Ignition Switch Alternative
Page: 1, 2, 3  Next
jall2n52
jall2n52 is offline
PostPosted: Sat Jun 01, 2013 4:59 am    Post subject: Ignition Switch Alternative Reply with quote
Being sick of replacing Ignition Switches has anyone replaced with a toggle switch and a start button?
yardbug
yardbug is offline
PostPosted: Sat Jun 01, 2013 5:03 am    Post subject: Reply with quote
I'm sure someone has done it in the past. Sounds like you might have a different issue. Ignition switches don't go out with every oil change.
'69 Tintop T2 - '86 Syncro - '87 Westy - '02 337 GTI - '99 4Runner - '13 4Runner
jall2n52
jall2n52 is offline
PostPosted: Sat Jun 01, 2013 5:06 am    Post subject: yard bug Reply with quote
suggestions?
insyncro
Banned
insyncro is offline
PostPosted: Sat Jun 01, 2013 5:07 am    Post subject: Reply with quote
I have a Vanagon Syncro with all brand new wiring.
I used Painless wiring harnesses and the start function is wired to a momentary push button switch.
Just as I wire up race cars.
Working perfectly Exclamation
yardbug
yardbug is offline
PostPosted: Sat Jun 01, 2013 7:14 am    Post subject: Reply with quote
You might check the plug behind the switch. What year vanagon
BillM
BillM is offline
PostPosted: Sat Jun 01, 2013 7:43 am    Post subject: Reply with quote
Are you using a good quality replacement? There are cheap ones out
there that don't last.
Do you have any wiring changes like your radio hooked to
the key in buzzer circuit?
While they do wear out and fail it shouldn't need to be replaced
that often. Do you have a pound of keys hanging from you
key chain?
I also wonder if the portion your key goes in is somehow messed
up causing the electrical part to fail prematurely.
Bill M
87 Westy
?Waldo?
?Waldo? is offline
PostPosted: Sat Jun 01, 2013 7:49 am    Post subject: Reply with quote
A couple years ago I fixed the ignition on one where the problem seemed to be the ignition switch but turned out to be that wear was preventing the little pin that turns the switch from moving the correct amount.
Jedi
Jedi is offline
PostPosted: Sat Jun 01, 2013 8:08 am    Post subject: Reply with quote
I have had the same issue in the past on one of my syncro's. I replaced 3 ignition switches till I noticed that the little switch was over worn and needed to be replaced. Embarassed Good thing is the part is cheap enough you can carry a spare in your parts box Cool
1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro
pushkick
pushkick is offline
PostPosted: Sat Jun 01, 2013 3:43 pm    Post subject: what pin? Reply with quote
what pin are you talking about? got a pic
i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper
Syncroincity
Syncroincity is offline
PostPosted: Sat Jun 01, 2013 4:15 pm    Post subject: Reply with quote
Have lots of keys & doodads on your keyring? Heavy keyrings will destroy them pretty quick, especially the cheap new ones.
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
?Waldo?
?Waldo? is offline
PostPosted: Sat Jun 01, 2013 5:14 pm    Post subject: Reply with quote
I don't have a pic. If you pull an ignition switch and look at what actuates it you'll know exactly what I'm talking about.
FWIW, I believe that the 'too many keys' idea is a myth at least WRT VW ignition lock cylinders. The excessive keys may cause extra wear to the lock cylinder but considering the way it engages the ignition switch I do not believe that extra weight can transfer to damaging the switch itself. Kinda like the way folks think that the clutch master and slave failures are related, which they aren't.
pushkick
pushkick is offline
PostPosted: Sat Jun 01, 2013 5:31 pm    Post subject: ignition switch issues Reply with quote
i guess the best way is to unplug the connector and plug in replacement switch and try to turn with screw driver and see how it works. if it works fine i guess its the pin that is causing the problem. will try this and see what i find out. thanks for the help.
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Sat Jun 01, 2013 7:14 pm    Post subject: Reply with quote
here's a pic (made by David B.) of the electrical parts of the switch. Just to add to the general conversation.
alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
r39o
Samba Polizei
r39o is offline
PostPosted: Sat Jun 01, 2013 8:02 pm    Post subject: Reply with quote
The pounds of keys thing is no myth.
That same lock was used on jillions of VWs.
So many girls came so many times with ignition issues and, almost, with out fail they had tonnage hanging on their key rings.
There may even be a TSB about it.
While you may not have caused it the PO may have.
Excessive play in the pin caused by the plastic bushing being worn will screw up the contacts in the switch.
randywebb
randywebb is offline
PostPosted: Sat Jun 01, 2013 10:06 pm    Post subject: Re: ignition switch issues Reply with quote
how about if you unplug the connector and then short some wires together in the connector itself - which ones do you connect?
1986 2.1L Westy 2wd Auto Trans.
thatvwbusguy
thatvwbusguy is offline
PostPosted: Sat Jun 01, 2013 11:18 pm    Post subject: Reply with quote
Here is the procedure to crank the starter via the ignition switch socket. I copied this from a post a while back and can't remember who originally wrote it at this point. Anyway, here goes.......
Ignition Switch Bypass - Jumper Wire Starting Method:
Remove the plastic cover from the steering column and pull the black socket off the bottom of the ignition switch.
Insert a jumper wire between the large red wire and the solid black wire (a bent paper clip works well, but will get hot, so be careful). You should hear the fuel pump run at this point.
If you hear the fuel pump, leave the first jumper (large red to black) in place and insert another jumper wire between the large red wire and the red/white wire. This is your starter wire.
The engine should turn over at this point. If the engine starts, remove the big red to red/white jumper wire immediately. If you don't remove this jumper, the starter will continue to run just like holding the key in the start position.
This is essentially how to hotwire a Vanagon, but since the ignition steering lock is still in place, you can easily defeat any would be Vanagon heist by leaving the wheels turned into the curb when you park...
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
geo_tonz
geo_tonz is offline
PostPosted: Sun Jun 02, 2013 12:41 am    Post subject: Reply with quote
...and bookmarked! Thanks Jay, I was looking for that proceedure a while back!
To the op: you might consider a hard start and headlight relay kit like Jay makes to greatly reduce the amps that regularly flow throught that piddly plastic switch. Plus gain brighter lights, better cranking power and potentially preserve your headlight switch. Maybe it'd help with your ignition switch consumtion as well in reducing the load to that part.
Red Vanagon "Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sun Jun 02, 2013 11:43 am    Post subject: Reply with quote
Yep...same story over in MB-land
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
?Waldo?
?Waldo? is offline
PostPosted: Sun Jun 02, 2013 12:13 pm    Post subject: Reply with quote
I believe it with the design of the older Merz ignition lock assemblies. I don't believe it with the design of the VW ones. The wear on the VW lock cylinder itself would have to be beyond the point that would keep the key from turning prior to actually causing the electrical part to fail.
Jahbah
Jahbah is offline
PostPosted: Sun Jun 02, 2013 12:14 pm    Post subject: Reply with quote
Great timing.
At Syncro de mayo we had a very long group discussion about van fires. The guys doing the talking cover this switch as a fire hazard. There are two big wires running up and down your steering column, one feeds the switch the other goes to the starter. Apparently when you hear stories of vans randomly catching fire, starting themselves and driving into houses THIS is the source. The switch shorts out and starts a fire and also melts these wires together. I bought a momentary starter switch with plans to install it. I want to use the key as a "switch" to turn the van on and energize the start button. The goal is to prevent the van from having this possible short problem. Any how to pointers from people that have already done this?
Jay "thatvwbusguy" makes some really user friendly kits. I have the headlight relay and the hard start relay. Super helpful.
'87 Westfalia Weekender + '86 Syncro Tintop +'02 Impreza 2.5RS
= '86.5 SuperWestySyncroSubyWeekendermobileagon =
Bueno.
Jahbah~D
Page: 1, 2, 3  Next
