Jeff Power Samba Member
Joined: October 13, 2004 Posts: 1170 Location: with any luck, in my garage building bass guitars.
Posted: Fri Apr 20, 2012 6:52 am Post subject: |
This bus is one of my favorites. _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
Check out my basses here www.ellabasses.com
| jerry wrote: |
Nothing says "I love busses" more than picking up a mouse turd filled with horse hair seat padding |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1663 Location: In Your Face...
Posted: Fri Apr 27, 2012 4:48 pm Post subject: |
| Jeff Power wrote: |
| This bus is one of my favorites. |
Well guys.... I have some bad news to report.
The effort to reach the Madera show this weekend, has been abandoned.
This is due to broken bleeders, and a lack of time to invest...
This is all that I have the authority to comment on at this juncture... Dan will respond once he has the time off from work.
But seriously, all that's left is the brake pluming, and to wire the coil... fine tune the motor, and the carb... and an hour at most.
I/we did try though.... but Jedi luck was not on our side of the Force for this trip.
But....
Sorry Dan-Dan.....  _________________
| Lind wrote: |
| Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
drumming123 Samba Member
Joined: April 04, 2004 Posts: 723 Location: Merced, California
Posted: Fri Aug 03, 2012 11:41 am Post subject: |
After a long hiatus, I am back. I finished up the shift rod, which was giving me never ending problems, and now have 4 forward gears and 1 reverse gear.
I went to bleed the brakes today, and ran into a problem. Me and a partner were bleeding the brakes with the 'him pumping and I watch the fluid come through the clear plastic hose' method and everything seemed fine. After the air was out of all the lines, there still appeared to be no pressure at the pedal. Where did I go wrong? Dual circuit master cylinder, wheel cylinders, hard and soft lines are all new.  |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53212 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Aug 03, 2012 12:07 pm Post subject: |
Did you adjust all the brakes before bleeding? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Aug 03, 2012 12:30 pm Post subject: |
| busdaddy wrote: |
| Did you adjust all the brakes before bleeding? |
The rear two yes, front are discs. |
Posted: Fri Aug 03, 2012 4:20 pm Post subject: |
I didn't know the bleeder valves had to be over the brake lines...
Needless to say I took care of that. They still feel spongey, I'll have to go through and bleed them all again I suppose. Anyway, took her for a cruise around the block for the first time in at least 6 months. I've got a lot of bugs to work out, but it felt good to make some progress.
Here is a short video whipped together on my iPhone.
Posted: Fri Aug 03, 2012 9:51 pm Post subject: |
I wish I could've helped out earlier in the week... but I have Life working against me too.... all apologies, my VW brethren .
BTW: How'd you 'bench-bleed' the master cyl? If done correctly, you could've solved your own "squishy-ness" on your master cylinder.... before you posted this problem, brother-bear.
Just a thought... _________________
| Lind wrote: |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Fri Aug 03, 2012 10:26 pm Post subject: |
| drumming123 wrote: |
| busdaddy wrote: |
Dan-You do know the fronts need to be bled also, even though they are discs, right? That may explain some of the squishyness. The bleaders on those need to be as high as possible also.
And what is with the test drive? There were absolutely NO sparks or gouges in the asphalt. And you just cruised into your driveway. I thought you were going to slam that thang.  _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Fri Aug 03, 2012 10:34 pm Post subject: |
| cru62 wrote: |
| busdaddy wrote: |
And what is with the test drive? There were absolutely NO sparks or gouges in the asphalt. And you just cruised into your driveway. I thought you were going to slam that thang.  |
And I thought that I only saw 1 headlight too... _________________
| Lind wrote: |
Posted: Sat Aug 04, 2012 5:01 am Post subject: |
Dont have much to add other than my compliments.
Did I mention I love this Bus!! _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
| jerry wrote: |
Posted: Sat Aug 04, 2012 4:58 pm Post subject: |
| Busryder wrote: |
Just a thought... |
I didn't bench bleed the master cylinder.. I didn't know I had too.. Whoops..
| cru62 wrote: |
| busdaddy wrote: |
I bled the front as well, just the top bleeder valve on one calliper was snapped off.. So instead of trying to spend all day getting that bleeder out, I removed the calliper, flipped it upside down to bleed it, then bolted it back on.. That was made my pedal go from hitting the floor, to having pressure.. Still didn't have complete stopping power though.. hmm..
And the test drive did goudge the driveway.. I just removed all the sound because all you could hear was the noisey electric fuel pump.
The ride around the block was WAYYYY smoother than I was expecting.. plenty of suspension travel and it is nice and soft, like I'm floating..
| Busryder wrote: |
And I thought that I only saw 1 headlight too... |
Yeah yeah yeah.. I gotta get another
| Jeff Power wrote: |
Did I mention I love this Bus!! |
Thanks Jeff! I love this bus too.. haha |
quartermilecamel Samba Member
Posted: Sat Aug 04, 2012 5:15 pm Post subject: |
Are you sure the floating wasnt from your mind in a vw induced high driving your bus around the block? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
cage66 Samba Member
Joined: January 14, 2005 Posts: 2039 Location: reno,nv. cultwagen.com
Posted: Sat Aug 04, 2012 6:58 pm Post subject: |
Awesome job Dan.
Looks great. Shit is SLAMMED!
Best thing I did bleeding wise was a simple gravity bleed.
Raise the front up and crack the furthest valve and put a tight tube on the valve into a can then let it sit for a few hours. Checking the fluid in the reserve often. It may take longer to fully bleed out but this has worked best for me. |
a1steaksauce Samba Member
Posted: Sun Aug 05, 2012 6:49 pm Post subject: |
glad to see this is back!
enjoyed your work on this and i love the video of her cruising around the block. |
Posted: Sat Aug 25, 2012 10:36 pm Post subject: |
Found em' trying to hot rod my bus down the street, but he couldn't get the key right, so he asked me for help.
Posted: Sat Aug 25, 2012 11:41 pm Post subject: |
| Busryder wrote: |
Send my LOVE to the boy man... good job Dan-Dan! |
http://www.thesamba.com/vw/forum/viewtopic.php?p=6226600&highlight=send#6226600 _________________
| Lind wrote: |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Salvarican Samba Member
Posted: Sun Jan 06, 2013 4:17 pm Post subject: |
My thoughts ^^^^^
I just finished reading this whole build. Bad ass thread. True inspiration. |
Posted: Sun Jan 06, 2013 4:31 pm Post subject: |
I lost interest I suppose.. The first year of ownership I busted my balls on it and putting all kinds of hours into it and think I just burnt myself out. This last year I've done practically nothing with it. I got it registered about a month ago in hoped that it would motivate me to get some use out of it, but it didn't. I drove it once and it went back to its parking spot. I think I enjoy the hunt and the build more than actually utilizing it. I'm pretty happy with the way it turned out, and for being as low as it is, it drives incredibly smooth.
It just sold this morning. The new owner showed appreciation for the bumps and bruises the bus has and has led me to believe he will keep it as such.
This is the car I've held onto the longest though, 2 years. Haha
I'll be back one day when I hunt down another  |
LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5656 Location: 1st Coast
