herkster Samba Member
Joined: February 14, 2013 Posts: 428 Location: Boca Raton, FL
Posted: Mon May 06, 2013 8:56 am Post subject: buggy painting ...shell only |
Anyone have an idea what a shell only...thats the cowl and the rest of the body only (full length car) should cost to paint? I know body work varies but just the shell and off the chassis after all fitting is completed. Just trying for a ball park.
thanks all! |
jspbtown Samba Member
Posted: Mon May 06, 2013 9:07 am Post subject: |
I guess it depnds on the rate, the amount of body work required, and your expectations.
I used "less expensive" paint (about $120 a sprayable gallon) and clear (about $60 gallon), and then probably 2 gallons of hi build primer ($150), then sandpaper, guidecoat, filler, resin & matt (probably $150) so I have close to $500 in my own supplies. That doesn't include my labor.
I have also seen paint go for $200 a quart so that will make a big difference.
I did just get a quote to have the front bumper cover on my SC430 repainted and that was $400.
I guess $1500-$2000 would not be unreasonable.
68Kghia Samba Member
Joined: April 01, 2013 Posts: 11 Location: Lancaster, ca
Posted: Tue May 07, 2013 4:02 pm Post subject: |
| Just got my body back from paint today. I did a lot of work on it my self (sanding repairs, ect) it cost about 900.00 and looks great. The used a special primer to start (fiberglass primer) a couple coats of paint and I went with extra coats of clear coat. They also did some more repair work ( i'm not that good at fiberglass repair) |
bornred62 Samba Member
Posted: Tue May 07, 2013 7:17 pm Post subject: |
Just pulled my manxter apart for a repaint 6 pieces all together. Paying 3000.
It's all about the quality of the job. Single stage, base coat clear coat, Hopefully you get what you pay for. |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3389 Location: Dirty Jersey
Posted: Wed May 08, 2013 12:42 pm Post subject: |
$500 at Maaco
_________________ 1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks! |
Posted: Wed May 08, 2013 1:41 pm Post subject: |
| I must say that paint at maaco looks good. I assume you did all the prep and body work? I plan on that and just need it shot well....All fitting will be done prior... |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4942 Location: Raleigh, North Carolina
Posted: Wed May 08, 2013 6:21 pm Post subject: |
| EMPIImp69 wrote: |
$500 at Maaco
Earl Scheib used to do it for less...
Looks good - was it a standard color from their color book?
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
EVfun  Samba Member
Posted: Wed May 08, 2013 7:06 pm Post subject: |
I've used Maaco before. I may do so my wife's '79, after removing the top and doing the bodywork. One thing, the quality varies from Maaco to Maaco, so check for the ratings of your local ones.
I've let them do some bodywork, but you should handle heavier work yourself, they are production shops not detail shops. I recommend you strip layers of old paint yourself and that you sand everywhere you want paint to stick. They will rely to much on feathering and etching agents. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
Posted: Thu May 09, 2013 7:19 am Post subject: |
| didget69 wrote: |
| EMPIImp69 wrote: |
$500 at Maaco
bryan |
Yep $99 any car! Thanks guys, its 1999 Chrysler Sparkling Silver metallic. Its my brother's buggy. He did all the prep. It is hit or miss with some Maacos. The one by us does decent work. They did the pods on my Imp too in two-tone green and this same silver for $150. _________________ 1963 Ragtop Bug
1966 Vert Bug
slalombuggy Samba Member
Posted: Thu May 09, 2013 7:27 am Post subject: |
Yes, check the work at the Maaco shop you might use. I saw a car come out of the local one that looked like they sprayed it with bedliner, then paint. Me and a buddy did a better job in his garage when we were young and had NEVER painted anything before. It was the worst job I had ever seen.
My paint was $160 a litre but the results are well worth the expense and Sickens will last FOREVER
brad |
Posted: Thu May 09, 2013 8:14 am Post subject: |
Never trust a place that steals shopping carts........ |
Rathbone Samba Member
Joined: February 25, 2006 Posts: 235 Location: Palm Coast, Florida
Posted: Thu May 09, 2013 8:47 am Post subject: |
Silver tends to show 'mottling' so that's a fantastic job. _________________ (o\_i_/o) what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul - Mr. Oblaski, Principal |
Posted: Thu May 09, 2013 9:47 am Post subject: |
Here's a little closer
Here's the side pods they did for me. Same silver on the insides.
1966 Vert Bug
jeromevw312 Samba Member
Joined: January 11, 2006 Posts: 236 Location: belmar, nj
Posted: Thu May 09, 2013 5:30 pm Post subject: |
The MAACO by me shoots great paint, but there bodywork and prep is horrible. We've ran a few cars through there that needed a quick coat of color, but after we sanded / stripped / disassembled. The paint they use is decent quality (better than the crap some private shops use), and the painter there shoots all day long, there's always something to say about experience.
If you do the prep yourself, you will be very satisfied with the results. |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Fri May 10, 2013 4:22 am Post subject: |
| Quote: |
jspbtown
Words to live by....
_________________ Gary
Being a cheap old fart is just a front for my actual lack of money.  |
ElijahTurtle Samba Member
Posted: Fri May 10, 2013 6:09 am Post subject: |
| jspbtown wrote: |
LMAO! |
Posted: Fri May 10, 2013 6:40 am Post subject: |
Same place did my other cars too. I did all prep on them.
1966 Vert Bug
firepainter Samba Member
Joined: December 20, 2004 Posts: 5 Location: Farmingdale, NY
Posted: Sat May 11, 2013 7:46 am Post subject: paint |
| As a professional painter you also need to factor in that some colors cost more, red is the most expensive color, adding mica, metalflake, pearls etc adds to the cost. Clear comes in all kinds of quality from cheap to very expensive, paint work is all based on the base the more time spent block sanding while no one will see it pays off in the final product. |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Mon May 13, 2013 12:02 pm Post subject: |
Paint work passed me by many years ago when fenders were $20 apiece from the VW dealer, and Sherwin-Williams automotive acrylic enamel and thinner was still under $50 a gallon. 2 shopping cart scrapes and a ding on the front fender of my Mustang GT a few weeks ago was $1400 at the Ford Dealer's body shop. But, I believe I got what I paid for.
I always had a few ounces of paint left over after 3 good coats and a buff shine on a Beetle. After 15 or so cars, I had mixed all the leftovers into about two quarts in a single can. Yellow, white, blue (all shades), red, orange, black, grey - 4 ~ 6 ounces of each,and I got the weirdest, shiniest, neatest looking , uhhh, errr, "color" '69 auto-stick on Staten Island. |
Posted: Mon May 13, 2013 4:56 pm Post subject: |
You could also consider using gel coat to cover the body. Vince down in OBX has done a bit of gel coat 'painting' on buggies, as have a few other people here. I'm planning to gel coat my buggy when the bodywork is completed.
