cargo boxes on top of cab & on rear hitch
pghmike
pghmike is offline
PostPosted: Fri Jun 08, 2012 9:31 am    Post subject: cargo boxes on top of cab & on rear hitch Reply with quote
with an extended summer trip coming up and a family of five, i am looking to maximize cargo space... to challenge things a bit more than normal, we rock climb and will have shoes, harnesses, helmets, ropes and a ton of gear in addition to all the normal stuff... i have put tracks up top and a roof rack and thule box, but i want more... there is an Action Packer that is 43 long x 17 wide x 20 high which would seem to fit perfectly in the cargo space on top of the cab... i'm wondering how much that big box up front and high like that is going to kill my mpg... i'm also looking into the stowaway carrier on the swing away arm for the back... i am thinking it would be pretty convenient to utilize all three options (thule on top, action packer in front of that, and stow away in the back)... so two questions: 1. should that action packer up top and front be avoided? and 2. the people at stowaway have said that i need a tongue weight capacity of 300 lbs to haul their box on my rear hitch... will i be fine doing that in my 86 weekender? (i have a custom steel bumper w. 2" hitch)
joseph928
joseph928 is offline
PostPosted: Fri Jun 08, 2012 11:02 am    Post subject: to much gear Reply with quote
Blue Bay Bus Yes you can do all this, cost, lost MPG, hassle to get to all of this. Just get a small trailer, 150 lbs. aka harbor freight $400.00 this is what I did, and when I take the box off the trailer I can hall my Harley! Yes I had to build the box but that was easy. Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
climberjohn
climberjohn is offline
PostPosted: Fri Jun 08, 2012 12:59 pm    Post subject: Reply with quote
Try a search on < Rola >
This is a burly cargo bag that fits well on top of the cargo area over the front 2 seats. This search will also lead you to many related threads.
link to the bag:
http://www.amazon.com/Rola-59102-Expandable-Hitch-Cargo/dp/B000E7WLJW
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
j_dirge
j_dirge is offline
PostPosted: Mon Jun 11, 2012 7:28 am    Post subject: Re: cargo boxes on top of cab & on rear hitch Reply with quote
300lbs seems like overkill.. perhaps they are quoting this wieght if the box were full of heavy items?.. like sand bags or some such?
Stuff stored off the back or front.. and on top.. should be the lightest of your cargo. Sleeping bags, lawn chairs, etc. Keep tool boxes and water jugs inside, low, and centered, (if at all possible).
300lbs on the rear hitch is beyond most VW hitch capacities. Only a couple of aftermarket semi-custom products fit the bill.
And once you have a proper 300lb receiver in place, the VW suspension is not really up to the task in stock configuration. Many of the tires used on Westy are not really suited to those loads, either.
As CJ points out.. LOTS has been written on receiver/hitches, rear suspension, towing, cargo boxes, GVWR, etc.
Use the search.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
presslab
presslab is offline
PostPosted: Mon Jun 11, 2012 7:49 am    Post subject: Reply with quote
How about on the front?
I keep my bikes on the back, and put my SCUBA stuff in the front.
If your custom hitch is stout, it should be ok. Sometimes I carry a dirt bike on the back (400 lbs all up) and this is too heavy for stock springs; I have air bags instead.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
danfromsyr
danfromsyr is offline
PostPosted: Mon Jun 11, 2012 9:31 am    Post subject: Reply with quote
WOOOT Air bags.. ;-p
Abscate wrote:
PDXWesty
PDXWesty is offline
PostPosted: Mon Jun 11, 2012 9:39 am    Post subject: Reply with quote
300 lb tounge rating is just a rating. It doesn't mean you want to carry that much in a box off the rear. You'd be suprised how much force can be applied though even from a 50 lb load through the lever arm of a box and the bouncing motion of the road. It's much more than 300 lbs.
89 Westy 2.1 Auto
GWTWTLW
GWTWTLW is offline
PostPosted: Mon Jun 11, 2012 9:45 am    Post subject: Reply with quote
I always run a tie-down from the top of the hatch to the back end of the rack to reduce the stress from bouncing. I haven't had any issues. This will be my first trip with the GW bumpers though. My old hitch was welded to the tow hooks.
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
JeffRobenolt Premium Member
JeffRobenolt is offline
PostPosted: Mon Jun 11, 2012 9:57 am    Post subject: Reply with quote
It is real heavy, even empty
For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com
joseph928
PostPosted: Mon Jun 11, 2012 10:10 am    Post subject: rear box Reply with quote
Blue Bay Bus also notice the license plat and lights, in most states you have to do this! Can't count all the ones that don't do this, dumb and illegal! Very Happy
presslab
presslab is offline
PostPosted: Mon Jun 11, 2012 10:14 am    Post subject: Re: rear box Reply with quote
That's a great point. Cops are looking for anything to pull you over. Recently I was pulled over for my bikes on the back obscuring my license plate. Of course once they pulled me over they shone their lights all around the insides.
In the front my plate is all the way to the right, so you can still see it beside the cargo bins.
j_dirge
j_dirge is offline
PostPosted: Mon Jun 11, 2012 10:18 am    Post subject: Reply with quote
Thats true.
I did an honest 325 lbs of tongue wieght when pulling my Moore 24 around town.. fairly regularly for over a year. Well beyond what I would recommend anyone do for any extended miles.
I'd not recommend more than 150-200lbs it without looking into mods like what Presslab has done with true airbag suspension. Even at 100-150lbs you'd probably want some load assist.
I am currently on load assist air shocks and s.org springs.. On this last trip I had about 200lbs off the back with 4 bikes on a tray and a big spare in close to body. Worked prettty well.. but I have $$$ into my suspension now... and I still ate a CV
I am working up towards another 80lbs on the rear for fuel and odds and ends. The CV failure has me moving towards 930s earlier than later. Maybe next month.
(Depends on what I find when I pull the boot and do some forensics.)
No way I'd do this again with OEM suspensions and tires. At least CVs are relatively cheap. Wink
WestyBob
WestyBob is offline
PostPosted: Mon Jun 11, 2012 10:34 am    Post subject: Re: cargo boxes on top of cab & on rear hitch Reply with quote
The action packer in the front westy luggage rack ... if full should give you slightly better aerodynamics than when the rack is empty regarding mpg's.
I have an older swing-away with cargo box .... it weighs 'tons' and wouldn't recommend for a westy except for maybe day trips.
Perhaps the front carrier like danfromsyr shows in the pic mounted in back with a cargo box attached would work well. You can get a less expensive, lighter version from Harbor Freight if there's one in Pgh.
Pulling a HF trailer with Thule/Yakima cargo boxes attached is not a bad idea as another mentioned if you don't mind dealing with trailers. DogPilot, no longer on this forum, had worked up a good version in a past thread that carried cargo plus bikes.
Bicycles and even jerry cans can be carried on a Gary Lee hatch ladder rack or a Paulchen-style hatch bike carrier.
GWTWTLW
GWTWTLW is offline
PostPosted: Mon Jun 11, 2012 11:24 am    Post subject: Re: rear box Reply with quote
We were stopped in Utah because our plate was blocked. He was nice about it but we still had to zip tie our license plate to the back of the rack for the rest of the trip. I will probably leave it where it is for now and not move it again until asked.
@gwtwtlw
