Don66bus Samba Member
Posted: Sat Jun 30, 2012 11:26 am Post subject: Data debate |
Now we are getting some numbers. Plane Ben's measurements say that open lids lead to hotter temps. I browsed about 8 sheets of Jake Raby's data but it is a little overwhelming without access to the spreadsheet, and it is for a bug in any case. Jake, could you shorten that exercise and tell us what you found on your Bug lid open or closed research? Pyroman, I agree that you have great data and what appears to be an admirable engine which does not need any bizarre cooling fixes. Do you have any comparison with the lid open and closed? We can tell it runs great with the lid closed.
Thanks to all. So far I do not see a clear decision on whether an open bus engine lid is an advantage or not in hot conditions.
Don |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12565 Location: Over 2002 posts deleted!
Posted: Sat Jun 30, 2012 11:51 am Post subject: Re: Data debate |
| Don66bus wrote: |
Don |
How about contributing by installing accurate gauges on your bus and running your very own test with the lid opened and closed?
| Quote: |
| A man with an experience is never at the mercy of a man with an argument. |
There's 3 kinds of people: those who make things happen, those who whatch things happen and those who wonder "what happened?"  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Sat Jun 30, 2012 12:22 pm Post subject: |
No use in summarizing.. Just look at the data and come to your own conclusion.. Anything I state will be argued with, anyway. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
dawerks Samba Member
Posted: Sat Jun 30, 2012 12:36 pm Post subject: |
1000 miles in one day in a bug! Awesome!! What is 'test lube #1'?
Don't worry about getting an argument, it's the nature of forums. Thank you for posting the information, great!
From the data; CHT's were higher with the decklid propped open (by about 14-18F). I would call it a toss. _________________ "There is only one sin; disconnection from self." |
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Sat Jun 30, 2012 3:35 pm Post subject: |
| cru62 wrote: |
| plane_ben wrote: |
| The splitties vents were low, below the belt line where laminar flow is consistant and strong you don't need scoops. |
It is difficult to change the direction of air in laminar flow. It either needs to be physically redirected (i.e. scoops in this case) or by pressure differential. Since it is so difficult it is possible that the laminar air rushing by on the outside of the vents could draw out air from the engine compartment by a venturi effect. The leaks in the sealing tins, etc. will be accentuated in this case, drawing in hot air instead of cool air.
As far as the dead zone is concerned, I did not mean that the air in it was still. The air flowing over, under and around a bus at speed will trap a low pressure "bubble" of "dirty" air which just stays in the aerodynamic shadow of the vehicle.
As the displacement of the VW engines increased in buses, the fan size (thickness) and vent area both increased. At the end of production the displacement of bug engines and the area of the vents were approximately equal to what they were in the late 60's. Buses, however, increased the vent area as the displacement increased. The reason that the scoops are high on the later buses is primarily due to the the cleaner air being up high. Just look at all the contraptions VW tried in various areas of the globe to pick up clean air. Trucks had the absolute worst location for the stock vents. AND they had one less vent on top of it. |
Sound good points raised by cru62 regarding aerodynamics. However, the air flowing off the trailing surface doesn't just sit dead or just stay there, it actually flows forward.
I'm not getting into the debate raised by the initial thread poster but I will point out some aerodynamic constants about any object with fast flowing air moving around it or a fast moving object moving through (still) air - same effect....
Especially if the object is squared off or slightly rounded off at the back end (most cars), the laminar air flowing off the back doesn't just hang around or just stay at the back of the object (car), it actually flows forward in a series of eddies called vortices. You have all observed this watching water in a creek flowing past a rock and is why white water rafters sometimes get trapped downstream of big rocks and you all learned pretty quickly when you first started driving that if you left the tailgate open in your station wagon, you got exhaust gasses 'sucked' into the car....
The oil mist on the back of the bus alluded to by cru62 is also there because of this effect.
Aerodynamics regarding airflow and pressure differentials can get complicated but the above is a constant for any 'blunt' object with air flowing around it. So an open engine lid will have some air flowing into it from behind the bus. If this air is coming off a hot engine & exhaust from underneath the bus..... well, I'll let you draw your own conclusions.  _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
Posted: Sat Jun 30, 2012 4:30 pm Post subject: |
| dawerks wrote: |
| 1000 miles in one day in a bug! Awesome!!. |
Yep Chicago to Denver in one day.. All we did was stop to take a leak and fuel up. _________________ Jake Raby
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5978 Location: Los Alamos, New Mexico, USA
Posted: Sat Jun 30, 2012 5:33 pm Post subject: |
False.
| Campy wrote: |
| Regarding leaving the engine door open, hot air is blown out from the rear of the engine (cylinder heads and cylinders) and some of it would go into the engine compartment. |
Exactly. Drive with your door closed the way VW intended. You don't want to be sucking in hot air coming off the bottom of your engine. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Jeff Power Samba Member
Joined: October 13, 2004 Posts: 1170 Location: with any luck, in my garage building bass guitars.
Posted: Sat Jun 30, 2012 6:44 pm Post subject: |
Closed, driving around with the decklid open just looks dumb like when you forget to close the fuel filler door.  _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
Check out my basses here www.ellabasses.com
| jerry wrote: |
Nothing says "I love busses" more than picking up a mouse turd filled with horse hair seat padding |
pyrOman Fire Master
Posted: Sun Jul 01, 2012 5:33 am Post subject: |
Not starting another thread but...
Chances are "good" that an open engine lid (or none at all) will allow all sorts of road debris including the ever present pastic bag and/or floating newspaper to get sucked into the engine compartment and thus the cooling fan itself.
True or false?  _________________ Some people are so busy being clever they don't have time enough to be wise. |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Sun Jul 08, 2012 8:54 am Post subject: |
This will make me sound like a dick, but.....I bet Jake has data on a bag being sucked into the cooling fan and covering the fins of 2 cylinders and measurements of the differences between them.....But, it on a Ghia.
Gordo. |
Brian Mathe Samba Member
Posted: Sun Jul 08, 2012 12:41 pm Post subject: |
I will have to dig up my old Gene Berg articles but I do remember him publishing an article about temps in the engine bay of a bus with windows open/closed, deck lid on/off. If I remember correctly, he advised to cut a small section out behind the license plate. It would not be visible but allowed some air flow out. I think it would help. Like when you drive with just one window down, if you crack the back one, the air flows much smoother. _________________ 59 Kombi
66 Porsche 912
50 split-window |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20955 Location: Sandpoint, ID
Posted: Sun Jul 08, 2012 1:53 pm Post subject: |
| papercutt wrote: |
| I will have to dig up my old Gene Berg articles but I do remember him publishing an article about temps in the engine bay of a bus with windows open/closed, deck lid on/off. If I remember correctly, he advised to cut a small section out behind the license plate. It would not be visible but allowed some air flow out. I think it would help. Like when you drive with just one window down, if you crack the back one, the air flows much smoother. |
the difference would be that in the engine compartment, there is already air outflow via the cooling fan and, in larger engines, dual carbs sucking way more air than a stock engine. I would bet that any opening to the rear of the compartment will only suck air in, not allow air to escape.
I like the idea of a duct that runs from down near the frame to the front tin near the starter. It brings fresh air from below the bus right into the intake area of the cooling fan. I did this on a 1776 in a 57 bus and though I had no real gauges, the dip stick test told me it was better than without the extra air. Plus, it was free. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two.
Posted: Sun Jul 08, 2012 3:23 pm Post subject: |
Very good point. _________________ 59 Kombi
66 Porsche 912
50 split-window |
