Compilation on the "early" 1986 Vanagon
randywebb
randywebb is offline
PostPosted: Thu May 23, 2013 4:01 pm    Post subject: Compilation on the "early" 1986 Vanagon Reply with quote
I am the often confused owner of an early 1986 Westy and thought it would be useful to collect all the oddities about this partial model year in one place for others who suffer. (I also own a 1973.5 Pooschey 911, and it has all sorts of weird things on it too.)
my VIN = WV2ZB0257GH 025 811 - early ’86
It has all sorts of wiring that does not match the Bentley manual fuse listing; e.g. on page 97.67 is a notation re (very early) 1986 “up to VIN G 055 689”
I've heard that a 1986 Vanagon with a VIN in the 028xxx to 029xxx should be around August to September production, so mine was manufactured much earlier, but I'm not sure when.
I also discovered that the relays in the engine compartment for the fuel pump and engine ECU are different from everyone else's relays.
What else is different?
1986 2.1L Westy 2wd Auto Trans.
t3 kopf
t3 kopf is offline
PostPosted: Thu May 23, 2013 4:38 pm    Post subject: Reply with quote
does that model not say what year and month it was manufactured on the upper aft driver door frame? mine says 01/84 there.
'90 Carat w/ '95 phase 1 EJ22 OBD2 conversion
Sir Sam
Sir Sam is offline
PostPosted: Thu May 23, 2013 6:51 pm    Post subject: Reply with quote
It should.
'91 Carat Westy
87' Syncro + '87 Westy conversion coming soon
dhaavers
dhaavers is offline
PostPosted: Thu May 23, 2013 6:56 pm    Post subject: Reply with quote
Mine (1/86 build date) got the '85 AC system: different reciever/drier & expansion valve...
"The WonderVan"
randywebb
PostPosted: Fri May 24, 2013 1:26 pm    Post subject: Reply with quote
any other electrical oddities?
ZsZ
ZsZ is offline
PostPosted: Sat May 25, 2013 9:12 am    Post subject: Re: Compilation on the "early" 1986 Vanagon Reply with quote
Mine VIN is around GH125000 and was manufactured in juni of '86. As I know the model year stamp was changes in every august. The 25000th should be manufactured in september.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
randywebb
PostPosted: Sat May 25, 2013 3:48 pm    Post subject: Reply with quote
manf. date 10/85 on my door post sticker - ugh
ZsZ
ZsZ is offline
PostPosted: Sat May 25, 2013 10:10 pm    Post subject: Reply with quote
then it must be correct Wink
You never know what the previous owners changed/repaired in an old car. I think in the factory they changed the old/new parts when the stocked ones were out. But neihter the official VW repair books are correct in some times.
Zoltan
