How to restore these rotten buffer supports on the RGBs
Wolfgang1
Wolfgang1 is offline
PostPosted: Thu Sep 22, 2011 2:55 pm    Post subject: How to restore these rotten buffer supports on the RGBs Reply with quote
Hi,
you all know them, rotten buffer supports on late RGBs... Crying or Very sad
What now? Leave them away? For me no alternative
As i know there`s no source i started to refresh them my way:
Here`s my step by step tutorial Idea
Where we start: Confused
First we have to remove the support from the axle tube. I thought the fastest way is to cut twice with a dremel like a V to avoid the original spot weldings:
Be careful not to hurt the tube! Wink
Now pull out the upper part of the support out of the rubber. It`s essential that the upper ring is salvable....
Now you have to find a tube with the correct diameter. Believe it or not, i used an old 36hp exhaust preheater tube, fits perfect Very Happy
Now i know again why i keep every vw scrap..... Wink
The upper "nipple" fits perfect over the tube:
Take your mig and here we go:
Now "clip it in" the rubber and drill a hole with the pre heater tube diameter in the support.
Put the tube with the rubber through the hole in the support you drilled earlier :
Fix it in the correct position with 2 spots, then remove the rubber and check angles etc. With only two spots you can correct it easily.
Now it`s time to weld:
Ready to reweld on the tube:
It`s essential to flaten the welding on the backside, otherwise it could collide with the cast iron of the RGB.
Now protect it from rusting again, i would recommend to add a little water drain hole.
Thanks for reading, i hope you enjoined it.
Wolfgang
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you.
GLHTurbo
GLHTurbo is offline
PostPosted: Thu Sep 22, 2011 3:51 pm    Post subject: Reply with quote
welding a lugnut in there works great too.
1957 Beetle
1966 Bus
kenshapiro2002
kenshapiro2002 is offline
PostPosted: Tue May 07, 2013 3:43 am    Post subject: Reply with quote
In another locked thread on this, DaWerks wrote:
dawerks wrote:
New bilstein shocks. They are awesome.
Also, you don't need the full size rubber bump stop either. You can get Delrin cut to size (I would go slightly over size and just slip it over the old holder, but half the height).
OK...how do the Bilsteins eliminate the need for the bump stops? Also, where can I find the delrin, and please explain how it's going to slip over the old holder and still maintain its height. Won't it be hollow (cylindrical) throughout its entire height? Sorry...a little confused.
Clara
Clara is offline
PostPosted: Tue May 07, 2013 7:21 am    Post subject: Reply with quote
I think the original poster of this thread showed a nice way to fix this problem. But if you don't feel up to dissembling and welding and reassembling, don't worry. The bus will be okay without the bump stops.
The bump stops were not used until part way through the 65 model year.
Meaning while they were added for a reason, you can drive with out them, and many buses never had them.
I am guessing that Dawerks meant if you have decent shocks, you don't actually use the bump stops much, unless you are on some really bumpy roads.
kenshapiro2002
PostPosted: Tue May 07, 2013 7:26 am    Post subject: Reply with quote
Thanks...great information there.
dawerks
dawerks is offline
PostPosted: Tue May 07, 2013 9:23 am    Post subject: Reply with quote
Plus you don't have to use the factory rubber mounts. The new Billstiens (sp) and some home made mounts are more than good enough.
Bump stops are only good when I ollie/jump curbs.
You can also re-index your rear spring plates so you have more clearance. The spring plates/torsions sag over time so maybe that's your issue?
"There is only one sin; disconnection from self."
baja1641
baja1641 is offline
PostPosted: Tue May 07, 2013 5:40 pm    Post subject: Reply with quote
Bilstein shocks have built in bump stops.
Mike
kenshapiro2002
PostPosted: Tue May 07, 2013 5:42 pm    Post subject: Reply with quote
Mike
Thanks for the info.
BarryL Premium Member
BarryL is offline
PostPosted: Fri May 10, 2013 7:10 pm    Post subject: Reply with quote
Where is this "bump stop" on the Biltsteins? I have a brand new set of the blue and yellow ones and they compress all the way just like KYB or any regular old one. Anyone have a picture?
baja1641
baja1641 is offline
PostPosted: Sat May 11, 2013 7:40 am    Post subject: Reply with quote
I don't know exactly, I guess they are inside the shocks. I was told this by a Bilstein dealer back in 1995. I bought a set for my baja bug and cut / removed all the bump stops on the car. I then proceeded to jump the car and generally beat on it. The shocks are still the same as they were when I bought them. That's money well spent!
Mike
sventinker
sventinker is offline
PostPosted: Sat May 11, 2013 8:12 am    Post subject: Reply with quote
Good job its nice to see people fix stuff with ingenuity.
April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote:
Perfection only comes with delusion.
http://www.oacdp.org/
kenshapiro2002
PostPosted: Tue Feb 10, 2015 2:42 pm    Post subject: Re: How to restore these rotten buffer supports on the RGBs Reply with quote
Wolfgang
OK...getting ready to do this (even though I realize it's not really necessary). What if you DON'T have the upper part of the support? Has anybody gotten past that problem?
Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Feb 10, 2015 4:01 pm    Post subject: Reply with quote
Then you find someone who has taken them off and does not need them. Hmm, where did we put those... Confused
Try a "WTB" ad in the classifieds.
In Stereo, Where Available!
Mile High Puma
Mile High Puma is offline
PostPosted: Tue Feb 10, 2015 4:02 pm    Post subject: Reply with quote
Bay window lug nut. There is a post on this way to do it.
1965 Velvet Green DC
1990 Westfalia Syncro
kenshapiro2002
PostPosted: Tue Feb 10, 2015 5:21 pm    Post subject: Reply with quote
Where's the thread? Looks like doing it that way doesn't even require removing the bracket from the axle.
Mile High Puma
PostPosted: Wed Feb 11, 2015 12:11 pm    Post subject: Reply with quote
here is the link,
http://www.thesamba.com/vw/forum/viewtopic.php?p=6952886&highlight=#6952886
kenshapiro2002
PostPosted: Wed Feb 11, 2015 1:44 pm    Post subject: Reply with quote
Thanks. So it was an Audi lug nut, not a Bay.Guess either might work? Two questions...looks like you ground down the flats on the lug...correct? Also, why did you remove the "flower"...the cup that supports the bump stop? Or was it already pretty much gone?
Mile High Puma
PostPosted: Wed Feb 11, 2015 4:25 pm    Post subject: Reply with quote
Took it off so I could clean it up better and get in there with my MIG easier to weld on the lug nut, was off a bay by the way, at the time I thought Audi but that was a lug bolt. If you notice I also drilled a drain hole in the center to give moisture a way out.
kenshapiro2002
PostPosted: Wed Feb 11, 2015 5:13 pm    Post subject: Reply with quote
Great help. Thanks.
Bruce Amacker
Bruce Amacker is offline
PostPosted: Thu Feb 12, 2015 8:38 am    Post subject: Reply with quote
Page 18 in the link below shows how I did it using a flange head bolt, there's many that will work. The reason you need to remove it from the axle is to sandblast it thoroughly and weld from the backside if needed. I wouldn't try to do it on the axle.
http://leakoil.net/forum/viewtopic.php?f=23&t=2888&start=170
Good Luck!
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
