1957 Euro Semaphore/Ragtop Vintage Speed Project
Page: Previous  1, 2, 3 ... 9, 10, 11, 12  Next
Rwoodshvac
Rwoodshvac is offline
PostPosted: Fri Jan 11, 2013 6:57 pm    Post subject: Reply with quote
I have the tube powdercated and mocked it up and then I saw a picture of another build with black wires and loved the look without tube. Plus it is somewhat different and old school So at this point i am leaving tube off and hope others like the look as i do. Sometimes i do things and then later say to myself what were u thinking!!!!!!!!
57 Ragtop Semaphore Sedan
48 Aluminum Case drilled tapped, Full Flow Filter
Porsche 356 B Crankshaft 74mm
Porsche 356 B Rods
Shasta Cylinders with JE Pistons 80mm
WW Okrasa Heads worked by Ron Chuck
Speedwell Ratio Rockers 1.25
Dual Valve Springs w/Lash Caps
Blackline Racing Lifter Inserts, Manton Push Rods
34 Pbic Carbs rebushed by Mr Okrasa
Custom Okrasa Intakes enlarged to 34mm
Gene Burg Sump
Fram bypass Filter with Okrasa Oil Cooler
Flavio
Flavio is offline
PostPosted: Sat Jan 12, 2013 3:40 pm    Post subject: Reply with quote
Yes, I know what you mean and that you are keeping the tube for later...just in case... Cool
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Tue Jan 15, 2013 12:10 am    Post subject: Reply with quote
Love the AN lock washers
"no more hacking my sig line"
vwmike333
vwmike333 is offline
PostPosted: Sun Jan 27, 2013 5:47 pm    Post subject: Reply with quote
Rwoodshvac wrote:
The other is the supply that leaves the Fram filter it is straight and long you have to decide where to cut the excess and how to make your bends for looks and alignment/fitment . It is a 6mm pure copper line very easy to cut and bend.
I can provide you with a matching short length of blue-striped steel-braided German hose to solder onto your cut-off copper Okrasa-style oil cooler return line. This is how I'm supplying the kits that I will be selling soon. It looks nice, correct and is easier to deal with than a long length of copper tubing to the distributor bolt oil return fitting. I can also supply the fittings, swivel nuts and cut-rings for the case and Fram filter fittings.
tigerdyr
tigerdyr is offline
PostPosted: Mon Feb 11, 2013 3:29 am    Post subject: Reply with quote
Any progress ?
vwmike333
PostPosted: Mon Feb 11, 2013 5:12 pm    Post subject: Reply with quote
tigerdyr wrote:
Any progress ?
Yes, I have the single orange stripe hose now, and can make custom lengths (and single blue stripe for additional $). I have some sets of fittings available now, also. I have also found some matching compression unions to eliminate the need for soldering the oil cooler to the hose feed and return sections. These can be hidden behind the fan housing if you don't want them to be visible. These unions will also allow you to disassemble the pieces easily if needed.
tigerdyr
tigerdyr is offline
PostPosted: Tue Apr 16, 2013 7:21 pm    Post subject: Reply with quote
What happened to this engine build? Is it done ?
txoval
txoval is offline
PostPosted: Thu Apr 18, 2013 3:40 pm    Post subject: Reply with quote
Anyone know where you can buy the dual springs the Original Poster is running?
Thanks
AirCooledClassics
AirCooledClassics is offline
PostPosted: Sat Apr 20, 2013 8:07 am    Post subject: Reply with quote
I was rereading your story about the valve train issues.I to had to go to dual jaguar springs but I just reused my ww retainers.Who's retainers did you use and have I made a big mistake?I miss good stories like this. Thanks
2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Sat Apr 20, 2013 9:32 am    Post subject: Reply with quote
The retainers were custom made by the head porter.
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
txoval
txoval is offline
PostPosted: Sat Apr 20, 2013 11:55 am    Post subject: Reply with quote
What type/year Jaguar dual springs? Can you provide a link to where they can be purchased?
AirCooledClassics
PostPosted: Sat Apr 20, 2013 8:42 pm    Post subject: Reply with quote
I got mine from World Pac in Vancouver. Jaguar 6 cylinder engines used the same vale springs from the 50's to the mid 80's.I checked with the dealership 1st .The springs were well priced about $35.00 Can. I did have to clearance the seat base on the okrasa head about 1 mm.
My You-tube video
Rwoodshvac
PostPosted: Tue Jun 11, 2013 1:10 pm    Post subject: Reply with quote
Sorry guys have been away for a while. Things are going well with the engine build. Here is a Pic of the full flow conections going behind the Pulley
Porsche 356 B Rods
Gene Burg Sump
Rwoodshvac
PostPosted: Thu Jun 13, 2013 12:12 pm    Post subject: Reply with quote
In the next few days i will post some Pics of the engine detail. Like i mentioned i ended up restoring a Fram Bypass Filter. Here is a picture of the finished product. This was powder coated. This filter is 100% functional even though i am using a full flow filter system.
Porsche 356 B Rods
Gene Burg Sump
djway3474
djway3474 is offline
PostPosted: Thu Jun 13, 2013 12:40 pm    Post subject: Reply with quote
I was thinking the same thing with the full flow and the bypass. Use the bypass filter for xtra oil instead of a sump.
I am also considering a doghouse out back.
Thanks for all your picts which inspire me to keep pushing forward.
Rwoodshvac
PostPosted: Thu Jun 13, 2013 12:52 pm    Post subject: Reply with quote
Do you put the Cart before the Horse or the Horse before the Cart. Its always a debate of what to work on. Over the weekend i installed the 1/4 windows and the Oval window. I had done the oval window before but removed it to fix a piece of headliner. I rolled the 57 outside to pick up some heat from the Sun to help with the install. This is the first time its been out of the garage since i started the restoration. I was able to do all three windows without help. I used a window suction cup from Harbor Freight it had amazing suction. Some weed eater string/cord and spray silicone to get it done. Putting the gaskets on the windows and then the chrome into the gaskets was a bear for me. I was thinking that since i had done the windshield before it would make things easy but it is hard no matter what.
The 57 is getting close. The Carpet and some odd and ends is all that remains. The Wife just had to have a picture
Porsche 356 B Rods
Gene Burg Sump
djway3474
PostPosted: Thu Jun 13, 2013 6:58 pm    Post subject: Reply with quote
Beauty VW Cool
AirCooledClassics
PostPosted: Thu Jun 13, 2013 8:35 pm    Post subject: Reply with quote
Fantastic work,I'm Impressed. The car really likes getting out of the garage. May the home stretch be short.
My You-tube video
Rwoodshvac
PostPosted: Fri Jun 14, 2013 7:21 am    Post subject: Reply with quote
Thanks for the positive comments!
Here is a picture of the full flow Denzel oil filter cover from underneath. The Denzel cover puts oil lines in psoition to allow you to route the lines above the sheet metal sleds and below the header.
Porsche 356 B Rods
Gene Burg Sump
Rwoodshvac
PostPosted: Tue Jun 18, 2013 1:28 pm    Post subject: Reply with quote
I spent some time trying to decide exactly where I wanted to locate the Full Flow filter. I wanted a location where I could hide the oil lines as much as possible. I wanted it in a place that was easy to access and easy to change the filter + I wanted it in a vertical position so when you do service it you will have less spillage.
I found a spot above and to the right side of the driver side heater box. I made a bracket out of aluminum to hold the JayCee filter adapter. It is bolted thru the bottom of the luggage shelf and holds the filter adapter very solid.
The heater hose fits right in with no modifications
Porsche 356 B Rods
Gene Burg Sump
Page 10 of 12
