What type of lubricant goes in a Vanagon gearbox?
[email protected]
aadamsfam4@msn.com is offline
PostPosted: Sat Dec 15, 2012 9:57 am    Post subject: What type of lubricant goes in a Vanagon gearbox? Reply with quote
I have a 1990 2wd vanagon, what type of lubricant goes in the gearbox?
thanks
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Sat Dec 15, 2012 10:00 am    Post subject: Reply with quote
assuming its a manual: 80w90 hypoid gear oil.
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
Franklinstower
Franklinstower is offline
PostPosted: Sat Dec 15, 2012 10:20 am    Post subject: Reply with quote
There is a lot of discussion about this. The most important aspect is a GL4 oil
Sweepco is highly recommended, otherwise stick with a GL4 80-90 weight Hypoid gear oil. It must not be a GL5! GL5 has additives that are harsh on the yellow metals in the gearbox. Like Bronze.
Also, many say do not use Redline MT synthetic either.
Paul
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
AtlasShrugged
AtlasShrugged is offline
PostPosted: Sat Dec 15, 2012 10:30 am    Post subject: Reply with quote
If it is an automatic trans-axle..use GL-5..its recommended by VW. If a manual gearbox..GL-4
insyncro
Banned
insyncro is offline
PostPosted: Sat Dec 15, 2012 10:34 am    Post subject: Reply with quote
Swepco is my choice for the manuals.
Timwhy
Timwhy is offline
PostPosted: Sat Dec 15, 2012 11:00 am    Post subject: Reply with quote
I put in synthetic gear oil in mine.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
joseph928
joseph928 is offline
PostPosted: Sat Dec 15, 2012 11:05 am    Post subject: gear oil Reply with quote
Blue Bay Bus X2- Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
xoo00oox
xoo00oox is offline
PostPosted: Sat Dec 15, 2012 11:08 am    Post subject: Reply with quote
Eight sticks of butter.
seventyfo
seventyfo is offline
PostPosted: Sat Dec 15, 2012 11:14 am    Post subject: Reply with quote
I bought a rebuilt manual transaxle for my 85 from Rancho and put NAPA GL-4 in it and had problems with it not shifting correctly in 1st and second and also seemed to be getting too hot. Mike at Rancho sent me 4 qts of LAT/Lubeatech 80/90 and after changing it out have no more shifting or heat issues.
85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey
Skip Laubach
Skip Laubach is offline
PostPosted: Sat Dec 15, 2012 11:21 am    Post subject: Reply with quote
May I elicit opinions regarding use of Lucas 80W-90 (exceeds GL-4 and GL-5) and/or Royal Purple Max-Gear 75W-90 (also exceeds GL-4 and GL-5) for '84 manual?
Perhaps either is "OK", but for any reason would prior-posts-mentioned products be preferred?
Thanks.
Skip
1984 Westy 1.9 case WBXR Manual (now with 2200cc GoWesty kit)
Since 26 July 2011
AtlasShrugged
PostPosted: Sat Dec 15, 2012 11:55 am    Post subject: Reply with quote
Thanks.
There is some confusion and marketing junk concerning gear oil. GL-4 is not an older or obsolete API specification replaced by GL-5. GL-5 is not "better" than GL-4.
GL-4 gear oil has less sulfur and some other additives that can damage "soft metals" like bronze or copper. Many manual gearboxes use brass/bronze syncros. That is why GL-4 is specified. GL-4 has more friction modifiers to help with hot lubrication. It is used on most modern manual transmissions.
GL-5 has a very robust sulfur/zinc additive package that works well with all steel and "hard" metals. It can be formulated without being concerned with damage to "soft metals". It works well in the all steel trans-axle like our automatic Vanagons, rear end differentials and Porsche 915 manual gearboxes.
When a bottle of gear oil says "exceeds GL-4 and GL-5", that is just nonsense. I would avoid those products. Probably just GL-4 with a load of friction modifiers.
Find a gear oil that meets the API spec and says so: GL-4 or GL-5, plain and simple. Swepco is an excellent gear oil. Hard to find. Any name brand synthetic would work too.
Do not use a gear oil that is labeled for "limited slip" differentials. They use a different formulation for the friction plates in a LS diff. Won't hurt anything, but you can do better.
The Vanagon manual gearbox spec is GL-4 or automatic diff is GL-5. Use the right lube with confidence.
outwesty
outwesty is offline
PostPosted: Sat Dec 15, 2012 12:02 pm    Post subject: Reply with quote
GrindGarage
GrindGarage is offline
PostPosted: Sat Dec 15, 2012 12:10 pm    Post subject: Reply with quote
I think this forum needs a like button.
-cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com
insyncro
Banned
insyncro is offline
PostPosted: Sat Dec 15, 2012 12:27 pm    Post subject: Reply with quote
Now that's brilliant Andrew.
The smell of gear oil makes me want to puke.
I'm picturing Homer Simpson under a vehicle drinking all the used buttery fluid coming out during a service.....uummmm....buttery fluid....num num num Laughing
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Dec 15, 2012 12:32 pm    Post subject: Reply with quote
Please use the existing topic on gear lubes and GL4 vs GL5.
GL 4 or GL 5 - "Official Gear Lube Topic"
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Vanagon All times are Mountain Standard Time/Pacific Daylight Savings Time
