DaleNW Samba Member
Joined: March 29, 2012 Posts: 169 Location: Boulder, CO
Posted: Wed Oct 10, 2012 5:18 pm Post subject: Headliner Flocking replacement on 78 Westy |
I've completely redone the fiberglass top on my bus. It looks brand new - maybe better (if that's possible). The old flocking on the inside is now gone and I want to replace it with something that will help control the condensation. I've owned pick up truck camper shells that were lined with a thin marine carpet and it worked great. However, I have had a hard time finding the right material to put up there. I found out that the material that I am looking for is called Trunk Liner - but it only comes in Black and a few shades of grey/heathered black. I'd love to find it in a tan or heathered tan. Anyone found anything like it or have another suggestion?
mtcamper Samba Member
Posted: Wed Oct 10, 2012 5:25 pm Post subject: |
Looks like you did a great job!! I dont know of what you can use but I will be watching this. I put on new canvas last year and while I had the top off I bleached the flocking ( that worked great for the moldy spots) and tried to scrub some flocking off not knowing why it was there. On my last camp trip condesation on the part where I removed the flocking was beading up. I felt the section with the flocking and it was moist holding the condensation, doing its job. Bottom line you definately want to find some sort of fabric to put up there felt mabey? Might want to try a marine/rv shop. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52883 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 10, 2012 5:55 pm Post subject: |
Why not put the flocking back?, there's lots of kits for doing the job at home, Google is your friend here. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
DaleNW Samba Member
Posted: Wed Oct 10, 2012 6:33 pm Post subject: |
Thanks. Great suggestion to just add flocking back the way it was. I was hoping to use something a bit thicker for noise and temperature insulation. I do quite a bit of camping year round, including snow camping here in WA. |
DaleNW Samba Member
Posted: Thu Oct 11, 2012 9:25 am Post subject: |
Thanks BusDaddy! You've provided some great suggestions. I'll take a look at the various options and see what might work best. I plan to be finished with this stage of the restoration by April and hope to be at the NW Springmeet. At least that's my goal. . . but still lots to do. I'll post more photos once I get more done. |
DaleNW Samba Member
Posted: Thu Oct 11, 2012 10:19 am Post subject: Westfalia Pop Top Flocking replacement Polymat |
Here is what I think I'll try. they offer it in several colors (but I am going with tan). it's only 2mm thick, so it will be nice and thin, but still offer condensation protection. I'll let you know how it is when I get it in.
http://www.polymatcarpet.com/products/carpet |
DaleNW Samba Member
Posted: Mon Nov 12, 2012 12:46 pm Post subject: |
okay - following up on this thread. I decided to go with a Speaker box material since it was all synthetic, thin, stretchable, and came in a nice tan (my bus is Dakota Beige). But, the material would not really follow stretch quite enough to dip low between the support beams in the roof and not be too slack along the sides where the support beams taper to 0. So, I decided to go with a flat section in the middle. Then, I could also add in insulation for winter camping (it will also reduce condensation).
I added a small piece under the long piece of insulation in the middle (peak of roof) to take up the rest of the space. it fit perfect and filled in all the gaps. |
DaleNW Samba Member
Posted: Mon Nov 12, 2012 12:48 pm Post subject: |
Next, I cut a piece of formica laminate to cover all the insulation and provide a smooth substrate beneath the headliner material.
Can't take it all the way to the ends though. Otherwise it blocks the tack board for attaching the tent. It would also block the attachment of the metal support bar at the front. |
DaleNW Samba Member
Posted: Mon Nov 12, 2012 12:52 pm Post subject: |
Finally, I glued down the new headliner material and trimmed the edges. it stretched and molded around the ends very nicely. Now, my roof is warm in the winter, cool in the summer and quieter year round. Also, no more condensation drips on the face when you wake up!
Yondermtn Samba Member
Joined: November 21, 2007 Posts: 614 Location: Illinois
Posted: Mon Nov 12, 2012 1:44 pm Post subject: |
Very nice  |
Bala Samba Member
Joined: December 04, 2003 Posts: 2637 Location: Austin, TX
Posted: Mon Nov 12, 2012 1:56 pm Post subject: |
Sheesh, another project I have to add my list now. Thanks a lot!
Looks like a quality job you did there!  _________________ 1976 Westy
1966 Beetle |
Posted: Mon Nov 12, 2012 2:01 pm Post subject: |
Hey!, that looks nice!, good job! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
DaleNW Samba Member
Posted: Mon Nov 12, 2012 4:00 pm Post subject: |
Thanks for the compliments. I know it isn't original, but It looks nice and clean in addition to making it much more usable for the wife and I to snow camp.
Overall, the project was relatively easy - once I figured out what I wanted to do and how to do it. Cutting the laminate perfectly was the hardest, but a Dremel with a cutting wheel did a nice job.
Up next, cleaning and clear coating the latch and catch. Already sandblasted and painted the rear hinges and they look great!
DaleNW Samba Member
Posted: Tue Nov 20, 2012 5:46 pm Post subject: |
okay, so I made a small change. I wasn't keen on the darker color of this tan. I wanted something lighter and I found it. it is marine hull-liner/headliner from www.perfectfit.com - and fortunately, they are located in Seattle, so I just ran over there and picked it up. (side note, they also have a great double foiled sound and thermal insulation to replace the foil and batting insulation between the gas tank compartment and the tranny). Here's the link - http://www.perfectfit.com/15593/154092/Marine-Carpet-and-Hulliner/Hulliner-and-Headliner-72.html
I went with the "Sand Stratos"
Now it will match my new tent perfectly!  _________________ '78 Deluxe Westy - Loose Lucy (where I rest peacefully)
'77 Transporter (may it rest in peace) |
eche_bus Samba Member
Posted: Wed Mar 04, 2015 5:52 pm Post subject: |
Looks really good!  |
Our79Westy Samba Member
Joined: August 08, 2012 Posts: 97 Location: Bronson, FL
Posted: Wed Mar 04, 2015 6:52 pm Post subject: |
Super job. Great inspiration. I am pursuing a similar modification on my 79 Westy "Constance" for at least the sound dampening.
May I please inquire as to how your headliner and insulation is holding up after 2 years in action?
Also, have you experienced any unintended consequences? Like maybe water condensation, vibration noise or anything?
Thanks in advance for any update and advice. _________________ 1979 Westfalia DELUXE 2.0 FI manual
Mexican beigeutiful and mostly original.
See the most up to date status of Constance on YouTube
https://m.youtube.com/channel/UCvO1ZedS22IepvvRYaTxiPQ
My 1979 Westfalia Campmobile's sundry Tales of Constance
http://www.thesamba.com/vw/forum/viewtopic.php?t=620965
1990 Vanagon, Red, Driven 70,000 miles till sold.
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Thu Mar 05, 2015 9:19 pm Post subject: |
I realize this is an old thread, but how did you secure the laminate down to the roof? Just contact cement or something?
That looks killer, I was trying to think of a way to get some sound deadening up there. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
airkooledchris Samba Member
Posted: Thu Mar 05, 2015 10:12 pm Post subject: |
that looks so good id consider using it to replace the actual headliner in a passenger model. I don't really like the classic headliners unless they are absolutely perfect, and nearly none of them are.
if I had a show vehicle, id go stock, but for a driver I really like the idea of this setup in any bus. |
DaleNW Samba Member
Posted: Sat Mar 07, 2015 11:01 am Post subject: |
Hey, sorry for not responding to the questions here. Somehow, I wasn't being notified of replies on this thread.
So far, I have been exceptionally happy with my roof system. It is quieter and warmer. It looks super clean and has stayed attached (which was my primary concern).
However, I have only had it out camping and on gravel roads about 1/2 a dozen times. The roof has been in the hot sun of Eastern Washington and the cold wet days of Western WA.
To attach the laminate, I sanded the bonding surfaces to create teeth. I then used contact cement - red can. I also used a lot of pressure and hard rubber rollers to make sure it was all pressed uniformly. Making sure the laminate fits perfectly without any stress on the edges is key.
Unintended things I had to deal with:
weight. Formica is light, but it still adds some more weight up top. I don't notice it as much, but my wife does.
strength: the roof is super strong now. I created basically a reinforced box. I can walk on the roof now with very little flex.
fittment issues: Even though the laminate is thin, it acts as a shim between a few parts that will need to be realigned. Also the hull liner material also adds extra thickness. 1) front support bar and latch. The screws are just barely long enough to get started. It can be done, but is frustrating. I replaced most of mine with stainless, so it wasn't as big of a deal. 2) H bar in the front. Because the upper attachment points are mounted to the roof on top and the side, I had to drill the side holes a bit lower for proper alignment.
Other than that, it was a solid project that was totally worth it. Most people (even at shows) don't notice it isn't stock unless you point it out, or they are looking close. Amazing how many people never look up.  _________________ '78 Deluxe Westy - Loose Lucy (where I rest peacefully)
