Horn wire in steering column
68busnow
68busnow is offline
PostPosted: Sun Jul 15, 2012 10:03 am    Post subject: Horn wire in steering column Reply with quote
I have been searching, with no luck, for a thread that explains/shows how to replace the horn wire that runs through the steering column of a 68 bay window bus.
Does anyone know if such a thread exist
Thx
70Crew
70Crew is offline
PostPosted: Sun Jul 15, 2012 1:59 pm    Post subject: Reply with quote
Are you trying to do it with the column in place? Having just rebuilt my whole steering column myself I'd say it is simple when the column is off and virtually impossible with it installed.
Daverham
Daverham is offline
PostPosted: Sun Jul 15, 2012 3:30 pm    Post subject: Reply with quote
One fine day... when I figure this out for myself. I mean REALLY figure it out, from top to bottom.. I'm going to do up the most awesome diagram that shows every detail, exploded view with notes!
Until then - if anyone has anything of that nature to start from. Post it here!
68busnow
68busnow is offline
PostPosted: Mon Jul 16, 2012 3:27 am    Post subject: horn wire Reply with quote
Of course, the column is in place. I figured it was tough. Do you any pics of the overhaul?\\I might be going there.
70Crew
70Crew is offline
PostPosted: Mon Jul 16, 2012 6:13 am    Post subject: Reply with quote
Of course now I wished I had been taking pictures. It may take me couple days but I will try and document the steps. What year is your bus?
68busnow
68busnow is offline
PostPosted: Tue Jul 17, 2012 7:53 am    Post subject: horn wire Reply with quote
1968 bay window
70Crew
70Crew is offline
PostPosted: Tue Jul 17, 2012 8:03 am    Post subject: Reply with quote
I'm going to post some photos of what I learned during the process of rebuilding my column. I have a 1970 bus so the parts should be basically the same. Even though I neglected to take photos as I was doing it, I have all the parts from another bus and can do a little staging (hopefully in the next day or so).
70Crew
70Crew is offline
PostPosted: Tue Jul 17, 2012 12:43 pm    Post subject: Early Horn wiring Reply with quote
There are 2 wires you need to connect on the steering column.
The first wire is the column tube ground. There is a short wire that comes off the main wiring harness and ends up right next to the steering gear box. This wire needs to be routed through the metal loop (A) on the underside of the cover plate and then attached to the tab that sticks out from the end of the column tube (B). These tabs break off easily; I have 3 column tubes and 2 of the ground tabs are missing (broken off). I attached this ground wire with the steering column, gear box and cover plate in place. It took a lot of cussing, a shop light and a pair of Harbor Freight extra-long needle nose pliers but it is definitely possible (see space G.... yep, that's pretty tight). The alternative is to remove the gear box which I didn’t want to hassle with.
The second wire (also a ground wire?) is brown and runs from the top of the steering column (C) to just above the gear box. The steering column is hollow and this wire runs through the center of it. The bottom end of this wire has a large loop wire terminal that fits around one of the 4 hex head M8 bolts that connect the steering column to the coupling disk and top of the gear box. There is a small gap (D) between the coupling disk and top of the gearbox which allows you to feed that wire (E) from the column and around the corner to one of the hex head bolts (F). I attached it on the bottom, under a nut, so that the contact was metal to metal rather than nut to rubber. I’m not 100% sure that is how it was done from the factory but it makes sense to me (anyone out there know better?).
Bentley says you are supposed to install the column tube first and then the steering column from underneath. That was not possible without a lift so I installed the entire assembly from the top. I did it alone and the only part that was remotely difficult was attaching the aforementioned column tube ground wire.
Good luck and holler if you have any questions.
Chris
(MiOdy81)
68busnow
68busnow is offline
PostPosted: Mon Jul 23, 2012 3:50 pm    Post subject: horn wire Reply with quote
Great pictures.
Is it possible to replace the brown wire that runs up thru the column to the horn ring without removing the whole column and steering box?
70Crew
70Crew is offline
PostPosted: Mon Jul 23, 2012 4:10 pm    Post subject: Reply with quote
I don't think you can get there without some work but you don't need to pull the steering box. Here's the easiest way I can think of (assumes the steering wheel is off):
1) Remove the 4 screws holding the steering column/ignition bracket so that the entire column assembly is loose.
2) Remove the 2 screws holding the cap that is mounted on the floor.
3 Raise the entire column tube assembly up off the floor (steering shaft will stay in place) high enough that you have access to the 4 bolts that hold the steering shaft to the coupler and steering box. This means you will be disconnecting the ground wire from the ground tab that sticks out from the end of the column tube. That is a pain to reconnect but can be done (see my original post). I'm also not sure whether the column assembly can be raised up high enough to get at the bolts without disconnecting all the wires to the ignition switch and turn signal. If they are all attached there may not be enough slack (mine were not attached when I did this).
4) Disconnect the 2 bolts holding the steering column on the coupler. These are hard to get at (easier with 2 people) and have cotter pins underneath which secure the nuts.
Once these 2 bolts are off, you can slide the steering column up the tube far enough to reach the wire and fish a new one through.
PS - it will probably be harder than this. I am going off memory and every bus seems to be a little bit different due to PO changes and such. Good luck.
Chris
70Crew
70Crew is offline
PostPosted: Mon Jul 23, 2012 4:19 pm    Post subject: Reply with quote
Another thought..... just taking off 2 of the 4 bolts holding the steering column to the coupler disc and steering box may not give you enough room to fish the wire, you may need to remove all 4. You'll need to remove at least 3 since you will be attaching the circular ground lug over one of the other bolt heads. Maybe removing 3 will allow you to swivel the shaft enough to feed the wire, so try that first before removing all 4.
TeamSpatula
Samba In The Rain
TeamSpatula is offline
PostPosted: Thu Aug 30, 2012 1:12 pm    Post subject: Reply with quote
Thanks for the great thread & pictures. So what do you do if that tab is broken off? What does it connect to? I've got the horn wire hanging down loose (71 if it matters) with that tab broken off in the connector. Is it possible to screw a new ground to the column, or else where could it be attached?
Thanks,
<---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com
SGKent Premium Member
SGKent is offline
PostPosted: Thu Aug 30, 2012 1:27 pm    Post subject: Reply with quote
I think it is a tab at the bottom of the tube as I recall. you can't bolt to it as the shaft is in the way. The tube is insulated by the plastic piece at the bottom too as I recall. Probably you could pull the tube, clean an area and solder or spot a new tab on it. I think I temp fixed mine on the 1971 by soldering the end of a wire to the remnant of the tab until I could fix it permanently.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
busdaddy
busdaddy is offline
PostPosted: Thu Aug 30, 2012 1:48 pm    Post subject: Reply with quote
The tab was riveted to the bottom of the tube. I've fixed them with a pop rivet but that's easier if it's apart. I've also drilled a hole in the floor plate just infront of the column tube and screwed the wire to the outside of the tube with a short screw, crude but effective.
Слава Україні!
TeamSpatula
Samba In The Rain
PostPosted: Sat Sep 15, 2012 5:35 pm    Post subject: Reply with quote
OK, so I must have something else crossed up...I drilled a hole at the front of the cab floor and ran that wire up through it, then drilled a hole about where the letter "B" is on that diagram, and screwed the wire connector to the plate.
However, now the horn button still doesn't do anything, but if I wiggle the outer column, with the 2 floor mounting screws loosened, then it appears to short out if I have it all the way forward, i.e. horn blows continuously, even if I unplug the brown wire from the connector in the middle of the steering wheel. Then when I move the column back, nothing possible will make it honk.
I am thinking I'm missing something, or else have something else wrong as well. At this point I'm just trying to not have to take apart the coupler or anything more serious like that. Can anyone point me in the right direction?
Thanks,
1981 Diesel Rabbit
busdaddy
busdaddy is offline
PostPosted: Sat Sep 15, 2012 5:44 pm    Post subject: Reply with quote
TeamSpatula wrote:
I am thinking I'm missing something, ,
You are if you screwed the wire to the floor plate, that would result in full time horn if it was making contact with the floor properly Wink
You need to screw the wire to the outer column tube as that's what the horn button grounds, and make sure the plastic ring is in place between the tube and the floor plate because it's an insulator.
Слава Україні!
kreemoweet
kreemoweet is offline
PostPosted: Sat Sep 15, 2012 9:45 pm    Post subject: Reply with quote
Another way to put it is: that wire cannot touch any grounded surface or part, because it is
the HOT wire feeding the horn button switch. The steering column itself is part of that same
HOT side of the circuit, and that is why it is insulated at both top and bottom from any contact
with ground.
'67 bug: seized by the authorities
SGKent is offline
PostPosted: Sat Sep 15, 2012 11:46 pm    Post subject: Reply with quote
strip an inch off the end of a wire. Clean an area of paint on the tube and use a stainless clamp to clamp the stripped wire to it. Run the other end thru the floor to the wire under the bus. Next time the column tube is apart you can fix the tab and repaint the tube,
George Carlin:
1971 deluxe (sold)
1977 deluxe
Tcash
Tcash is offline
PostPosted: Sun May 18, 2014 6:56 pm    Post subject: Reply with quote
Deleted, already posted.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun May 18, 2014 7:29 pm    Post subject: Reply with quote
would like to note:
the wire in the column tube is grounded as shown in the picture, through the coupler bolt to the steering box but the factory did it on the top side (not that it matters)
also, make sure the bolt you pick is one that attaches the coupler to the steering box. i have found too many of 'my horn won't work' complaints because someone used the bolt that the steering shaft uses to bolt to the coupler thus making no ground connection
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
