dalland Samba Member
Joined: September 03, 2010 Posts: 70 Location: norway
Posted: Fri Jan 18, 2013 1:16 pm Post subject: Transmission for 400 hp track day/everyday bug. |
Hey guys, my everyday bug is a 1300S with a 2276 190-200hp engine.
I use it summer, winter, long camping trips and some time track day racing and uphill racing. But now the 200 hp doesn't cut it anymore and I'm planning my next engine.
My next engine will be a 2.6L type 4 with around 400 hp and 500 nm.
Not going into details about the engine now but the question for now is:
Until now I have been using the original transmission with out much problems, but I am now looking for a new transmission that can handle 400 hp and I want to keep almost the same gear ratio as the 1300S.
I will not go drag racing and/or running drag slicks tires.
But it has to handle semi slick street tires and go road racing.
I am also thinking about running a lsd of some sort..
On a side note, I am also wondering about what clutch system I should use since I am using my car all the time and already think the stage 1 is to heavy..
So what do you say guys?
Who should build my transmission?
What parts do I have to use?
What axles do I need?
Any good clutch systems?
And whats the cost? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80416 Location: Sneaking up behind you
Posted: Fri Jan 18, 2013 2:45 pm Post subject: |
Get a Mendola. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Jan 18, 2013 2:50 pm Post subject: |
| Glenn wrote: |
| Get a Mendola. |
Hoping for something under 3000$ ? |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Fri Jan 18, 2013 2:58 pm Post subject: |
for 400 horsepower, and wanting it to be reliable for street and track days....I would think Glenn is correct. You could try a strengthened bus trans,Not sure if you could keep your budget or not...and I dont have experience with how they hold up. _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15604 Location: Deep in the 405
Posted: Fri Jan 18, 2013 3:06 pm Post subject: |
If you have the money to build a TIV that has a serious 400 HP then you need to find the money to buy a Mendola transaxle that will handle it. No Type I transaxle will last long and you'll be $3500 or more into a Bus transaxle that can handle it. For another $1000 you can get a Mendeloa gearbox that will handle 600 HP. Spend the money once on a Mendeloa and be done with it. After you buy your 2nd or 3rd $3000 gearbox you will wish you did.
You should ask Kennedy about a P/P but I'll guess you need at least a stage II. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
NJ John Samba Member
Joined: September 21, 2007 Posts: 3028 Location: HdG, MD & NJ
Posted: Fri Jan 18, 2013 3:17 pm Post subject: |
A Mendola puts the starter on top, unless they came out with a sedan version. The firewall usually has to be modified. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
58Dub Samba Member
Posted: Fri Jan 18, 2013 3:30 pm Post subject: |
Im not sure how the roads are in Norway, but if you really plan on driving this through the winter with 400 HP, you will have your hands full. _________________ 58 Beetle (now just a pile of parts in the corner)
bug66 Samba Member
Joined: February 25, 2010 Posts: 110 Location: OSLO, NORWAY
Posted: Fri Jan 18, 2013 3:35 pm Post subject: Re: Transmission for 400 hp track day/everyday bug. |
Dalland..
Just copy some of the boxes we have in Norway.. Then throw some more money at it..
Send me a PM at the norwegian site and I'll give you some of the pointers I got
Erlend |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 938 Location: Vernon, CT
Posted: Fri Jan 18, 2013 3:45 pm Post subject: |
NJ John - Mendeola has a bellhousing with the starter in the normal position. We have one with the Subaru bellhousing. I think the quoted prices are a little low. 4 speed is @ $5000, 5 speed with LSD is @ $10,000 They can make a 4 or 5 speed with 3.88 ring & pinon. They also have .7 4th or 5th gear. Many chassis changes are also required to fit. Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA
Posted: Fri Jan 18, 2013 4:22 pm Post subject: |
Hmmm, think you are right bug66, maybe the Americans are not the guys to ask..
But there must be some Americans with experience of driving high power bugs on the street that can answer...  |
kadub Samba Member
Joined: November 04, 2004 Posts: 444 Location: Auburn, Wa
Posted: Fri Jan 18, 2013 5:19 pm Post subject: |
how many times can we spell Mendeola wrong in the same thread?
A built 091 should handle your needs, and keep it "VW", but it'll blow your 3K budget right out. More like double that for a "Mendi"  |
bug66 Samba Member
Posted: Fri Jan 18, 2013 5:25 pm Post subject: |
| kadub wrote: |
How much is a mendeola in the states?
Pluss another 1000$ in shipping and multiply with 1,25 (norwegian sales tax)
Still want to buy a mendeola? |
jhoefer Samba Member
Posted: Fri Jan 18, 2013 5:41 pm Post subject: |
A flipped R/P subaru box is also a possibility: http://www.subarugears.com
LSD's readily available for subaru boxes. Though you'll want an aftermarket gearset for that power level and it's unclear on their site if that is included in some of their full-build pricing options, you'd have to ask. Pricing probably somewhere between the two others.
bug66 Samba Member
Posted: Fri Jan 18, 2013 5:51 pm Post subject: |
| jhoefer wrote: |
LSD's readily available for subaru boxes. Though you'll want an aftermarket gearset for that power level and it's unclear on their site if that is included in some of their full-build pricing options, you'd have to ask. |
He has a swingaxle car. But hey, maybe he wants to convert to the other side.. |
nick wharton2 Samba Member
Joined: November 20, 2003 Posts: 41 Location: Modesto Ca
Posted: Fri Jan 18, 2013 6:04 pm Post subject: |
If you dont plan on doing 6,000 rpm launches with slicks, a built 091 bus box will be just fine. Do plan on spending over 3,000. My box alone was well over 5k, mainly because I went with weddle 4.13 r&p.
If you want to stay swing, just do a folts conversion. Might be hard living overseas to get a folts setup. _________________ cheap, fast, or reliable. Pick two
unless you're sponsored  |
| bug66 wrote: |
| jhoefer wrote: |
Doesn't the mendeola swing-axle conversion require a spool? And like nick just said the stronger late bus boxes are irs without extra parts. I'm kind of making some assumptions here... |
flyboat Samba Member
Posted: Fri Jan 18, 2013 6:25 pm Post subject: |
| jhoefer wrote: |
LSD's readily available for subaru boxes. Though you'll want an aftermarket gearset for that power level and it's unclear on their site if that is included in some of their full-build pricing options, you'd have to ask. Pricing probably somewhere between the two others. |
This requires a special ring and pinoin, and that little tidbit is quite expensive. Making the Mendeola look better all the time. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
Posted: Fri Jan 18, 2013 6:57 pm Post subject: |
| flyboat wrote: |
| jhoefer wrote: |
This requires a special ring and pinoin, and that little tidbit is quite expensive. Making the Mendeola look better all the time. |
I didn't say it was cheap. But it is 5-speed.
I don't know price-wise but an upgraded porsche 915 box might work. Don't know enough about the limits/required mods on that one. Stock is good to about 300hp. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Jan 18, 2013 10:14 pm Post subject: |
Nother Mendi vote, if you're looking for savings you're in the wrong hobby. If you have 400 on tap, you will quickly appreciate the diff in that box. Dana 60, I believe. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
| satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Chip  Samba Member
Posted: Sat Jan 19, 2013 12:47 am Post subject: |
| FWIW, I hope to be making right around 400whp with my T1 this coming spring. I'm running a built T1 box on the street. If you aren't launching it then you really shouldn't have many issues keeping it together, assuming it is well built. 3k will get you a stout T1 with a spool and decent swing axles. Add 8-900 for an LSD. You might look into going with the Porsche G50 gear box. That has been proven to handle lots more than 500whp in a VW. Again, you'll have to swap to IRS, but why wouldn't you at this point anyway, it is definitely superior to swing in your application. |
