Solex 34 pci parts and info - someone in germany?
beetleseb
beetleseb is offline
PostPosted: Wed Apr 10, 2013 1:36 am    Post subject: Solex 34 pci parts and info - someone in germany? Reply with quote
Hi guys
Just started on the solex 34 pci carbs for my 1500sp engine and have a few questions.
Firstly I bought 3 carbs to make 2 good ones and 1 has a taller emulsion tube housing. Seems to be the same as my 28pci anyone know if there is a better style to run?
Also interested in parts suppliers as struggling to get hold of the emulsion tube holders in the UK. I would also need main jets, idle and both air correction. Maybe someone off here in Germany can help?
Also how easy are these to set up? They are going on a rebuilt engine which by luck has a used cam and followers so doesn't need that running in, but am I best starting with a good single to run it in?
Seb
Wanted - OG 50 split bug door panels, brown mats and old running boards
loor
loor is offline
PostPosted: Wed Apr 10, 2013 4:17 am    Post subject: Reply with quote
Hi,
fact is there were two different versions of the 34PCI
one version came off the nsu prinz the other one off the the BMW 700
The main difference of those carbs is the acceleration pum as you already found out.
I know people who say the NSU works better but fact is that both work fine. I wouldn't recommend to mix both styles in one setup!
BMW
NSU
For more information/spareparts -> http://www.ruddies-berlin.de/34pci.htm
As far as i know the NSU style carbs are used by riechert for his setups
http://www.riechertmotorentechnik.de/Vergaser/riechert-vergaser/solex/verg_2xsolex34pci-e-expl.htm
TDE (Theo Decker Essen) used the BMW style carbs.
I used to own one like this and it worked propperly.
With best regards,
Lorenz
beetleseb
PostPosted: Wed Apr 10, 2013 8:10 am    Post subject: Reply with quote
Hi
Thanks for that
Looks like I have two nsu and one bmw. Whats the difference in accel pumps? I need to rob some parts off the bmw one for the nsu fuel pump as it has been robbed for parts. (although was put back together and sold complete!!)
Looks like the 28pci emulsion tube holders are the same so that sorts out my first parts issue!! still need a few jets etc etc but know I can get those over here.
Will have some BMW bits left over I can swap for NSU bits if it helps others.
Seb
beetleseb
PostPosted: Wed Apr 10, 2013 2:13 pm    Post subject: Reply with quote
Had them apart and see the difference now
I'm missing 28-31 off the 2nd diagram if anyone can help or 95 and 96 on the first one would do. If anyone can help?
Knowing there where 2 different types I bought 3 off evilbay to make sure I had two the same, sadly although sold as complete one was empty inside Sad
Got a emulsion tube now so will just need a few jets and some luck!!!
Seb
loor
loor is offline
PostPosted: Thu Apr 11, 2013 1:48 am    Post subject: Reply with quote
i gotta take a look into my parts pile and let you know if i find the disassembled 34pci i have Wink
beetleseb
PostPosted: Thu Apr 11, 2013 5:03 am    Post subject: Reply with quote
That would be great, either style would do. Be nice to run a matched pair!!
Let me know what you find
Seb
62ItalianRagtop
62ItalianRagtop is offline
PostPosted: Fri Aug 14, 2015 8:16 am    Post subject: Reply with quote
Anyone knows which are the ones of the riechert kit ?
Ops NSU ones Shocked Very Happy
LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/
62ItalianRagtop
PostPosted: Sun Aug 16, 2015 11:57 pm    Post subject: Reply with quote
No info in english on these carbs ?
62ItalianRagtop
PostPosted: Sat May 28, 2016 9:44 am    Post subject: Re: Solex 34 pci parts and info - someone in germany? Reply with quote
Anyone can help me identifying
1) Idle adjusting screw
2) volume control screw
3) other useful screw for setting the carb
Thank you
vespist
vespist is offline
PostPosted: Wed Jan 25, 2017 3:59 am    Post subject: Re: Solex 34 pci parts and info - someone in germany? Reply with quote
hi
https://felix03.jimdo.com/
everything u want to know about 34pci and a lot of info and oldschool pictures.
62ItalianRagtop
PostPosted: Wed Jan 25, 2017 4:22 am    Post subject: Re: Solex 34 pci parts and info - someone in germany? Reply with quote
Thank you ... the problem is that I don't know german Sad
Kjell Roar
Kjell Roar is offline
PostPosted: Thu Jan 26, 2017 11:53 am    Post subject: Re: Solex 34 pci parts and info - someone in germany? Reply with quote
Thats what Google Translate is for! Wink
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
62ItalianRagtop
PostPosted: Thu Jan 26, 2017 12:16 pm    Post subject: Re: Solex 34 pci parts and info - someone in germany? Reply with quote
mm ... Google translation sometimes are horrible
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Thu Aug 07, 2025 2:58 pm    Post subject: Re: Solex 34 pci parts and info - someone in germany? Reply with quote
Does anyone know if the top of these 2 34 pci carbs are interchangeable..looks like i have a NSU version.. but i like the bmw top since it has the treaded fuel line .. at first I was like hmm I have plenty of the solex 28pci carbs let me try one of those and nope the solex 28pci top is shorter / dont match....so im on the look out for a bmw solex 34 pci top for my nsu carb but thats if they are interchangeable....anyone have an extra bmw solex 34 pci top ???
