BlastMasterMannyFresh Samba Member
Joined: November 21, 2001 Posts: 6106 Location: #31peach
Posted: Fri Aug 31, 2012 3:48 pm Post subject: |
cdennisg wrote: |
Lengua? ICKY! |
Are you kidding me Corey? Lengua is actually a delicacy served on special occasions. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20828 Location: Sandpoint, ID
Posted: Fri Aug 31, 2012 3:57 pm Post subject: |
mannys66 wrote: |
cdennisg wrote: |
Lengua? ICKY! |
Whale snot and monkey brains are delicacies, too, but I ain't eatin' 'em. _________________ You can't spell sausage without "USA"! |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1663 Location: In Your Face...
Posted: Fri Aug 31, 2012 4:05 pm Post subject: |
cdennisg wrote: |
mannys66 wrote: |
cdennisg wrote: |
Lengua? ICKY! |
Whale snot and monkey brains are delicacies, too, but I ain't eatin' 'em. |
You need to expand your horizons...  _________________
Lind wrote: |
Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
Posted: Fri Aug 31, 2012 4:08 pm Post subject: |
Busryder wrote: |
cdennisg wrote: |
mannys66 wrote: |
cdennisg wrote: |
Lengua? ICKY! |
You need to expand your horizons...  |
65Busstop Samba Member
Joined: January 06, 2004 Posts: 312 Location: Akron Ohio
PSScoots  Samba Member
Joined: January 06, 2007 Posts: 505 Location: Chattanooga TN
Posted: Fri Aug 31, 2012 6:26 pm Post subject: |
That's way more interesting than the video about how put your pulley belt on with the engine running. _________________ Rebuilt to drive not decorate. -VOLKSWAGNUT
"Service the car and it will give you good service." |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Fri Aug 31, 2012 6:58 pm Post subject: |
Done that many times myself. The trick when prying it on is to force the bead down into the channel of the rim by standing on the tire for the last bit. However, most of the time with VW tires, you don't need to resort to the "fire" method. Just removing the valve core and sending a blast of air down the valve will be enough to seat it. |
LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5596 Location: 1st Coast
Posted: Sat Sep 01, 2012 1:07 pm Post subject: |
Done, too bad I just didn't go to my mechanic first
My mechanic did it free but I always leave him a good tip
The cool thing is I learned about the tire machines with the 4 grippers and I will also use it for my other vintage car.
Thanks for all the help.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2669 Location: Phoenix AZ
Posted: Sat Sep 01, 2012 10:19 pm Post subject: |
is it bad to not balance your tires? _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Posted: Sat Sep 01, 2012 10:22 pm Post subject: |
sub-hatchtim wrote: |
is it bad to not balance your tires? |
You can 'feel' an unbalanced tire at the helm....  _________________
Lind wrote: |
Posted: Sat Sep 01, 2012 10:37 pm Post subject: |
On buses, I don't bother unless I can feel something while driving. I just mounted four Cooper Discoverers and I can feel no out of balance issues all the way up to 70 MPH. This is the second set of these tires I have had on a bus with no balancing. _________________ You can't spell sausage without "USA"! |
Posted: Sat Sep 01, 2012 10:45 pm Post subject: |
cool I have 205 75 15 bfg's they arent balanced and I cant even tell but I have only gotten it up to 65 _________________ 58' pg/sg silo fridge westy
76 911S |
Posted: Sat Sep 01, 2012 11:30 pm Post subject: |
Simple speculation:
I would assume that the side-wall grade would make a bit of a difference... the BFG D's on my Vanagon were balanced, but I have felt nothing while in these shoes.
(I may be interested in selling it, it's in my Gallery, but I have yet to commit... )
The BFG's:
195/75R 14" BFG's, Load Range: 'D'
What Load Rating are your tires? _________________
Lind wrote: |
Posted: Sun Sep 02, 2012 7:54 am Post subject: |
I did not have him balance the spare and it s a used tire (for now) but when I swap it back I'll have him balance just in case I need it. Thanks guys.
Next wheel problem, this is the wheel I swapped out with the spare, I read somewhere the hubcap clips are riveted in how do I remove the old rivit without damaging the wheel and once I buy new clips I am assuming they include a rivet which I know how to apply. Thanks again, making progress everyday.
Linda Grunthaner wrote: |
Maui Roadsters
Lind wrote: |
Posted: Sun Sep 02, 2012 8:49 am Post subject: |
Drill the rivet out from the backside of the rim. Be careful not to make the hole too big.I use a 1/8" bit, which is smaller than the rivet, but once drilled I use a small center punch to drive the old rivet through the hole.
I also grind the back of the rivet flush with the wheel to get rid of the mushroomed part of the rivet. Sometimes that is enough to make the rivet come out without drilling. Don't overdo the grinding, just remover the rivet mushroom.
You need a special rivet tool to install the factory rivets. I don't bother with that anymore, but I built a tool for it years ago. Now, I just use a small screw and a nylock nut. Works perfect every time, it can't be seen with the hubcap on, and if a clip breaks, it's much easier to replace. _________________ You can't spell sausage without "USA"! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25948 Location: Olympia Wash Rinse & Repeat
Posted: Sun Sep 02, 2012 9:37 am Post subject: |
Lots easier (and no risk of drilling off center) to either use a small chisel to chop off the rivet head or use a dremil cutting disc to do this if worried about slipping with the chisel and hitting nicely painted rims.
Then pin punch out the rivet remains.
See 1963-67 Workshop Manual, section B-10, page 3. _________________ In Stereo, Where Available! |
Posted: Tue Sep 04, 2012 2:25 pm Post subject: |
Eric&Barb wrote: |
See 1963-67 Workshop Manual, section B-10, page 3. |
Thanks nice dolly:
Maui Roadsters
Lind wrote: |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15231 Location: Casa de Oro, California
Posted: Fri Jul 11, 2025 6:26 pm Post subject: Re: mounting tires |
Anyone know if modern (or older) tire mounting machines can mount the tire onto the rim with the beauty ring installed? |
BarryL  Samba Member
Posted: Fri Jul 11, 2025 8:17 pm Post subject: Re: mounting tires |
Since beetle rims can be put on a type 2 and visa versa, it does not matter which lug bolts you use in a tire adapter. _________________ In Stereo, Where Available! |
