82 westy oil cooler bracket bolt
pkovac
pkovac is offline
PostPosted: Thu Jun 13, 2013 12:18 pm    Post subject: 82 westy oil cooler bracket bolt Reply with quote
I have an 1982 air cooled westy and the bolt that screws into the fan shroud and holds the black oil cooler bracket is missing. Does anyone know what size this bolt is? I imagine not having the bracket screwed in puts unwanted stress on the oil cooler seals maybe causing the leak I have. Thank you
MarkWard
MarkWard is offline
PostPosted: Thu Jun 13, 2013 12:56 pm    Post subject: Reply with quote
I see a bolt that goes into a tab on the bracket that is 8mm x 1.25 pitch 22 mm long. The bracket appears to be two peice and clamps the cooler. Those two bolts are smaller. 6mm x 1.0 pitch 15 mm long. Both should be available at your local hardware store. As a reference, 25.4 mm = 1 inch.
pkovac
pkovac is offline
PostPosted: Thu Jun 13, 2013 8:55 pm    Post subject: Reply with quote
Thank you very much for the detailed information! Exactly what I needed.
