DonziGT230 Samba Member
Posted: Thu Sep 27, 2012 8:20 am Post subject: 8 dowel flywheel on 4 dowel crank; any issues? |
I have a lightened 8 dowel I got from a buddy I'd like to put on my stocker. It seems to fit fine, not as tight as the stock one which fits very tight, but not loose at all. Looks like there'd be no problem, just making sure there's not something I've overlooked. Most importantly, could it have different balance? I think vw wheels are neutral balance-?- It was on a forged 84mm stroker crank. I will be rechecking thrust in case it's different. _________________ I refuse to call a distributor a dizzy--earthquake.
The glass is always full and I can prove it!--me |
jeffsbugs Samba Member
Joined: May 02, 2011 Posts: 293 Location: Nanaimo, British Columbia, Canada
Posted: Thu Sep 27, 2012 8:51 am Post subject: |
I wouldn't recommend doing this.
If you want to use an 8 dowel flywheel get the crank drilled for 8 dowels. You don't want that connection to come loose.
http://www.aircooledtech.com/8_doweling_crank/
I had a lightened flywheel on my baja and hated it. Very much reduced rotational mass to go slow and crawl over stuff and also to coast. Very good throttle response though.
Jeff _________________ '73 Westfalia, rebuilt 1700, dual OG solex - 3500 miles and counting
'62 Baja |
oukno Samba Member
Posted: Thu Sep 27, 2012 8:55 am Post subject: |
Just buy the die/tool
Drill your stock crank and make it an 8early dowel
otherwise I do see it as being a weak spot in a place you don't want things to be weak _________________ 64 baja
64 ghia
74 Scout II
74 Tahiti Jet boat
02 Sierra 2500 HD
Love them all but I never enough time to play with them. |
Posted: Fri Sep 28, 2012 3:54 pm Post subject: |
Ok, thanks guys.
Are flywheels ever balanced to the motor or are they always neutral balance? _________________ I refuse to call a distributor a dizzy--earthquake.
gargamel Samba Member
Joined: December 20, 2011 Posts: 693 Location: Orange Grove, Texas
Posted: Mon Nov 05, 2012 12:02 pm Post subject: |
Old post but it on the question I also have.
Seller just sent me a nice German flywheel but it has 8 holes while I requested 4 hole. He stated that I did not need to waste money sending my crank to get it machined for a 8 dowel since my stock 1600 engine would not put any punishment on the flyweel and I can easily run it with 4 dowels. Of course he said the internet guys are misleading me. Go figure.
Any thoughts? |
joescoolcustoms Samba Member
Posted: Mon Nov 05, 2012 9:55 pm Post subject: |
You will have 4 extra holes. Those holes are a weak area at a small circle of high torque. The flywheel is not hardened and even though the stock engine is regarded as low on power, it can deform the area around the dowells and slowly move metal into the open hole area making the dowell occupied hole oblong.
I have seen this happen on engines I have torn down that ran a 8 dowell on one side and 4 dowells on the other.
I have sucessfully cut dowells to where they will fit into the open holes, sit just below the gland nut seating surface and run them many years without metal deformation. The dowells are hardened steel and hard to cut, but fill that gap and keep the softer metal around it from moving.
It also appears to me your parts supplier does not want to make the purchase right. Don't settle, you will pay for it in the end. I would 8 dowell the crank if you have the crank out of the case. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
donbarnes Samba Member
Joined: February 28, 2011 Posts: 731 Location: Wilmington,NC
Posted: Wed Nov 07, 2012 8:33 am Post subject: |
I've forgotten the whole issue now, but it seems I tried to put a 8-dowel CB flywheeel on a stock crank and one of those holes on a 8-dowel is slightly offset and it wouldn't fit right on the stock crank? Can't remember now what fix I used... _________________ Hater of cheap parts and poor workmanship.. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79500 Location: Sneaking up behind you
Posted: Wed Nov 07, 2012 8:39 am Post subject: |
donbarnes wrote: |
I've forgotten the whole issue now, but it seems I tried to put a 8-dowel CB flywheeel on a stock crank and one of those holes on a 8-dowel is slightly offset and it wouldn't fit right on the stock crank? Can't remember now what fix I used... |
It's a SPG pattern, only one dowel is offset, so rotate it one dowel and it will fit. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Wed Nov 07, 2012 9:11 am Post subject: |
donbarnes wrote: |
The offset was put there to index the crank and flywheel so that balancing efforts would be maintained. You just twist the flywheel one dowell and the 4 stock dowells will line up.
This offset dowell configuration is called the Okrasa pattern. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Wed Nov 07, 2012 9:13 am Post subject: |
Did not see Glenns post. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3389 Location: Dirty Jersey
Posted: Thu Nov 08, 2012 8:17 am Post subject: |
If you leave the 8 dowell flywheel on a 4 dowel crank, when you do some offroad beatings, you will ruin the crank and flywheel. Especially if you like to dump the clutch and spin the wheels in dirt and sand. _________________ 1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks! |
