spencerfvee Samba Member
Posted: Fri Dec 14, 2012 4:46 pm Post subject: EMPI has there own cams are they china junk |
update where i buy my vw parts started selling EMPI cams . out of 7 cams they had to send 3 cams back to EMPI because the side clearance was 10 thousands when you installed the cam in the thrust cam bearing .that was on two of the EMPI cams the 3rd EMPI cam the center cam bearing was ground with a 6 thousands taper that stopped middle ..where the cam bearing would be if you buy one make sure you look it over real good my self i am never going to buy a EMPI cam spencerfvee......... i see EMPI has come out with there own cams . are they china junk or are they good . ?? looks to me that there ground the same as engle cams . i see EMPI does not sell engle cams any more .i wonder why lol .. to me i want the real deal when i buy a cam not some china look a like cam . how do you guys feal real deal cam or a china cam ?? spencerfvee
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80663 Location: Sneaking up behind you
Posted: Fri Dec 14, 2012 5:40 pm Post subject: |
I bet they are all made in China these days. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
67Callooker Samba Member
Joined: January 24, 2008 Posts: 158 Location: las vegas
Posted: Fri Dec 14, 2012 5:52 pm Post subject: |
glenn if im not mistaken engle is owned and made by so cal imports, so cal bought the maching from engle _________________ "dumbass" red foreman if you paint an engine case you probably forgot the tin |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Fri Dec 14, 2012 6:03 pm Post subject: |
| if im not mistaken I was told by engle they get thier cores from japan. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Fri Dec 14, 2012 7:05 pm Post subject: |
That should be illegal. I doubt anyone's buying those with Engles so readily available. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sat Dec 15, 2012 7:27 am Post subject: |
If you have to ask the question, I would just look elsewhere. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Posted: Sat Dec 15, 2012 11:29 am Post subject: |
| getting good stuff can be hard,Ive heard since crane closed down a lot of cores are not being produced in the usa any more,still a lot coming out of wisconsin from what I hear but with the roller cams in the oe cars now most are steel billet so making small spicific batches of cores isant a real money maker,comp cams does have a p55 cast core for thier cast roller cams. be nice if they would make a pile of them for us vw guys, it still needs nitriding to last but much cheeper than a billet steel cam,but the billet cam last a lot longer if all is good on the set up. or if you like just dish out the$$$ and get a tool steel camshaft.they are oh so sweet. |
72volksbug Samba Member
Posted: Mon Dec 17, 2012 12:18 pm Post subject: |
if your looking for a cam upgrade just go with engle there race proven street proven and not that pricey, i be leave i only spent like 80 something and thats with shipping, they give you the valve lash you should set with the cam, they give you the proper lube to break in the cam with and instructions on how to install, if you do upgrade your cam you might wanna think about changing your cam gear to straight cut gears but youll need access to a press unless you have a really strong grip lol but straight cut means no more thrust on your cam well greatly reduced thrust anyway lol. but thats just my two cents. _________________ Lets tear up se assfault! |
Posted: Mon Dec 17, 2012 12:46 pm Post subject: |
| not just thrust on cam but what else is it thrusting agnist??THE CRANK. |
Posted: Mon Dec 17, 2012 12:50 pm Post subject: |
are you crazy? The cam/lifters are the LAST thing you should be the guinea pig on. You can be a tester on a lot of different things, but it's crazy to try in on the cam/lifters with all the problems we've been having with them.
Don't be stupid. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2380 Location: Mount Airy, Maryland
Posted: Mon Dec 17, 2012 1:29 pm Post subject: |
| [email protected] wrote: |
Don't be stupid. |
Well said John.
To add to that; Choose a Web product if you can. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Posted: Mon Dec 17, 2012 1:34 pm Post subject: |
dam john i was just asking what people thought . i dont buy empi junk . i buy engle cams for all my motors . in my own way i was pointing out that EMPI fu%ked engle cams by making there own china cams that are the same as engle cams . EMPI and wallmart are the little china and they both dont care who they hurt . spencerfvee
Don't be stupid. |
slalombuggy Samba Member
Posted: Mon Dec 17, 2012 1:42 pm Post subject: |
| spencerfvee wrote: |
Don't be stupid. |
Not defending Empi, but are you sure they #$%$# them out of their cam grinds and are making them in China? Maybe they are buying their cams direct from So-Cal/Engle. I'm not going to test them, but until someone knows the facts, is this post really accomplishing anything. Until someone finds out correct information, this is all just more B.S. FYI My new cams are going to be Web from now on.
brad |
Posted: Mon Dec 17, 2012 2:30 pm Post subject: |
how much is an Engle cam? SCAT?
if you are trying to do it on the cheap, these are the only 2 I'd consider. I don't care what the EMPI ones are made of, they are not proven. If the cam goes bad you are looking at close to $1k in parts replacement. Rings, cylinders, oil pump crank reground, all bearings, re-balancing, etc etc. MAJOR MAJOR HEADACHE.
There are a lot of places you can skimp, the cam is not one of them.
Just because EMPI says "same as Engle, only cheaper" doesn't mean you have to bite on that hook. Don't be a sucker. _________________ It's just advice, do whatever you want with it!
Posted: Mon Dec 17, 2012 2:58 pm Post subject: |
no they are not made by so cal. i talked to them .all so cal said was they no longer sell engle cams to EMPI . and they sounded like they were not very happy with EMPI at all . the point of this post was that nothing any one makes. is safe from being remade in china. and sold at a cheaper price . because the USA lets anything come into the USA from china . spencerfvee
| slalombuggy wrote: |
Don't be stupid. |
brad |
Posted: Mon Dec 17, 2012 3:32 pm Post subject: |
if EMPI did what they usually do, they just copied all of Engle's cams and lifters, and have them made in China now. _________________ It's just advice, do whatever you want with it!
ALB Samba Member
Joined: August 05, 2008 Posts: 3506 Location: beautiful suburban Wet Coast of Canada
Posted: Mon Dec 17, 2012 3:46 pm Post subject: |
| Just because EMPI says "same as Engle, only cheaper" doesn't mean you have to bite on that hook. Don't be a sucker. |
If more people would think like that... _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Mon Dec 17, 2012 4:10 pm Post subject: |
john thats the point i was making . at one of the shops i buy my vw parts off of they have the new EMPI cams when i looked at the empi cam specks they were the same as engles cam specks . i only had time to check out the EMPI 110 cam specks they were real busy that day i was there . there for sure made in china john some guy posted on samba and said EMPI copied some guys wheels and the guy saw them at the SEMA show . and he was pissed off big time . i think the day has come to a end for any little guy to make some thing to sell and make a good living selling it .. because some jerk will come along and have china make it. and sell it cheap and theres nothing the little guy can do to stop it . spencerfvee
| if EMPI did what they usually do, they just copied all of Engle's cams and lifters, and have them made in China now. |
Posted: Mon Dec 17, 2012 4:18 pm Post subject: |
I just talked with Engle.
I haven't checked this, because I wouldn't sell an EMPI cam in the first place, but word is the EMPI cam advertised #s do not match the Engle equivalent, even though they are advertised with identical #s. I do not know how far they deviate from them, I really don't care (since we would never sell them anyways).
I think you are a chump if you know this stuff and choose the EMPI anyways. _________________ It's just advice, do whatever you want with it!
Posted: Mon Dec 17, 2012 4:41 pm Post subject: |
hay john i am with you . i would never buy a EMPI cam . never.. i am done got to get my race car ready for next year... at this point i could care less about EMPI cams lol lol merry x mass to all and happy new year to all spencerfvee
I think you are a chump if you know this stuff and choose the EMPI anyways. |
