brandondonat Samba Member
Posted: Mon Jul 08, 2013 10:08 am Post subject: Engine Dies in Reverse |
When I put the gear selector in reverse on my 67 Bus, and let off of the clutch, it dies immediately... Before I can even give any gas. Has anyone ever seen this problem?
As a result I cannot reverse my Bus at all unless I manually push it. Once I back it up I am able to drive the bus forward in an other gear. I can put the gear selector in all positions (even reverse) and there is no grinding and it goes into gear easily. I don't know if it would help to say but once it is in gear it stays in gear until I change it to another gear - there is no slipping.
Any idea why this might be happening?
Thank you. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19893 Location: Land of Whine and Phonies
Posted: Mon Jul 08, 2013 10:19 am Post subject: |
Hmm. Do you have reverse lights? _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
widehatch Samba Member
Joined: May 27, 2007 Posts: 777 Location: Memphis, TN aka The Armpit of the South
Posted: Mon Jul 08, 2013 10:30 am Post subject: |
have you tried putting the bus in reverse before you start the engine? _________________ Missouri Micros |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15444 Location: Casa de Oro, California
Posted: Mon Jul 08, 2013 10:53 am Post subject: |
| Sounds like flacky wire such that in reverse the engine cocks and makes a disconnect. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7124 Location: Lawrenceville, Ga
Posted: Mon Jul 08, 2013 11:17 am Post subject: |
| widehatch wrote: |
| have you tried putting the bus in reverse before you start the engine? |
or even better, start the bus with the car in reverse and the clutch released.
that way you see if it even turns over? (make sure you have enough room to hop around the parking-lot) _________________ regards
Uli
Culito 11010101
Joined: December 07, 2006 Posts: 5882 Location: Columbia Missourah
Posted: Mon Jul 08, 2013 3:11 pm Post subject: |
Sounds like the reverse light wire hooked to the wrong side of the coil. _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
| johnnypan wrote: |
| ...dont pay no attention to Culito,he's a cornhole.. |
BarryL  Samba Member
Posted: Mon Jul 08, 2013 4:44 pm Post subject: Re: Engine Dies in Reverse |
| brandondonat wrote: |
| and let off of the clutch, |
Sounds like it runs while in the reverse position but dies after he lets off the clutch. That's why I think torque or maybe the clutch pedal+reverse position shift rod hitting funky wire? |
olliehank47 Samba Member
Posted: Mon Jul 08, 2013 4:50 pm Post subject: |
| Culito wrote: |
| Sounds like the reverse light wire hooked to the wrong side of the coil. |
If you have reverse lights, I'd agree with this ^^^. The reverse light wire should be on the same terminal as the hot from the ignition, terminal 15. If you have it on the other terminal and you engage the reverse switch, you are effectively routing all primary current to the coil, through the reverse lights so you have no build up within the coil to discharge through the secondary circuit to the plugs. Result, no spark. |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Mon Jul 08, 2013 5:59 pm Post subject: |
| olliehank47 wrote: |
| Culito wrote: |
x3 |
Posted: Mon Jul 08, 2013 6:37 pm Post subject: |
very interesting, maybe i should get me a split with backup lights, just to see this? _________________ regards
Uli
Posted: Tue Jul 09, 2013 6:31 am Post subject: |
Thanks for all of the help everyone. I went out to check the functionality of the reverse lights and wiring in the engine bay. Turned out that both reverse lights worked and the wiring was hooked up to the coil as you have stated. Scratching my head I gave everything a good once over and noticed that the notched carb gearing (not exactly sure of its name but has a scallop shape to it) that controls the throttle was completely turned around. Once I flipped it right side up... In its normal position... I fired up the engine and it went into reverse without any problems. I did it a number of times so this seemed to be the culprit.
Playing with this scallop piece on the carb it is very wobbly and not very effective. Probably best if I put a new carb... Or a good used carb... On it instead. Anyone have an extra carb kicking about? Don't need anything fancy... Just the standard bus carb.
Thanks again for your help. |
Posted: Tue Jul 09, 2013 6:54 am Post subject: |
Glad your problem is solved, but can you explain, or do you have any idea, of how the carb part would suddenly cause your engine to die only when the trans was put into reverse? Was the part you describe the idle cam on the throttle shaft--the part with a stepped edge that the throttle lever rests on when the choke is engaged? Did it in anyway contact the wires to the coil when it was installed incorrectly?
At this point, I just don't see any connection between your initial problem and the solution you found as I can't see any relationship between the carb part and the reverse light system. Any ideas would be helpful.
Maybe it's just me, but if it was my bus, I wouldn't considered a problem really solved until I can find the cause, and, given what you've described, I can't see how the carb part is the cause. |
Posted: Tue Jul 09, 2013 7:12 am Post subject: |
My guess is that he's only using reverse after the car has cooled enough to reset the electric choke so that when he steps on the pedal the spring in the choke is strong enough to flip the plate around. The carb is missing it's pin to prevent that or its a carb without the pin. _________________ Your Vanagon sucks, Stop waving at me.
BarryL  Samba Member
Posted: Tue Jul 09, 2013 8:04 am Post subject: |
Wobbly is ok.
Like Campy said, there is a little roll pin that has fallen off. Look close and you'll see how it fits into the slot. Usually when that cam flips over the engine races and won't idle down.
Still can't understand how only reverse was affected.
| BarryL wrote: |
| Like Campy said |
Sorry, I meant Crofty.
Posted: Tue Jul 09, 2013 7:06 pm Post subject: |
Ollie: I wish I could explain more about how this lever had caused this problem only in reverse. The part I am referring to I'd the one you have mentioned... The idle cam on the throttle shaft with the stepped edge. It was completely flipped over.
I too think there is more to this problem but I only found this solution after I flipped the idle cam back over. There is no tension on the idle cam and a missing spring, as has been suggested, may be the problem here. In addition, the cam is so wobbly that it often doesn't even make contact with the throttle lever. The throttle cable is also set with the incorrect spring so the tension is likely a bit off.
Barry: You are exactly right about the engine racing when the cam is flipped over. As my wife explained it... It sounded like I was taking off in a small aircraft. |
BarryL  Samba Member
Posted: Wed Jul 10, 2013 7:56 am Post subject: |
| Once you discover the missing pin you'll discover how gravity holds that cam. There is no spring for the cam itself. The choke interfaces with the cam to make it add more steps when it's cold so that may be the spring you feel but it's actually on the other side and part of the choke mechanism where the wire hooks on. |
Culito 11010101
Posted: Wed Jul 10, 2013 9:15 am Post subject: |
Obviously this missing pin is also part of the reverse gear linkage.  _________________ © CJ Industries, Inc.
'62 bug
| johnnypan wrote: |
