disty with out the curves and buying 10 disty, just to find one
not bad ,or hacked is not too effective. IMO, but luck happens, so i wish you luck , sure do......
see that 9-12 deg (this is mfg variances, crude back in the day) This vacuum advance
is what gives you that extra grunt off the line. make city driving a dream and increases MPG. ALL GOOD, NO BAD.
When you move the gas foot down, the vacuum drops and the advance is robust !
you motor smiles and burns the gas far more efficiently (not puked out those pea shooters Rolling Eyes )
so take your old SVDA.
static time it.
then idle the motor. at 900 RPM (spec)
now attach the vacuum hand tool to the vac can.
suck it down. (pump handle) did you get 9deg? if yes, its working.
if you want proof. the put in a T fitting and monitor the vacuum with the same
tool and make sure the vacuum is correct at idle. and that it drops vacuum at WOT.
Blip the throttle and see the vacuum drop like stone. (SVSA owners dont read this please, its NOT like yours at all, start your own posts)
you must be connected to the correct vacuum port, some carbs have up to 3 ports
none are the same. each has a purpose.
these tests are in the Bentleys, why people shy from books, i dont know.
on new cars i use Alldata(tm) but on VW, its Bentleys, every car mech uses books or
uses online full spec. so he dont have to guess, and make costly mistakes.
your question of which is best, is easy?
answer: the stock parts.
and the stock parts that still work and are not hacked.
only testing them solves this riddle, not others guessing or wondering.
SSDD, as we call it in a shop.
I dont know, but then i dont know your goals or utility. (racing DD, GG, toy, or ?)
good luck and ask lots of questions.
from old folks home.
Distributor: VW 113-905-205AJ, Bosch 0231 167 049 > 043-905-205C, 0231 176 028
Can Use: VW 113-905-205AN, Bosch 0231 167 070 or 043-905-205C, 0231 176 028
Points Replacement Plate Assy: VW 311-905-227A, Bosch 1237 110 064
Condensor: 02 054
Rotor: 04 033
Dust Cover: 039-905-241, Bosch 1230 500 139 > 1230 500 147
Cap: 03 010
Distributor Cap Clip: 034-905-265, Bosch 1231 251 033
Parts Kit (Shims, Washers & Hardware): 059-998-211, Bosch 1237 010 007
Coil: 00 015 (Blue Coil: 00 012)
Vacuum Can: 07 223 (1237 122 969) (Formerly 07 091 [1237 121 851]
Ignition Wires: 09 001
Spark Plug: W8AC
Advance/Retard Range: Vacuum: 9-12deg Adv, 11-13deg Ret; Centrifugal: 6-12deg @ 1500rpm, 22-25deg @ 3800rpm
for sale now.
in Samba classifieds....1968 T1.
Globespotter
PostPosted: Tue May 29, 2012 7:38 am    Post subject: Reply with quote
I will swap in the original dual vacuum dizzy and see how it works. I'd rather run stock since the rest of the car is stock, and right now there is a flat spot on acceleration, plus the aggressive nature of the 912 dizzy concerns me a bit.
If the original one works great, I'll certainly look at selling the 912 one to someone who can use it.
If the original does not work well, I may look at a 019.
Cadaver
Cadaver is offline
PostPosted: Tue May 29, 2012 8:29 am    Post subject: Reply with quote
return it to stock
then set the timing correctly (RTM)
test the timing functions to make sure they still work (vac and mech)
then drive the car. See of power and MPG are good, no pinging. no bogs..
if these parts don't work right, find out why and correct it.
at least your car has stock parts and are known.
the disty is the easiest
you check the advance by the book ( tuned up, is given,points at .016")
and for jitter.
and for misfire.
and advance rate, if happy, the disty is now working correctly
last you the address the carb tuning.
the carb can be bad, have bad parts, wrong parts. or maladjusted.
wrong jets. clogs, drilled jets both fuel and air and can have a dead/weak
high speed accelerator pump (bogs then catches up?)
i'd replace that HSAP diaphragm part pronto, so it dont crack and start a fire.
some cars have clone carbs that look stock and are not. but can be tuned to work great. see Rob and dave for the story on that.
that is my idea of points to ponder, in this regard. Carb-disty matching.
for sale now.
Globespotter
PostPosted: Thu May 31, 2012 9:44 am    Post subject: Reply with quote
Checked the timing with the 912 dizzy. My pulley has no dent/dimple - just a single notch which I believe should be 5 ATDC as the original dizzy was a DVDA.
Notch is showing about 6 or 7 degrees to right of the centerline when checked with timing light - so I'm figuring that would be around 11 ATDC if the notch is actually 5 ATDC.
Does that make sense?
I still need to verify TDC and that the notch is 5 ATDC then I want to swap the old DVDA dizzy back in and time.
Globespotter
PostPosted: Wed Jul 11, 2012 7:08 pm    Post subject: Reply with quote
Swapped the original 113 905 205 AJ Distributor into the Bug today with new points, condensor and cap. Hooked up both advance and retard lines and set timing.
The car runs like a DREAM!!!!
The flat spot and hesitation is GONE. Taking off from a stop is amazing and the car feels like it has so much more power, runs and shifts smoothly.
So happy!!!!
Looks like I will be posting the Porsche Distributor for Sale Smile
ETA: 031 is for Sale in Classified for anyone interested...
vwjim70
vwjim70 is offline
PostPosted: Sun Dec 06, 2015 9:36 am    Post subject: Re: Swapping back to original Dist - where to put vac lines? Reply with quote
Hi
i have a 74 SB and i am putting a new 34 pict 3 carb on..
however, on the new carb the advance hookups are different..
referring to the reply to the original post, it says to hook B to 1 and A to 3..
What can i do if I do not have a 1 but i have a #2?
can i hook up B to 2?
Thanks
ashman40
ashman40 is offline
PostPosted: Sun Dec 06, 2015 9:55 am    Post subject: Re: Swapping back to original Dist - where to put vac lines? Reply with quote
It would help if you had a vacuum gauge or a vacuum hand pump with a gauge. Connect it to port #2 and take some vacuum readings at different rpms. You want to see max vacuum at idle. This will activate the vacuum retard only at idle and not at any other time.
Then test the vacuum retard by connecting B to #2 and watching the timing marks under the strobe light. When the hose is connected the timing should be 8-12deg retarded from when the hose is removed.
The second option is to just leave the B nipple disconnected/open and run your DVDA distributor as an SVDA. Just use the vacuum advance (A) port on the distributor/carb. Also test this by connecting the A port to a vacuum source and confirming the timing advances.
AshMan40
vwjim70
vwjim70 is offline
PostPosted: Sun Dec 06, 2015 10:01 am    Post subject: Re: Swapping back to original Dist - where to put vac lines? Reply with quote
I'll give it a try.
Thank you for the response!
