DoctorP Samba Member
Joined: April 06, 2013 Posts: 28 Location: Clear Lake, TX
Posted: Thu Apr 11, 2013 10:06 am Post subject: Is this engine straightforward for me to work on? |
I have (or will have) a 1973 bus with a Type IV engine (pictured below). I know very little about engine repair. If I want to learn how to work on my own engine, should I replace this one with a Type I 1600? That seems to be the one pictured in the Muir book.
I have the Muir and Bentley manuals.
Thanks
DP
2013-04-109517-10-1195766 by fpearl, on Flickr |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu Apr 11, 2013 10:12 am Post subject: |
That is a good motor, check the compression and if it is useable roll the machine as is! You can make the bus a driver easy if that engine has some compression, a type 1 swap is not necessary imo, and it isn't correct for that bus unless you get the euro style tin to fit one in there. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends  |
Randy in Maine Samba Member
Posted: Thu Apr 11, 2013 10:17 am Post subject: |
Keep what you have for now. They all work about the same but a type 4 is considerably more robust internally and was needed to push a heavy bus down the road (which is why they came that way).
Do you have the green Bentley manual for the buses?
Someone replaced the factory dual carbs with a Weber progressive, so that is something that you will need to keep in mind. |
guitarman63mm Samba Member
Joined: September 03, 2008 Posts: 797 Location: Asheville, NC
Posted: Thu Apr 11, 2013 10:18 am Post subject: |
This is a point of contention for many people on here, but my two cents is that the type 1 is cheaper to learn on, and less expensive to repair if it fails. The type 4 heads have a habit of failing, according to many threads on here, and to get a good set of heads, you'll need to set aside $1k alone. In contrast, you can rebuild the entire low end of a type 1 for the same price.
That being said, in terms of power and such, the type 4 is superior and requires less maintenance, but when it does fail, you're looking at a lot of money. A lot of it. There are also quirks to a type 4 that the type 1 doesn't have, but the fact is that you have a type 4, so unless it's literally destroyed, you may as well work with it and keep it in there. _________________ Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine. |
Posted: Thu Apr 11, 2013 10:21 am Post subject: |
For the amount of effort to properly install a T1 engine in a late bus, you could maintain the T4 for years. |
MidWesty79 Samba Member
Joined: October 19, 2011 Posts: 503 Location: Milwaukee Wisconsin, US
Posted: Thu Apr 11, 2013 10:22 am Post subject: |
Agreed with everything above. The type 4 is great, and if that one checks out, keep on rolling. Oh! And if that bus runs for crap, don't blame the engine right away. That progressive perched atop that engine really likes it when you swear, scream, and throw things. It is horrible. I've been down that road and my friend who bought my '77 with a progressive off of me last year is still entertaining that carb with rants and hysterical cursing to this very day. (He will be going dual carb or returning the bus to FI eventually... hopefully...)
In short... if you're going to swap something out... start with that carb!!! _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42614 Location: at the beach
Posted: Thu Apr 11, 2013 10:45 am Post subject: |
Quote: |
I know very little about engine repair. |
my own opinion is my own only as I cannot speak for others here. A type 1 bus would be easier to learn on than a T4. Parts are more readily available also. However the best T1 bus is a 1971 and clean ones are expensive. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Apr 11, 2013 11:31 am Post subject: |
He was asking if he should swap the type 4 for a type 1 if and when he gets that bus. I say it looks good don't swap it. But I agree that a type 1 engine in a 71 bus would be better for a person to learn on as far as refreshing a motor. The 71 is the only year with a dual port type 1 engine, did earlier vw's have dual port type 1's? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
SGKent  Samba Member
Posted: Thu Apr 11, 2013 11:44 am Post subject: |
Red Fau Veh wrote: |
He was asking if he should swap the type 4 for a type 1 if and when he gets that bus. I say it looks good don't swap it. But I agree that a type 1 engine in a 71 bus would be better for a person to learn on as far as refreshing a motor. The 71 is the only year with a dual port type 1 engine, did earlier vw's have dual port type 1's? |
I wish someone paid me a penny for each time in life they told me they were going to own something. My dad died 2 1/2 years ago at age 88. I am still waiting for him to give me that 1962 VW bug of his that he promised would be mine when I turned 16, I am 62 now. Then he said the F84 would be mine instead. That never happened either. In fact I am still waiting to see Santa bring me all the things I put down in my letters to him as a child.
If he has a chance to get a T1 bus instead of a T4, it will be easier to learn on. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52824 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 11, 2013 11:56 am Post subject: |
SGKent wrote: |
If he has a chance to get a T1 bus instead of a T4, it will be easier to learn on. |
I'm not so sure, a type 4 with a single Weber isn't really too much different from a type 1, the Weber will add some challenges but basic diagnosis, maintenance and tune ups are really all the same. As long as it's got good compression and oil pressure there's no reason it can't be used to learn on, the oil sump plate is the only place that's really vulnerable to a noob, the rest is tougher than a type 1 and able to resist learning the hard way on a little better. Do buy a torque wrench and some manuals before your thumb even touches the decklid button  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
chazz79 Samba Member
Posted: Thu Apr 11, 2013 12:13 pm Post subject: |
I think the t4 is simpler and better laid out for a newb to understand. There are many hanging points to putting a t1 together. Push rod tubes and lifter replacement got 100x easier. head access and tin remival about equally crappy, but who doesn't love the spin on oil filter...yes t1's are only prefered because they're familiar and cheap
T4 is superior in every way to the t1 (other than parts cost)
T5 is superior to T4 for similar reasons.
it's called evolution.
I can only wonder what would've happened if vw stayed in the flat four bussiness. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Thu Apr 11, 2013 12:21 pm Post subject: |
People seem to over look the fact that not everybody can be a mechanic even a basic one none of us know this person skill level or ability to "get it" if you want to call it that. I get tiered of seeing on here oh just get a Bentley and you will become a great mechanic well not everybody can do it. Sorry Iam done now its been a LONG WINTER up here it snowed ANOTHER foot and half last weekend and now its 0 outside ok so DoctorP what is your skill level? do you have a set of tools? _________________ where its cold and snowy |
dasdachshund Samba Member
Joined: March 29, 2010 Posts: 728 Location: Vancouver, WA USA
Posted: Thu Apr 11, 2013 12:24 pm Post subject: |
......The 71 is the only year with a dual port type 1 engine, did earlier vw's have dual port type 1's? |
No. My 1970 has a single port.
Although I am going to replace it with a dual port this spring, then it will be, so maybe the question should be "did pre-71's come STOCK with a duel port". The answer is still no.
-dasdachshund |
Posted: Thu Apr 11, 2013 12:28 pm Post subject: |
busdaddy wrote: |
SGKent wrote: |
I'm not so sure, a type 4 with a single Weber isn't really too much different from a type 1, the Weber will add some challenges but basic diagnosis, maintenance and tune ups are really all the same. As long as it's got good compression and oil pressure there's no reason it can't be used to learn on, the oil sump plate is the only place that's really vulnerable to a noob, the rest is tougher than a type 1 and able to resist learning the hard way on a little better. Do buy a torque wrench and some manuals before your thumb even touches the decklid button  |
2X, I prefer Type 4's because they require so little in the way of maintenance. |
Posted: Thu Apr 11, 2013 12:54 pm Post subject: |
dasdachshund wrote: |
-dasdachshund |
Did any vw's have the dual port prior to the 71 bus? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Posted: Thu Apr 11, 2013 1:02 pm Post subject: |
-dasdachshund |
Did any vw's have the dual port prior to the 71 bus? |
Not from VW, but most get swapped in over the years. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Joeys1969 Samba Member
Posted: Thu Apr 11, 2013 1:04 pm Post subject: |
bigbore wrote: |
People seem to over look the fact that not everybody can be a mechanic even a basic one none of us know this person skill level or ability to "get it" if you want to call it that. I get tiered of seeing on here oh just get a Bentley and you will become a great mechanic well not everybody can do it. Sorry Iam done now its been a LONG WINTER up here it snowed ANOTHER foot and half last weekend and now its 0 outside ok so DoctorP what is your skill level? do you have a set of tools? |
I agree with bigbore completely! Not everybody is cut out to work on cars. I've been working on my bug since I was 15 with the help of my dad(and many of thesamba members) and now I am 20. I feel pretty confident in myself to work on my own cars now but still love it when my dads out there to help me along the way if I get stuck(and also use thesamba members and pick theirs brains too!). My dads the best teacher I could ever ask for.
So if you're trying to learn how to work on cars, I say get a buddy or someone you can trust to help you out and show you the way!
Joey _________________ Old VW's and Old Motorcycles. |
Posted: Thu Apr 11, 2013 6:02 pm Post subject: |
Joeys1969 wrote: |
bigbore wrote: |
Joey |
I agree with both of you but disagree too, there has been some really useless mechanics here that sucked it up and figured it out with a little guidance, the defining factor is they asked questions and followed instructions, you can't learn if you don't try. Without a doubt there's a few who will never get it and are dangerous with a wrench (some still try sadly), most of that group seem to fit the mold of the person who opens the box with the new toy and tosses the instructions aside with the rest of the packing. It all depends on how driven you are and if you can take pictures, ask questions and then follow the advice given.
I can't recall specific users or threads right now but I recall 6 or 8 members that couldn't find the dipstick when they got thier bus yet now when they say thier dwell or valves are set properly I completely believe them, skills come with experience and how you handle it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 11, 2013 6:25 pm Post subject: |
Thanks everyone for the advice! I'll leave the engine where it is. It sounds like the IV may be slightly harder to learn on but I am brave.
It sounds like I may want to deal with the carburetor first so long as the engine is otherwise in good shape. I heard that this engine had a fuel injector on it before that Progressive, but I'm not certain that's true. This is probably worthy of a whole different thread, but any suggestions on what to replace it with? If I get it back to original specification, what would that be? (And where can I find that kind of info in the future)
DP
P.S. Randy, I have the green Bently manual also; been reading it all evening! |
Posted: Thu Apr 11, 2013 6:41 pm Post subject: |
DoctorP wrote: |
DP
It did come with FI from the factory, and I've heard it's a pain to get the progressives to run on those motors. I have one on my 1600, but that's completely different.
