Which Big Brake kit. Van Cafe or Smallcar.
Page: Previous  1, 2, 3, 4, 5, 6, 7
insyncro
Banned
insyncro is offline
PostPosted: Sun Aug 04, 2013 4:39 pm    Post subject: Reply with quote
Nope, no pictures at this time.
Take flat stock, drill a hole where it will attach to the caliper, heat the center of the stock in a vice, twist it to the desired angle, drill a hole for the union of the lines and assemble.
Some of the SA calipers I have seen in the past lack a tapped hole for this.
If so, I make up my own braided lines with a swivel banjo fitting at the caliper and only support the braided line at the stock location on the upright, knuckle, spindle....what every you want to call it.
If you want to use the lines you have....get a male/male adapter to attach the line directly to the caliper.
If you do this, drop the suspension to full droop while on stands to make sure the line is long enough.
Attach it to the knuckle at full droop.
Crankey
Crankey is offline
PostPosted: Sun Aug 04, 2013 7:59 pm    Post subject: Reply with quote
ProvoCyclist wrote:
r39o wrote:
Franklinstower wrote:
Girling G60. Not corrado
The caliper in question is a twin pot and easy to spot. It says G60 on it too.
There is another caliper out there that bolts up just like the G60, except it is a single pot.
You can find pictures in the HUGE Audi Big Brake thread in the FAQ.
Thats kinda what I thought, ive got a pair, and the are massive and weighty. Plus i take it they dont bolt up to the VC kit?
I want to know this too...will the G60s work with the other components of the VC kit ? with mods like a spacer or milling off material somewhere ?
insyncro
Banned
insyncro is offline
PostPosted: Sun Aug 04, 2013 8:26 pm    Post subject: Reply with quote
For use on a 2wd van, the SA hubs allow for many different calipers and rotors to be used.
Backspacing the caliper with an adapter will be unique to each of the different calipers.
Crankey
Crankey is offline
PostPosted: Sun Aug 04, 2013 8:59 pm    Post subject: Reply with quote
excellent ! thank you Dylan.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sun Aug 04, 2013 10:45 pm    Post subject: Reply with quote
MsTaboo wrote:
Hi everyone who has VC Big Brakes.
What did you do about the hose support where the flex line meets the hard line at the caliper?
I used a big stainless steel hose clamp - it seems plenty strong to me. But then, I don't have a welder so...
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Mon Aug 05, 2013 1:49 pm    Post subject: Reply with quote
Here is what I ended up doing.
The white washers are made from UHMW plastic, and serve as spacers for the tension spring only.
Everything clears nicely and the homemade mount seems to hold the rigid line pretty firm.
Currently:
MsTaboo is offline
PostPosted: Fri Aug 09, 2013 2:56 pm    Post subject: Reply with quote
Well, my VC big brake kit is in and while I'm still doing the bed in on the new pads everything is working well and there is already a notable difference in performance.
However, now I have a new problem. The clutch master cylinder, which was working fine, has crapped out. Mad
I guess it couldn't handle new fluid. As part of the brake upgrade I took the time to completely flush all the old fluid out of both systems. The fluid was pretty dark in the clutch system, not so bad in the brakes. I had flushed the brake system back a year or so ago when I rebuilt the rears.
Time for a new clutch master cylinder. I just did this job on the Joker! Confused
Sure wish we could get rebuild kits for these! The one I took out of the Joker looks brand new. Even the bore is clean, just old seals.
Currently:
syncrodoka
syncrodoka is offline
PostPosted: Fri Aug 09, 2013 2:59 pm    Post subject: Reply with quote
rock auto lists them. I have no experience with the kits myself though.
insyncro
Banned
insyncro is offline
PostPosted: Fri Aug 09, 2013 3:03 pm    Post subject: Reply with quote
Are you sure it is bled out completely?
Gravity draining can cause air to get into the cylinder and not be easily bled out.
I didn't have any luck rebuilding them years ago.
With new one, I open them up and inspect them completely.
I have had to remove them and use a syringe to get fluid into them on the bench, than install, than power bleeder in the past.
Removing the slave from the bracket and getting it as low as possible has also helped before.
Hope this helps.
MsTaboo is offline
PostPosted: Fri Aug 09, 2013 3:50 pm    Post subject: Reply with quote
When I did the brake change I kept air out of the system as best I could. Always kept the res full, never dropped below fill line.
Bled brakes, got rears completely clear of air, had a little more trouble with fronts. Bled clutch, got a fair amount of air out, was surprised there was any at all!
Clutch would alternate between feeling ok to completely flat. Finally got all air out (over a quart of fluid through lines!) but clutch pedal never came back.
As far as I know this is the original master cylinder.
When I did the clutch master on the Joker I was able to achieve full action after only a pint. And that was with full drain down of front lines.
I'll run more fluid through if you think it might help.
Currently:
insyncro
Banned
insyncro is offline
PostPosted: Fri Aug 09, 2013 3:56 pm    Post subject: Reply with quote
Adding fluid directly to the cylinder, reconnecting and bleeding is what I feel will help if it has any life left in it.
The air pocket is in the master.
I use like a 1/4 - 1/2 of a pint to bleed when I prefilled all cylinders.
MsTaboo is offline
PostPosted: Fri Aug 09, 2013 7:10 pm    Post subject: Reply with quote
Yep, I bench filled the new cylinder on the Joker.
If I'm gonna remove the clutch master anyway (to fill), I might as well get a fresh one.
Currently:
Page 7 of 7
