1970 Buggy Samba Member
Joined: February 24, 2011 Posts: 15 Location: Kennesaw GA
Posted: Sun Jul 07, 2013 8:23 pm Post subject: Vapor Digital Gauge ? |
Has anyone used a electrical Vapor Digital Gauge in a rail buggy or VW before? I saw a forum about this gauge set up but after looking in to it I don't think that the speedometer part will work for a actual car wheel.
My speedometer cable broke therefore I'm looking for other options.
http://www.trailtech.net/vapor.html _________________ If it can't burn rubber, I won't drive it. |
Aruba1 Samba Member
Joined: November 13, 2012 Posts: 95 Location: Birmingham, AL
Posted: Tue Jul 16, 2013 6:07 pm Post subject: |
| Been tinkering with this idea too, hopefully someone can chime in. |
cgummerson11 Samba Member
Joined: May 31, 2013 Posts: 101 Location: Huntington Beach
Posted: Wed Jul 17, 2013 1:33 pm Post subject: |
| The trail tech kit comes with a magnetic bolt that goes on the brake rotor for a MC or ATV, then the pick up is drilled to be mounted on the brake caliper. If you could get the magnet to stay on your wheel, and find a place to mount the receiver/pickup, it would work. Vapors wheel sizes are customizable, but may not be 100% accurate. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3716 Location: West Coast (Michigan's)
Posted: Thu Jul 18, 2013 5:45 am Post subject: |
This would be nice. I don't see a universal option unfortunately. _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Thu Jul 18, 2013 9:28 am Post subject: |
could you just mount the magnet to the CV joint and fab up a bracket off the trans for the pick-up? _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Posted: Thu Jul 18, 2013 12:12 pm Post subject: |
I was picturing the front brake drum but I like your CV idea as long as it handles that diameter ok and is adjustable which most are but this one doesn't mention it which makes me wonder why they don't offer anything non-vehical specific. _________________ Brian H.
Posted: Thu Jul 18, 2013 5:11 pm Post subject: |
| Not sure how just the magnet that comes in the kit would stay on the front wheel, then you could mount the pick up on the front shock. I dont know how close the pick up has to be to get the signal. I will take my bike pick up and move it a foot away and see if I can get a signal. |
Aruba1 Samba Member
Posted: Thu Jul 18, 2013 8:59 pm Post subject: |
I got an email from the guy that sells them on here, he said I'll need a speedometer extension otherwise the kit is pretty much complete. I'll call him tomorrow to get more information but if the kit is complete as he claiming I'll buy one. For a buggy it sure would be nice to replace all them gauges with a small digital cluster.
I found some other information through google (forgot the site) but it sees that the rpm is a bit erratic. Has anyone experenced that? |
Posted: Fri Jul 19, 2013 3:54 am Post subject: |
| Aruba1 wrote: |
i'll second that. space is definitely golden _________________ Brian H.
Aruba1 Samba Member
Posted: Thu Jul 25, 2013 12:16 pm Post subject: |
| I spoke with the seller this morning, the gauges no longer comes with tachometer as they were erratic to start with. The package comes with a kit to attach the speedo to the rear disk brake, if you have drum you need to get an extension or something ($11 extra). For aircooled temp reading it comes with an adapter that attaches to one of the spark plugs. I think I will skip on the kits due to not having a tachometer and I will probably wait till they improve the RPM reading. |
Posted: Fri Jul 26, 2013 5:03 am Post subject: |
I was kinda the opposite. I think nothing displays rpms as well as a needle guage. As for the speed sensor, I'm sure there's a lot of ways you can skin that cat. I'd just be worried about that Tach bit. If they can't get that to work right what else is iffy? _________________ Brian H.
doom buggy Samba Member
Posted: Fri Jul 26, 2013 3:52 pm Post subject: |
| Aruba1 wrote: |
?i just spoke with trailtech the last couple weeks and the tech was explaining how to hook everything up including the tach.he actually quoted me on a vapor stealth and said the tach is a digital numarical readout and a bar graph.i think they still come with the tach from what the company told me. _________________ 2 seater street legal rail buggy
stock 1600dp,stinger exhaust,31x15.50 terra tires,irs conversion with type 4 cv joints,boxed arms,rear disc brakes,dual circuit master cyl,thing trans,empi trigger shifter,empi breather,electronic svda dist.,outerwears pre-filter,swingaxle torsion bars,aluminum pulley,work in progress |
Aruba1 Samba Member
Posted: Fri Jul 26, 2013 6:52 pm Post subject: |
| Very well could be the case but the seller that posts them for sale on Samba does not provide them with a tach. |
Aruba1 Samba Member
Posted: Fri Jul 26, 2013 6:55 pm Post subject: |
| doom buggy wrote: |
| ?i just spoke with trailtech the last couple weeks and the tech was explaining how to hook everything up including the tach.he actually quoted me on a vapor stealth and said the tach is a digital numarical readout and a bar graph.i think they still come with the tach from what the company told me. |
There are several threads on the internet about the rpm issue. I'll will consider buying two kits if they can fix the problem. Some of the threads mentions messing with some of the programming settings to get it to work but accuracy is still questionable. https://www.google.com/#output=search&sclient=...mp;bih=653 |
Posted: Fri Jul 26, 2013 7:54 pm Post subject: |
do you have a link to the vendor that sells them without the tach function?just wondering,ive never seen a trail tech vapor without the tach,ive seen a bunch in person when i used to ride dual sports and online.maybe he was talking about one of the other computers trail tech makes,such as the striker,vector,or endurance computers? _________________ 2 seater street legal rail buggy
Aruba1 Samba Member
Aruba1 Samba Member
Posted: Mon Jul 29, 2013 8:36 pm Post subject: |
| Who is the brave one and go first? |
Posted: Tue Jul 30, 2013 5:52 pm Post subject: |
| Aruba1 wrote: |
| I spoke with the seller this morning, the gauges no longer comes with tachometer as they were erratic to start with. . |
i would steer clear of that vendor,i emailed him about a vapor stealth model and he doesent know what im talking about(he should know what that is being a vendor).i just got off the phone with trailtech directly,i asked them if they made the stealth model still and they said,of course,its the black version.then i said i was told that they dont have a tach anymore,the guy on the other end of the phone laughed a little and said "no they have always had a tach function,thats one of the key fetures of the vapor".you can order directly from trail tech,then at least you know your getting the right thing. _________________ 2 seater street legal rail buggy
Aruba1 Samba Member
Posted: Tue Jul 30, 2013 7:19 pm Post subject: |
| If you end up getting the setup please let us know how it works. I am ready to try it one of the sand rails but there are no reviews of VW owners to warrant the purchase. |
Jhawk Samba Member
Joined: September 06, 2019 Posts: 18 Location: Alabama
Posted: Sun Dec 29, 2019 11:33 am Post subject: |
| Aruba1 wrote: |
Well this is a old thread but I am wondering if anyone has installed a Trail Tech unit since he last post and if so how has it performed. Thanks |
