xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2734 Location: East Nassau, NY
Posted: Mon Apr 08, 2013 12:45 pm Post subject: Can the 1.8t run backward? |
Rather than start a new thread, I changed the title of this thread, it was "difference between ABA and AHU/1Z oil pump?"
There seemed to be a lot of interest in this idea, so I'll keep it going. Last year Syncroghia started a thread on the idea of turning a TDi engine backward http://www.thesamba.com/vw/forum/viewtopic.php?t=515641&highlight=, I also had been wondering if it was possible. The TDi would have needed a custom camshaft to work. I am working on running an AEB backward, the advantage of this engine is the intake and exhaust cams are separate and I'm hoping I can re-time the timing chain and belt to open the valves at the right time running reverse of the norm.
I consider the AEB/ATW 1.8t and the ALH/1Z TDi engines a gift from VW. They allows us to mix a lot of old parts with much newer parts because they are based on the old engine blocks from the '70s, '80s, and '90s, yet they have much more modern cyl heads and engine managements. You can bolt a 1975 rabbit oil pan and transmission to either of these engines.
My goal is to run the engine backward using a B5 Passat 5speed transmission in a Vanagon. If this proves to be possible, maybe the A4/Passat Quattro/4motion transmission could be used in my Syncro?
My first question was "does anyone know the difference between these pump?"
Anyone know the difference?
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10131 Location: Where?
Posted: Mon Apr 08, 2013 2:34 pm Post subject: |
| I am fairly sure the shaft length is different but it's been a few years since I compared the two. |
Posted: Mon Apr 08, 2013 3:17 pm Post subject: |
I'm trying to decide what oil pump would work better in an AEB (1.8t) block. I am attempting to run the engine backward. I am using a diesel gear on intermediate shaft and the gear from the vacuum pump to correct the direction of the oil pump shaft.
Any thoughts? I am trying to avoid removing oil pans from engines I have just to get the oil pumps out to try.
Andrew- |
Posted: Mon Apr 08, 2013 6:38 pm Post subject: |
| I spent a minute thinking on it. Now my head hurts. |
Posted: Mon Apr 08, 2013 7:07 pm Post subject: |
That's nothing compared to the valve train and timing issues. This engine has separate intake and exhaust cams, this is the key that will allow it to run backward, or so I hope. I'm re-timing the belt and timing chain so it will open the valves at the correct time while spinning backward. The cam chain tensioner looks like it will be ok with reverse direction. I also will need to call #2 or #3 cylinder #1 and re-number the other cyls. accordingly and match the injector and coil wires to each. This is because of the location of the sensor wheel on the crank.
I'm hoping to correct the coolant and PS pump by running the belt on the other side of the pulley. I'm told the alternator will not care about direction of rotation.
The AEB oil pump is driven by a spline rather than a T slot like the AHU (bottom of the vac pump) or the AEB (bottom of the dist.)
My head really hurts. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Mon Apr 08, 2013 9:08 pm Post subject: |
Dayamn bud, I'm gonna need to spark one up before I revisit this topic again...throbbing migraine alert _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Tue Apr 09, 2013 2:28 pm Post subject: |
I can't seem to shake this subject from my head. What solutions are available to correct the Bendix drive on the starter? _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
Posted: Tue Apr 09, 2013 2:35 pm Post subject: |
I'm hoping to combine parts from a Jetta starter with a passat B5 starter. They were mounted on opposite sides of the flywheel.
I could be making a complete fool of myself with this project but I've done that before. |
Robw_z Samba Member
Posted: Tue Apr 09, 2013 2:55 pm Post subject: |
So why are you running the motor backwards?
-Rob |
Posted: Tue Apr 09, 2013 3:09 pm Post subject: |
Hoping to use a b5 (1998-2005) passat five speed transmission running backward as well in the back of a vanagon.
The transmission may have its own ideas on running backward.
Andrew- |
Posted: Tue Apr 09, 2013 3:20 pm Post subject: |
Very cool idea. _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Tue Apr 09, 2013 3:28 pm Post subject: |
But yet they still TURN the same way
| xoo00oox wrote: |
nothing reversed there, paint a direction arrow on the casing and hold up in each place.  _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Posted: Tue Apr 09, 2013 5:22 pm Post subject: |
The inline passat starter....
Volkswagen Passat Starter also fits these models:
2005::GL; 4Cyl 1.8L AWM;
2005::GL; 4Cyl 1.8L;
2005::GLS 4 Motion; 4Cyl 1.8L AWM;
2005::GLS 4 Motion; 4Cyl 1.8L;
2005::GLS; 4Cyl 1.8L AWM;
2005::GLS; 4Cyl 1.8L;
Part Name Volkswagen Passat Starter - New Click Image to Enlarge
Part #REPA320101
Brand Replacement
Fits 2001-2004 Volkswagen Passat
Features
Condition: New
Type: OE Replacement, 9-tooth Pinion, Clockwise Rotation, 1.4 KW Power Output, PMGR Design
Quantitysold: Sold Individually
The transverse Jetta/golf starter.......
Volkswagen Jetta Starter also fits these models:
2000|2001|2002|2003|2004|2005::GL; 4Cyl 2.0L;
2000|2001|2002|2003|2004|2005::GLS; 4Cyl 1.8L;
2000|2001|2002|2003|2004|2005::GLS; 4Cyl 2.0L;
2001|2003::Wolfsburg Edition; 4Cyl 1.8L;
2003|2004|2005::GL; 4Cyl 1.8L;
2004|2005::GLI; 4Cyl 1.8L;
Part Name Volkswagen Jetta Starter - OE Replacement, 10-tooth Pinion, Counterclockwise Rotation, 1.1 KW Power Output, PMGR Design |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10518 Location: Sunshine Coast B.C.
Posted: Tue Apr 09, 2013 5:53 pm Post subject: |
| xoo00oox wrote: |
Andrew- |
This is where I thought you were headed.
Having seen the involved great work D Clymer has done with the Suby transmission, I would imagine that the shift linkage for the Passat 5 speed is all doable. (?)
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Posted: Tue Apr 09, 2013 6:33 pm Post subject: |
| Hi 'Nut, I'm sure we can work out the shifter, I'm not sure yet the engine will work. There may be some hidden surprises in store. |
hans j Samba Member
Joined: May 06, 2006 Posts: 2745 Location: Salt Lake City UT
Posted: Tue Apr 09, 2013 9:25 pm Post subject: |
Aren't you going to have to cut apart the camshaft and reweld to make it open at the correct time? Seems like you would almost be better off running a Honda engine that rotates opposite from the factory.
Plus I don't know how well the ring gear is going to like the reverse load either. And would you have 5 reverse gears? Hurts my head trying to picture it.
I know it would be more expensive, but I would probably use a Porsche trans. It's already setup the correct way and sure to handle whatever power you throw at it.
Another option would be just to enlarge the rear seat firewall and run a mid engine setup with a stock Passat transmission and engine _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Wed Apr 10, 2013 2:32 am Post subject: |
The reason for making it spin backward is so I don't have five forward gears using the Passat trans that is now mounted in the back of a van.
It's not about cost, I have a Porsche 915 transmission in my collection of parts. It's more about the challenge of seeing if it can be done, if it works out it should make a nice driving van.
I don't know how well the transmission will like it but I'm willing to sacrafice one to find out. My theroy is it will be fine because they are made to handle loads in both directions. Every time you let off throttle or downshift it reverses the load that the engine puts on to drive the wheels.
All the headaches this is causing is just a side benefit.
Rallyedude Samba Member
Joined: December 06, 2009 Posts: 206 Location: Aylmer, QC
Posted: Wed Apr 10, 2013 4:32 am Post subject: |
Why don't you do the tranny flip ? Puts your shift linkage on the correct side. _________________ 85 2wd Doka ABA In progress
82 westy diesel under the knife , MTDi ,weddle gears |
Posted: Wed Apr 10, 2013 4:12 pm Post subject: |
| Rallyedude wrote: |
| Why don't you do the tranny flip ? Puts your shift linkage on the correct side. |
-mostly because I want to see if I can make this work.
Libby was correct, the shaft is longer on the diesel pump. I going to try using the AHU/1z TDi oil pump and cut the base of an old vacuum pump off to keep the gear running true. |
hans j Samba Member
Posted: Wed Apr 10, 2013 4:58 pm Post subject: |
Another issue I thought of was the pressure on the timing belt tensioner. Instead of being on the mostly slack side, the tensioner is now the roller with all the pressure on it from dragging the camshaft along. A mechanical tensioner will have to be used but I don't know how long the bearing would last with that much demand on it. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
