Another fog lamp install thread
isea
isea is offline
PostPosted: Sat Nov 17, 2012 7:18 pm    Post subject: Another fog lamp install thread Reply with quote
I am really sorry to bring up a topic that is gone over some many times already on the Samba but I really just want to make sure I do this right.
The fog lights I have only have one wire coming out of them. I thought there would be two. Isn't there suppose to be a ground wire too?
I have a 20amp fuse. Should that be installed between the switch and the battery or the lights and the switch?
I have a 20amp switch. I am unclear but from what I have read it seems like I would be ok with the 20amp switch and no relay.
Clearly I am ignorant about this installation so be patient please.
And if you want to just spell out the directions like I'm a 5 year old from another planet that would be fine too Smile
Thanks!
'67 Beetle, Fresh 1600cc SP
2.5" drop spindles
61SNRF
61SNRF is offline
PostPosted: Sat Nov 17, 2012 7:38 pm    Post subject: Reply with quote
Is your car 12 volt?
-Bruce
An ounce of prevention is worth a pound of cure.
isea
isea is offline
PostPosted: Sat Nov 17, 2012 7:40 pm    Post subject: Reply with quote
sorry, yes it's a 12volt
2.5" drop spindles
61SNRF
61SNRF is offline
PostPosted: Sat Nov 17, 2012 8:14 pm    Post subject: Reply with quote
Does it have an Alternator, or a Generator?
-Bruce
isea
isea is offline
PostPosted: Sat Nov 17, 2012 8:20 pm    Post subject: Reply with quote
It's a generator.
2.5" drop spindles
RareAir
RareAir is offline
PostPosted: Sat Nov 17, 2012 8:29 pm    Post subject: Reply with quote
Ground connection is made via the brackets to body, much like reverse lights.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
isea
isea is offline
PostPosted: Sat Nov 17, 2012 9:49 pm    Post subject: Reply with quote
OK, that's what I thought, but I wasn't sure.
2.5" drop spindles
isea
isea is offline
PostPosted: Sun Nov 18, 2012 9:35 am    Post subject: Reply with quote
OK, so is it safe to say I can run a 14 gauge wire from the battery to a 20amp switch then a 20amp inline fuse then the lights?
2.5" drop spindles
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Nov 18, 2012 9:36 am    Post subject: Reply with quote
How many Watts are your lights?
14 gauge should be ok, but can your switch handle the Amps?
Prolonged illumination of high wattage lamps can destroy switches in a short time.
As for fuse placement, it depends on your path for circuits. You need it close to the voltage starting source to protect the most.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
isea
isea is offline
PostPosted: Sun Nov 18, 2012 9:54 am    Post subject: Reply with quote
I'm embarrassed to say I do not know the watts on the lights. I got these ones:
http://www.socalautoparts.com/aftermarket-fog-lights-12-volt-5in-chrome-amber-p-17020.html
I don't see anything on the light or the shipping info with the watts.
As far as the fuse goes I just put that right off the battery I guess.
2.5" drop spindles
VOLKSWAGNUT
PostPosted: Sun Nov 18, 2012 10:02 am    Post subject: Reply with quote
You'll probably be ok using a 20 Amp rated switch only. (rather than adding a relay)
(Id really want to know how many amps those use.)
Id route a battery feed with the fuse at the battery, to supply your switch. That way the entire circuit added, from the battery is protected. Lower your fuse to 15 amps. I doubt those lights use that many amps, maybe 3-5 each.. Without measuring or knowing how many amps those lights use its a guess at proper amp rating fuse.
You can start low like 10, and if its ok.. leave it, if it pops after using without any other fault, up it to 15.
aka Ken {o\!/o}
61SNRF
61SNRF is offline
PostPosted: Sun Nov 18, 2012 10:14 am    Post subject: Reply with quote
If the kit came with a 20 amp fuse, that's probably about twice what the lights draw, in other words ~10 amps total or 5 amps each.
Ohm's law say's: 12v x 10a = 120 watts total.
Most auxiliary lights will draw an excessive amount of electrical power for a stock 12v Beetle with a stock Generator. The car was not designed with any extra reserve of electrical power for accessories other than a transistor radio.
If you are serious about this, really need and will use the Fog lights, then you would be well advised to upgrade to an ALT with higher output, a Battery with a larger capacity, and for optimum performance run them through a relay.
-Bruce
Miklo
¡Chale!
Miklo is offline
PostPosted: Sun Nov 18, 2012 10:29 am    Post subject: Reply with quote
I believe those are the same fog light I have but not %100 sure...
My lights are H3 bulbs so each one is about 55W.
This is the diagram I basically used...
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
isea
isea is offline
PostPosted: Sun Nov 18, 2012 12:40 pm    Post subject: Reply with quote
great! thanks guys this is all very helpful
2.5" drop spindles
onetuza
onetuza is offline
PostPosted: Wed Jan 02, 2013 7:31 am    Post subject: Reply with quote
What gauge wire from the battery to the relay?
When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car!
VOLKSWAGNUT
PostPosted: Wed Jan 02, 2013 7:36 am    Post subject: Reply with quote
With Length and actual amps it can vary.
16 Gauge is fine, 14 Gauge is better, but may not be needed.
aka Ken {o\!/o}
Keith
Keith is offline
PostPosted: Wed Jan 02, 2013 11:07 am    Post subject: Reply with quote
Got a version of this chart for 6V ?
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
VOLKSWAGNUT
PostPosted: Wed Jan 02, 2013 11:36 am    Post subject: Reply with quote
Best I can do on short notice.... Wink
I'd have to search my 6 volt American Archives.
http://www.gtsparkplugs.com/WireSizeCalc.html.
Wire gauge rating is more about AMP capacity, the voltage is the pusher of said amps.
Rule of thumb, measure the amps and select the correct gauge. Usually 1 size larger for 6 volts. Thats simply to keep resistance down and voltage drop to a minimum.
aka Ken {o\!/o}
JSB
JSB is offline
PostPosted: Wed Jan 02, 2013 11:49 am    Post subject: Reply with quote
Veedubdoug,
Nice diagram. Is that the same relay used for rear window defog? If not, do you have a part #? Thanks.
