New CB camshaft: 2228 any one tried it yet?
Page: Previous  1, 2
drumbum68
drumbum68 is offline
PostPosted: Fri Mar 29, 2013 6:46 am    Post subject: Reply with quote
Seems like it might be a good WBX cam.
gooser
gooser is offline
PostPosted: Fri Mar 29, 2013 7:52 am    Post subject: Reply with quote
what does wbx mean?
Alstrup
Alstrup is offline
PostPosted: Fri Mar 29, 2013 8:13 am    Post subject: Reply with quote
Waterboxer.
Freebug. Your issues are well known with the fk65 cam. But half of it is most likely carb/ignition related though.
Since youre taking the engine apart anyway, I could push you in the right direction. But I will need to know the rest of the set up. These smaller engines are rather sensetive to changes. And sometimes less is better than more
While cold start enrichment is nice to have when its really cold, you should be able to live with out it. (Assuming it is a summer vehichle)
If you want me to take a look at your set up, send me a mail or a PM with the info.
T
FreeBug
FreeBug is offline
PostPosted: Fri Apr 05, 2013 10:33 am    Post subject: Reply with quote
So far so good, I drove it home for the first time this evening.
It was nice! smooth from idle on up, not too much loss in power in the lower rpm, a little less on top, obviously, but not sure how much less yet.
going from 50 mph to 75 it's not as zippy as the FK, but mid-range and upper end feel better than the 2280.
at 75 head temps never went over (or reached, in fact) 300°F.
Still need to work out probs with the pdsit 34 linkage cb provided.. it's not as good as stock type III.
Still need to work on jetting, I'm running what they came with, 30 mains, 50 idles, I forget the airs.
I'm running my old distributor, prolly needs some tuning.
We'll see about mileage....
Thanks to everyone who helped... Well, Alstrup, really!!!
Alstrup
Alstrup is offline
PostPosted: Fri Apr 05, 2013 10:39 am    Post subject: Reply with quote
Wink The loss of some upper end power was expected. But I´m sure that once you get the bugs sorted out you will discover that thew engine actually pull better numbers down low (than the FK65) You just dont feel it, because the power comes on so low that it is more smooth.
T
FreeBug
FreeBug is offline
PostPosted: Fri Apr 05, 2013 12:25 pm    Post subject: Reply with quote
Laughing I felt it! It was generally nicer to drive, especially driving up! Sorry if I wasn't clear, it was really nice!
The torque peak seems higher, and thus the engine seems more eager, always wanting to climb. Sorta like a Golf engine. The FK-65,after torque peak, just seemed to want to make more noise, when you revved it. Not much going on otherwise.
It's just that at say 1/4 throttle, it rumbles a bit, and I'm pretty sure it's the carb sync at part opening. it all needs attention. The slop in the linkage axle is horrendous!
I haven't even been able to touch the idle fuel much, hard to access the screws... I have just 1 Type 3 adjusting screw with knob, neeed to source another one, or make a pair.
And, the mains are probably rich, I was thinking of trying a 122.5 first, and seeing where that leads me...
I think I have one spare set of airs, 145 I think. Really need to set up the wideband.
I'm just using the CB airfilters for now, and it isn't even that bad with the noise, none of the low-rpm dreaded overlap BUUUUUUUUUURP.
FreeBug
FreeBug is offline
PostPosted: Sat Apr 06, 2013 12:49 pm    Post subject: Reply with quote
Funny start to the day. It started up great, but the when I took off, the throttle stuck open. I drove my little route full throttle till the first area I could pull off. To negociate turns, I would kill it with the key.... on and off. Laughing
I figured it was the linkage, but in fact, it was a PITA carb, the shaft wich leaves the automatic choke assembly was seized. Took a while to sort out.
Next the linkage, lots of slop to take out of the pivot shaft. Almost comical. Almost.
Needed an extra return spring, the cable is presenting too much drag
Now, runs ok, smooth throttle operation, consistent flows through the carbs at different rpms, maybe not around 1300 rpm, though. Hard to get that out.
A little hesitation around 1200-1300, and doesn't seem to like the extra advance of the vaccuum cannister. Now it's at 10°idle, 30° total.
I have yet to change the mains, but found the airs are also 130.
I'll pull a plug tomorrow or monday, have a look. Also curious about doing a compression test. Used to be 11 bar.
FreeBug
FreeBug is offline
PostPosted: Tue Apr 09, 2013 12:31 pm    Post subject: Reply with quote
Now this is weird... I can screw in the idle fuel screws all the way in, no stall.
And I know the throttle plates are good, no vacuum from distributor outlet at idle, kicks in just off idle..
I guess I'll take them apart and have a look... I sure got my 300$ worth!! Laughing
Alstrup
Alstrup is offline
PostPosted: Tue Apr 09, 2013 1:07 pm    Post subject: Reply with quote
You may need to back the timing down a bit to get the throttle plate closer to the progression holes. That is most likely why you do not get any reaction on the idle mix screw.
If that is not the case, you may have a too high float height. I do not remember the desired height off hand. But check.
T
FreeBug
FreeBug is offline
PostPosted: Tue Apr 09, 2013 2:27 pm    Post subject: Reply with quote
So, you think it's running off the progression circuits? I really think the throttle plates are almost closed, running at 650 rpm, with 7.5° BTDC.
I checked for dribbling from the mains, or accelerator pump: none
I wonder if the idle screws aren't seating...
you're right, though, the fuel has to be coming from somewhere!
I'll check the fuel bowl levels, compare L and R floats, maybe lower them a bit.
Another thing: I remember the solex handbook mentions starting with an air metering jet 60 larger than the main jet, should't I be starting off with a 190 air? Seeing as I have to redo the jetting from scratch...
And another thing: I've been used to Type 3 and Bus and Transporter PDSITs, but almost all of those had full-load enrichment "power jets", and the CB 34s don't. That would allow for better part-throttle economy, I'm sure...
I wish they were more like type 3 PDSITs( for ease of tuning) but I'm glad they're not as complicated as the Type 4 ones!!
Having said that, I'm not sure what size air jet to use as a base starting point, in order to start trying main jets... any ideas? Thanks
FreeBug
FreeBug is offline
PostPosted: Tue Apr 09, 2013 2:31 pm    Post subject: Reply with quote
At what point do you drill a small hole in the throttle plate to reduce vacuum? Not that I think I'm there yet, will check all the above tomorrow. thanks.
FreeBug
FreeBug is offline
PostPosted: Wed Apr 10, 2013 12:49 pm    Post subject: Reply with quote
Well , I'm there... I took it all apart, you were right, the throttles were well into the progression slot (no holes, a vertical slot), I backed them off till I was out of the slot, probably ended up with the slot just visible from underneath, after synching at 600 rpm.
I guess I now need to drill a small hole in the throttle plate, if the idle is too low.
The float levels seemed ok, I left them as they were, have some fine-tuning reserve there.
I put some knobs on the idle fuel screws, now I can adjust them, and now the engine responds (at 600 rpm idle). Phew.
Driving was nice, but feels like I could step up the idle jets a half-size, say, to 52.5.
Now I really should set up the wide-band, maybe tomorrow.
FreeBug
FreeBug is offline
PostPosted: Wed Apr 10, 2013 12:53 pm    Post subject: Reply with quote
SixVolt
SixVolt is offline
PostPosted: Sat Feb 08, 2020 7:04 am    Post subject: Re: New CB camshaft: 2228 any one tried it yet? Reply with quote
Putting this here rather than starting a new thread as it relates to the 2228 cam.
Assume aluminum block engine 1600 with 85.5 pistons and SP stock heads, stock rocker shafts and valves, SP manifold and a 30/31 Brosol carb in an empty '59 panel bus with big nut tranny and reduction gear boxes.
Given that I have limited knowledge of engine builds and someone competent will be doing the assembly, how would the Eagle 2228 from CB PReformance https://www.cbperformance.com/product-p/2228.htm compare to the Engle W-90 cam from aircooled.net https://vwparts.aircooled.net/Engle-W90-Type-1-Camshaft-1-1-or-1-25-Rockers-p/e6090.htm
And yes, I know many will want to say build bigger, but I'm just trying to get an answer to this question for now so I can have as much information as possible.
Thank you in advance and appreciate these with knowledge of these cams weighing in.
Alstrup
Alstrup is offline
PostPosted: Sat Feb 08, 2020 11:29 am    Post subject: Re: New CB camshaft: 2228 any one tried it yet? Reply with quote
CB 2280, which you can also get from ACN. The 2228 is a fuel miser cam. You will not get much benefit from it in a bus. Then its better to take advantage of the slightly better power from the 2280. - Remember to up the CR a bit.
SixVolt
SixVolt is offline
PostPosted: Sat Feb 08, 2020 5:36 pm    Post subject: Re: New CB camshaft: 2228 any one tried it yet? Reply with quote
Apprecite the response. Thanks for the tip on upping the CR with that 2280. While I have rudimentary understanding of these ratios, I'm just trying to learn all I can so when I discuss all my options with my builder I'll have a better understnding of what he's talkiig aobut.
FWIW, he's recomending I get the 2280 and get a counterwieght crank from CB and move up to DP heads and a 34 PICT-3.
I'm sitting on what's basically a new stock crank, new 85.5 pistons and cylinders and a set of recently done SP heads. It just about how mush $ I can afford for that upgrade or just live with what I've got. Anything will be an improvement over the stock 40HP I'm running now.
Page: Previous  1, 2
Page 2 of 2
