Reserve tank on a Bug
truckersmike
Elder Sambanite
truckersmike is offline
PostPosted: Thu Aug 15, 2002 3:48 pm    Post subject: Reserve tank on a Bug Reply with quote
I have a '62 Bug and when I was showing a friend one time he said I was missing the lever for the reserve tank. What reserve tank I asked and he said that his old Bug had a lever to switch to the last chance reserve tank. Is he correct or crazy?
IndianaVWKid
IndianaVWKid is offline
PostPosted: Thu Aug 15, 2002 3:54 pm    Post subject: Reserve tank on a Bug Reply with quote
You're buddy was correct...His OLD'er bug had one, I'm sure of it...Anything '61 and earlier (without a gas guage) had a reserver lever, just above the tunnel in the chassis, and on the firewall. It was used when you were driving along, and ran out of gas, then you flipped it over, and it went to a 1 gallon reserve. The reserve is actually, just the last gallon of gas in the bottom of the tank, the lever just switched it between to hoses that sucked gas at different heights, top one was for normal use, and the bottom, for the reserve, it's a great idea, but sometimes it takes a while to get the gas flowing again. Gas guages are a little handier to use, so consider yourself lucky.
James
RareAir
RareAir is offline
PostPosted: Thu Aug 15, 2002 4:02 pm    Post subject: Reserve tank on a Bug Reply with quote
Reserve fuel levers were used till '61 on Beetles. Your '62 has a fuel gauge and NO reserve lever.
79SuperVert
79SuperVert is offline
PostPosted: Fri Aug 16, 2002 9:17 am    Post subject: Reserve tank on a Bug Reply with quote
Hard to believe the same engineers that came up with such a neat solution to running out of gas also came up with the world's worst way to power the windshield washer.
[email protected]
jcecil@charter.net is offline
PostPosted: Thu Aug 22, 2002 6:19 pm    Post subject: Reserve tank on a Bug Reply with quote
My '66 has a reserve lever on it.
