Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Wed Apr 17, 2013 5:40 am Post subject: Correct Size Tool To Remove Axle Bolts Or CV Bolt |
Thanks Wildthings.
Wildthings wrote: |
Clean each socket well with a pick or small screwdriver, hammer the tool into the socket, remove and clean again. Hammer in one more time and hope for the best. My choice is to buy a 4" or 6" long tool as it will interfere with the boot less than the shorter variety.
The Allens are 6mm as others have stated, while the triple square is an 8mm, IIRC. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5173 Location: California's Hot and Smoggy Central Valley
Posted: Wed Apr 17, 2013 7:28 am Post subject: |
Napa sells that tool, by itself so you don't have to buy a set. I cannot recall the part number of the tool, but it is under $7. Also be wary that you might have allen socket screws installed, as were mine on several bugs/busses over the years. Just have both tools on hand. |
guitarman63mm Samba Member
Joined: September 03, 2008 Posts: 797 Location: Asheville, NC
Posted: Wed Apr 17, 2013 7:39 am Post subject: |
Wasted: When I asked for a triple square / XZN bit at Napa, they looked at me all bug-eyed. Same for the other FLAPS I tried.
I made due with my old bolts and a standard hex for a while, just tack one of these onto your next order. I'm pretty sure this one was an EMPI-branded tool, so meh, but it gets the job done.
http://www.busdepot.com/5796 _________________ Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine. |
Randy in Maine Samba Member
Posted: Wed Apr 17, 2013 8:22 am Post subject: |
After cleaning the bolt heads, I just put the 8mm triple square socket on my cordless impact driver to remove them. Give them a little love pat with a hammer to make sure the socket is well seated in the bolt head. That makes quick work out of it.
I like to use new bolts when I go to re-install, then I just use the impact driver to get them all started. Once all are started, I use my torque wrench to do the final tightening to the torque specifications. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Wed Apr 17, 2013 9:31 pm Post subject: |
or use the standard size one with a socket extension. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13495 Location: West Coast, USA
Posted: Wed Apr 17, 2013 10:01 pm Post subject: |
Wasted youth/adulthood wrote: |
Some early bays came with 6mm 6-side (Allen) head bolts.
When ordering at NAPA, find the product on their website and give them the NAPA part number. They can order it in the morning and get it to you before closing time. Don't make the poor guys behind the counter actually look something up on their own!!
And there is absolutely nothing wrong with the EMPI one  _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Thu Apr 18, 2013 12:40 am Post subject: |
BUSBOSS wrote: |
or use the standard size one with a socket extension. |
The long thin tool clears the boot much better than a short squat one used with an extension.  |
Posted: Thu Apr 18, 2013 4:45 am Post subject: |
From last July when I learned about this problem:
My local Napa store had the correct tool, house brand. Tool 2304 Serrated Wrench, 8mm @$6.69 ea.
I picked up my bus and it had a mixture of both Allen sockets and those in question. |
Tcash Samba Member
