PDXSyncro Samba Member
Joined: August 25, 2010 Posts: 135 Location: Portland OR
Posted: Sun Jan 06, 2013 4:15 pm Post subject: Rear hatch rubber door to body cable sleeve |
Hi Guys,
I'm in need of a new rear hatch cable sleeve with grommets. It's #33 in the image on this page:
http://www.jimellisvwparts.com/showAssembly.aspx?u...gory=21728
If they are not available has anyone had any luck fabricating anything? I figure a few grommets and a nice thin yet tight fitting rubber sleeve might work.
Cheers,
glen |
Timwhy Samba Member
Timwhy Samba Member
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
hdenter Samba Member
Joined: October 14, 2008 Posts: 2966 Location: San Luis Obispo, CA
Posted: Sun Jan 06, 2013 9:07 pm Post subject: |
I haven't gotten to this yet, but my plan was to search the wrecking yard for a similar tube and either use that tube or use the make and model to order a new one from that manufacturer. Switching to an oval tube would be a good idea, too.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Sun Jan 06, 2013 9:39 pm Post subject: |
Thanks guys I got the part number from the other link (251971840) and found it at busdepot. I just ordered it. We'll see if they have it. They'll probably just come back and say that they don't have it. If it doesn't work I'll try that grommet and clear plastic tubing workaround. Mine was completely disintegrated. The drivers side grommet/tubing is in good condition. Weird!
BTW: I'm in the process of running new windshield washer tubing in the front and back. I've completed the front and tested some new squirters I got and they shoot straight up over the windshield So anyway I've searched and found a link for some 2 way squirters that someone had good luck with:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6356690#6356690
Fingers crossed
So now at least the front tubing is all replaced and working apart from the crap squirters from gowesty. Now the back tubing will have to wait for this darn grommet sleeve. |
