Heater Box air flaps
Jockomo
Jockomo is offline
PostPosted: Sat Jun 23, 2012 8:43 am    Post subject: Heater Box air flaps Reply with quote
I am missing the air flaps for the heater box.
I don't need the heat in the bus.
Should I close them off and run the heater fan all the time to blow the heat out of the exchangers? (is the fan supposed to run all the time? or just when you need heat)
Can I leave them open and close off the tubes that come from the fan, then not have to run the fan to cool the exchangers? That's actually how I have run it in the past.
'75 Westy with '78 2.0L engine.
busdaddy
busdaddy is offline
PostPosted: Sat Jun 23, 2012 9:30 am    Post subject: Reply with quote
Exactly which flaps are we discussing? the non return flaps at the bottom of the shroud?, the non return flaps in the booster fan? or the flaps in the control valves at the front?
Слава Україні!
jmstu76
jmstu76 is offline
PostPosted: Sat Jun 23, 2012 9:31 am    Post subject: Reply with quote
Why not just leave it alone as it was designed and don't turn the heat on since you don't need it?
James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger Instagram Gallery Classifieds Feedback
Jockomo
Jockomo is offline
PostPosted: Sat Jun 23, 2012 9:48 am    Post subject: Reply with quote
The ones in the bottom on the fan housing.
#2 on ratwell's
jmstu: because I don't have the flaps.
As far as I can tell, they only come into use if the fan is on. I guess my question is, can i ditch the fan, as long as i cover the holes that bring air into the heat exchangers from the fan tubes?
busdaddy
busdaddy is offline
PostPosted: Sat Jun 23, 2012 10:23 am    Post subject: Reply with quote
You don't really need the lower flaps, they are an evolutionary throwback from the 411/412 and really don't do much in a bus. You do need the flaps in the booster fan or if you remove the booster fan you have to cap the tubes so hot air doesn't blow into the engine compartment.
Слава Україні!
Jockomo
Jockomo is offline
PostPosted: Sat Jun 23, 2012 10:26 am    Post subject: Reply with quote
Perfect. Thanks once again Busdaddy!
KlassicBus79
KlassicBus79 is offline
PostPosted: Sat Jun 23, 2012 10:39 am    Post subject: Reply with quote
Thanks for the info Busdaddy.
One of my lower flaps is missing and the only place I can find it is German Supply, but I haven't ordered it yet because I'm not sure if the pin and spring come with it.
79 Cal Transporter 2L
udidwht
udidwht is offline
PostPosted: Mon Jun 25, 2012 12:35 am    Post subject: Reply with quote
Pin no spring. As for replacing the pin...coat hanger wire
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
tootype2crazy
tootype2crazy is offline
PostPosted: Mon Jun 25, 2012 5:06 am    Post subject: Reply with quote
You can make the flaps easily with a piece of lightweight tin from something like a pie pan. Just cut them to the desired shape, roll the area for the pin and set it up against the shroud and hammer it into shape with a ball peen. U can use a piece of wire or a large paper clip for the pin.
air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
KlassicBus79
PostPosted: Mon Jun 25, 2012 8:33 pm    Post subject: Reply with quote
Absolutely correct about the spring. I just finished working on the guard on my lawn mower just before I wrote that. Embarassed
Wildthings
Wildthings is offline
PostPosted: Tue Jun 26, 2012 3:48 am    Post subject: Reply with quote
All the little flaps on the outlets of the fan shroud do is break off and clog your heat exchangers. They had a purpose on 411/412s which had gas heaters that could be run with the engines off, but no purpose that I know of on a bus engine.
As mentioned above you do need the flaps, hoses, and stuff for the aux fan, or you need to close off the tubes going down into the heat exchangers. If you have your heat exchangers off then having the ports where the tubes attach welded up is a good option, but you can also easily close off the tops of the tubes with freeze plugs, metal tape, etc.
LeeE
LeeE is offline
PostPosted: Tue Jun 26, 2012 11:26 am    Post subject: Reply with quote
Easy to make, and a finishing nail is perfect for the pin.
I removed the fan and hoses completely. I capped the heat exchanger inlets and covered the holes in the tin with pieces of can metal. Cut one piece to fit over the hole and another for a brace underneath, screw them together loosely, bend and fit them tightly into place and then tighten the screws to snug them.
1978 Westfalia stock 2.0 FI
Welcome to the Okeedokee Swamp
whatdoesthisbuttondo?
whatdoesthisbuttondo? is offline
PostPosted: Tue Jun 26, 2012 1:04 pm    Post subject: Reply with quote
Hammering over the opening sounds easier that what I did. I bent a piece of coat hanger into a rectangle so it just fit inside the fan shroud opening, then placed that on top of the metal sheet on a block of wood like a punch and whacked at it with a hammer; had to leave the outside of the sheet metal blank a little bigger to account for the indent, then fit and traced with a sharpie around fan shroud edges, trimmed and filed the edges of the flap. I screwed up the first one because I didn't leave the hinge bits long enough and it wouldnt close smoothly. Coat hanger for pin was perfect.
Glad to hear they are kind of useless pieces Laughing
Orange 1973 Campervan. Rebuilt 1700cc with dual Solex carbs. Pertronix electronic points on stock distributor. Engine rebuild in progress (fall 2023).
Gatorbus
Gatorbus is offline
PostPosted: Tue Apr 16, 2013 11:17 am    Post subject: Heater non-return flaps Reply with quote
Old post resurrected. Sounds like these fan shroud lower non-return flaps aren't too critical, but are they essential if I want to have my heater working properly and stink free? And what controls the flaps since they have a pin/hinge incorporated? What position do they take with the heater on or off? Goal is to get my heater working as close to stock.
1973 Automatic Transporter
2.0 with Weber 32/36 DFEV progressive
Wildthings
PostPosted: Tue Apr 16, 2013 1:14 pm    Post subject: Reply with quote
They are open any time the engine is running, whether the heat is on or off. To the best of my knowledge they have zero effect on the heat output, either temperature or volume. The only purpose I can see them serving on a bus is that of a one way mouse door. Don't know if that is good or bad though.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Apr 16, 2013 1:33 pm    Post subject: Reply with quote
If the electric fan RPM was a higher output at idle than the cooling fan it would prevent back flow.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Gatorbus
Gatorbus is offline
PostPosted: Tue Apr 16, 2013 1:42 pm    Post subject: Reply with quote
Thanks WT. With trapped mice in there, maybe I'll get some more torque out of my engine.
edhnb
edhnb is offline
PostPosted: Sat Mar 30, 2024 2:52 pm    Post subject: Reply with quote
Thank you!
1977 Asi Riviera
Whaanga
Whaanga is offline
PostPosted: Sun Mar 31, 2024 2:23 pm    Post subject: Re: Heater Box air flaps Reply with quote
Does anyone have a photo of the flaps connected to the booster fan?
Late 1973 Bay w/a transplanted 914 Engine
