New rail owner needs help with engine type
swflmike
swflmike is offline
PostPosted: Sat Feb 23, 2013 6:35 pm    Post subject: New rail owner needs help with engine type Reply with quote
I just picked up my first VW sand rail and need some help identifying the engine. I was told that it may have been from a 74 Notchback. Where can I find the info that I need? I want to start ordering parts to clean it up. Any help will be greatly appreciated. Thanks
Mike[/img]
txdunebuggy101
txdunebuggy101 is offline
PostPosted: Sat Feb 23, 2013 7:00 pm    Post subject: Reply with quote
Welcome to the Samba. The engine id # is stamped into block at the base of the alt/gen stand. It will begin with a letter then numerals. Look up that number to see what type you have.
I NEVER KNEW I KNOW SO LITTLE, TILL NOW....
Dale M.
Dale M. is offline
PostPosted: Sat Feb 23, 2013 8:04 pm    Post subject: Reply with quote
Vin/engine number listings cam be found here...
http://www.thesamba.com/vw/archives/info/bugchassisdating.php
Engine number should be under alternator stand if its Type 1 (uprights) some type 3 (pancakes) have engine number om case seam (where both sides join) near area of distributor...
Dale
swflmike
swflmike is offline
PostPosted: Sun Feb 24, 2013 3:54 pm    Post subject: Reply with quote
Thanks for the help. Looks like I have a 1973 Type 1.
AH217061
Dale
