Canadian Standard "small" headliner
jeffff
jeffff is offline
PostPosted: Wed May 08, 2013 11:01 am    Post subject: Canadian Standard "small" headliner Reply with quote
I have my new headliner sewn up, bows in, ready to go for my 53. However, all the info I'm finding regarding headliners is for the "full" headliner. Lots of talk of gluing, cutting etc Very Happy
When it comes to these standard headliners, what it the procedure for installing? Looking at my 57 I can't tell.
Are the front/ back glued in while the the bows just lay inside??
slalombuggy
slalombuggy is offline
PostPosted: Wed May 08, 2013 11:40 am    Post subject: Reply with quote
IIRC the standard headliners had cardboard strips sewn along the perimeter on all 4 sides. these went on and hooked on the inside lips of the roof rails. The bows simply hooked in over top of the rails and supported the middle.
brad
jeffff
jeffff is offline
PostPosted: Wed May 08, 2013 1:49 pm    Post subject: Reply with quote
Thanks, pretty much what I was thinking. So there is no need to use glue whatsoever? It all just "hangs" there.
slalombuggy
PostPosted: Wed May 08, 2013 8:11 pm    Post subject: Reply with quote
No need for glue
brad
sunroof
sunroof is offline
PostPosted: Thu May 09, 2013 8:32 am    Post subject: Reply with quote
This is one of the principle reasons I like standards so much: super simple headliner.
Don
Joey
Joey is offline
PostPosted: Thu May 09, 2013 8:40 am    Post subject: Reply with quote
I agree - nice and clean looking.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
Tempie
Tempie is offline
PostPosted: Thu May 09, 2013 9:19 am    Post subject: Reply with quote
True, but I have the - not so simple - standard sunroof (3 fold) option Smile
When a deluxe is not enough.... you go standard Smile
Early 55 standard sunroof Smile
Visit the Standard Split and Oval Beetle group!!
VW Standard Split and Oval Beetle
sunroof
sunroof is offline
PostPosted: Fri May 10, 2013 6:38 am    Post subject: Reply with quote
My 59 Canadian custom sunroof
You can see the left front corner is coming down a bit. These corners are glued in with the rest of it tucked in with cardboard strips.
Don
jeffff
jeffff is offline
PostPosted: Fri May 10, 2013 10:53 am    Post subject: Reply with quote
Thanks guys, I'll let you know how I make out.
AirCooledClassics
AirCooledClassics is offline
PostPosted: Sun May 12, 2013 11:38 am    Post subject: Reply with quote
Ive had problems with U.S. supplied headliners in the past .Seeing as we buy a deluxe hdlnr. and throw away the rest It has pissed me off to find a loose fit and have to have a trimmer tailor it to fit right. Id try wolfsburg west. The other way Ive done them is to pick my fabric (40by 60") spray glue it to 1\2" foam then sew in lines at the bow spacings then using headliner glue or green upholstery glue spray the roof and foam and install tucking the excess away .It looks just like the oe headlining and costs perhaps $25.00. Not for the vintage car show but for customs and the bugget challenged.
2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552
