DoctorP Samba Member
Joined: April 06, 2013 Posts: 28 Location: Clear Lake, TX
Posted: Fri May 03, 2013 9:48 am Post subject: How to prepare new HT Leads |
I'm working on getting my 73 bus started. Currently focusing on the spark plugs. I have to replace 1 lead because the existing one is hard and crispy. The PO looks like they put in new spark plugs. In any case, the new Bosch leads have a retaining wire in each connector and their too small to accommodate a spark plug. Am I supposed to somehow custom fit it?
DP
_________________ Air-Cooled Novice
1973 Westphalia Campmobile
Proud owner since April 19, 2013
Engine Code GE009830 |
Skoolieman Samba Member
Joined: January 31, 2011 Posts: 573 Location: Chattanooga TN
Posted: Fri May 03, 2013 9:52 am Post subject: |
You need to pull the cap off the sparkplug. there is a small threaded rod inside that they go over
Edit: Here is a pic _________________ '69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4111 Location: Seattle, WA
The screw-on tip is supposed to be removed from the plug end. The connector clip you show
is mangled, must be fixed or replaced. _________________ '67 bug: seized by the authorities
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52983 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 03, 2013 9:53 am Post subject: |
Unscrew the terminal off the end of the spark plug. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17682 Location: San Diego, California
Posted: Fri May 03, 2013 10:27 am Post subject: |
Yep, unscrew it. If your wires are bad just replace the entire set. Shouldn't be more than about $30. I like to use Bosch wires and I always stay away from those colorful "bling" wires some people buy. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri May 03, 2013 11:17 am Post subject: |
Thanks for the replies everyone. I'll now get that done. I definitely don't trust the current wiring anymore, nor the PO who installed them. This will get me started.
DP _________________ Air-Cooled Novice
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1921 Location: Sacramento ca
Posted: Fri May 03, 2013 11:26 am Post subject: |
aeromech wrote: |
Yep, unscrew it. If your wires are bad just replace the entire set. Shouldn't be more than about $30. I like to use Bosch wires and I always stay away from those colorful "bling" wires some people buy. |
On busdepot they say these are better than the Bosch wires:
http://www.busdepot.com/021998031a
If they are better then why are the Bosch wires so much more expensive?
http://www.busdepot.com/09171 _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Fri May 03, 2013 12:42 pm Post subject: |
Since when does price have anything to do with quality? _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Fri May 03, 2013 12:46 pm Post subject: |
VDubTech wrote: |
Since when does price have anything to do with quality? |
I don't know that's why I'm asking;) _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Fri May 03, 2013 12:47 pm Post subject: |
Actually I found out that Bosch T4 wires are more like $60 a set. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42807 Location: at the beach
Posted: Fri May 03, 2013 12:48 pm Post subject: |
the skin on the Bosch ones tears easily. The other ones BD carries are better IMHO. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
