goffoz Samba Member
Posted: Mon Sep 03, 2012 6:17 pm Post subject: Butyl adhesive for the door vapor barrier? |
Ok professional body guys...where do you buy this stuff that Vdub uses to hold door plastic, and carpet for 20yrs, with out hardening ?
As usual I asked all the locals........and guess what they say "Just tear that plastic out and throw it away"..."Doesn't do shit !...what'dya need it for???"
"Butyllll what ?"
Yeah I tried a little search ...YaDah YaDah.Whatever
I'm so tired of Rednecks...maybe there's a virus we can put in the Butt=wiper
and kill them all...If you know what I mean
..thanks for any tips on butyl adhesive vendors |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
pigryder Samba Member
Joined: January 17, 2012 Posts: 162 Location: south central PA
Posted: Mon Sep 03, 2012 6:52 pm Post subject: |
I get it from local parts store _________________ 1982 Westfalia L Diesel "Stink"
1982 Vanagon GL Diesel "Charlie"
1983 Rabbit GTI a 20 year love affair
1988 Cabriolet diesel |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12424 Location: Santa Cruz, CA
Posted: Mon Sep 03, 2012 7:03 pm Post subject: |
| People often call it dumdum(not a joke) a good auto parts shop should be able to get you a 3m equivalent. |
goffoz Samba Member
Posted: Mon Sep 03, 2012 7:26 pm Post subject: |
Thankyou thankyou.
I know the glass guys/grls...they drink wine, and will probably be helpful.
as for the FLAps....Hmmm ...its still "Butyl??, for what?"
"Is that like Sillycone?"
I dunno ...maybe its my accent...or the fact that I make sentences with subjects and ? marks.
Thankyou I'll see the glass chick in the AM. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16823 Location: State College, PA
Posted: Tue Sep 04, 2012 3:53 am Post subject: |
Last tube I got was from Lowes or Home Depot. Think it was with the other caulking. But I tend to grab whatever is handy anymore (trim adhesive, silicone caulk). And on the subject I cant believe that people pay someplace like Mid America $20 for 4 pieces of plastic sheet that is the same thing as a heavy garbage can liner......  _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Bntbrl Samba Member
Joined: September 04, 2012 Posts: 438 Location: Sydney, Australia
Posted: Tue Sep 04, 2012 4:29 pm Post subject: |
Not sure if you are replacing something or are r and i for repair. If you are removing the sheet to make a repair use either a razor blade or a sharpened metal filler spreader and cut the dumb dumb. When you're done stick the dumb dumb sides back together.
You can also get dumb dumb a.k.a. Thycol or whatever else you want to call it at part supply places, comes in a box rolled with a paper separator.
Plastic sheet is a vapor barrier and is meant to contain moisture from coming in from areas like the belt molding at the window line, etc. |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Tue Sep 04, 2012 4:40 pm Post subject: |
I've used non-hardening gasket sealer, stuck fine and can still unstick/stick it years later.
_________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
I use this stuff for lots of projects where butyl rubber is required.
I don't use it for vapor barriers, though. I use either Permatex or 3M spray adhesive to adhere plastic barriers to the doors. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
rlamb Samba Member
Joined: March 26, 2012 Posts: 211 Location: Sweet Home, OR
Posted: Thu Jul 21, 2016 4:55 pm Post subject: Re: Butyl adhesive for the door vapor barrier? |
I just bought a tube of the DAP butyl flex today for less than $6 at Bi-Mart here in OR. Ace didn't have it here.
http://www.dap.com/dap-products-ph/butyl-flex-gutter-flashing-sealant/ _________________ 1984 Westfalia - Ford Cologne 2.8L conversion
2003 Passat GLX Wagon (4Motion) |
pbrown Samba Member
Joined: July 15, 2008 Posts: 542 Location: Seattle, WA
westylife Samba Member
Joined: October 28, 2007 Posts: 410 Location: Anchorage, Alaska
Posted: Fri Jul 22, 2016 5:01 pm Post subject: Re: Butyl adhesive for the door vapor barrier? |
I just used a roll of carpet protector that I bought at Home Depot. It comes in a roll and one side is sticky. Movers use it to put over the carpet so they don't have to take their shoes off. You can see it on this thread http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=20[img][/img]
Works really well; then just trim with a razor blade.
WL _________________ 1983.5 Westfalia Bostig RG1 |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4784 Location: Arizona Highways
Posted: Fri Jul 22, 2016 5:49 pm Post subject: Re: Butyl adhesive for the door vapor barrier? |
word! _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
boroko Samba Member
Joined: September 11, 2012 Posts: 326 Location: S.W. Michigan
Posted: Fri Jul 22, 2016 6:03 pm Post subject: Re: Butyl adhesive for the door vapor barrier? |
| Quote: |
| I just used a roll of carpet protector |
Sweet re purposing idea. I love it when someone discovers a alternate use for something that is perfect for a totally unrelated application.
Bo _________________ '87 SyncroWesty: Smokey the Turtle, '85 SubiWesty: Chappie, '84 GTI, '86 GTI in full Rally trim,
previous: 2 Syncro tin tops, 2 Vanagons, 3 busses, 3 Ghias, 2 Jettas, a 411, a gas and a diesel Bunny and about 25 Beetles, one that only drove left. |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4307 Location: Redwood City, California
Posted: Sat Jul 23, 2016 8:55 am Post subject: Re: Butyl adhesive for the door vapor barrier? |
Butyl lets loose and spray glue will not last. I use Construction adhesive like what they use for putting paneling on walls. It comes in a caulking tube and will bond to the paint of the door and to plastic sheeting. When you need access to the door again, just cut it with a razor blade and re apply.
I've used adhesion promoter on the plastic when making new door skins . Don't let anyone tell you they are not needed, They are a noise dust and vapor barrier.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Terry Kay Banned
Posted: Sat Jul 23, 2016 9:14 am Post subject: Re: Butyl adhesive for the door vapor barrier? |
I have always used 3-M spray adhesive.
Allow it to set up, apply the viscuine, it'll never come off.
Fast, easy, permanent. _________________ T.K. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Sun Jul 24, 2016 7:42 am Post subject: Re: Butyl adhesive for the door vapor barrier? |
When the surface is prepped right, butyl works great.
Strip caulk does not have the holding power and will not work what so ever.
Spray adhesive works quick and easy. The trick is to let it dry a bit. This is my go to procedure for plastic vapor barrier installation. |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4634 Location: East Kootenay, British Columbia
Posted: Sun Jul 24, 2016 10:18 am Post subject: Re: Butyl adhesive for the door vapor barrier? |
I've have always just used a cheap tube of clear window caulking. Stays flexible and holds fine. You do have to reapply when you remove the plastic at a later date. If your plastic moisture barrier is all ripped up from PO hacks you can replace with simple clear plastic painters tarp.
To those hacks that say "just pull that plastic off-you don't need it" bull sh*t! That moisture barrier is very important. Rain will always get past the window scrappers and into the door, without the barrier the door panels get wet, moldy, and begin to fall apart. They also help with drafts, noise and insects.
I just recently pulled the door panels off my Geo Tracker, I had the panels off a couple years ago to install some sound deadener, and the clear window caulk was still holding fine and the inner door was full of dead stink bugs. Damn things are everywhere around here in the fall; the barrier kept them out of the interior of the car. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Merian Samba Member
Posted: Sun Jul 24, 2016 11:38 am Post subject: Re: Butyl adhesive for the door vapor barrier? |
clear window caulking most likely has silicone in it, so you can never ever take it to a painter
if you do, he will hunt you down and kill you _________________ .... |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3680 Location: Dartmouth, Mass.
Posted: Mon Nov 23, 2020 11:05 am Post subject: Re: Butyl adhesive for the door vapor barrier? |
| westylife wrote: |
WL |
Any report on how's it holding up? Anyone else use this?
I located it @ the Big Box store website - there were comments on it being basically a thicker Saran Wrap.
I was thinking of using something thicker, but perhaps that is unnecessary. _________________ John - 86 Wolfsburg Westfalia "Weekender"
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
