Any aftermarket cruse control suggestions - AAZ in Vanagon?
Gizmoman
Gizmoman is offline
PostPosted: Sat Aug 17, 2013 9:41 pm    Post subject: Any aftermarket cruse control suggestions - AAZ in Vanagon? Reply with quote
I figure while I'm running wires, adding gauges and whatnot, a cruse control would be nice for long trips (hope to have many).
Does anyone have some recommendations?
The engine is a 1.9 AAZ, the vehicle is an 82 Vanagon/Westy.
Custom bracketry is no problem, just want something that works well.
Thanks,
Jim
82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale).
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Aug 17, 2013 9:55 pm    Post subject: Reply with quote
How about retrofitting the late model stock cruise system, which works exceptionally well.
Casey--
'01 Weekender --> full camper
y u rune klassik?
Gizmoman
Gizmoman is offline
PostPosted: Sun Aug 18, 2013 5:48 am    Post subject: Reply with quote
That would be perfect but I've been to the local wrecking yards and everything has been picked clean.
"Back in the day" it was easy to find them - now, not so much.
brad131a4
brad131a4 is offline
PostPosted: Sun Aug 18, 2013 4:29 pm    Post subject: Reply with quote
For the price the Go Westy one works well. Even with the stock switch controlling it. It takes a bit of adjusting to get it dialed in correctly. The one I helped install worked fairly well but could have used some more adjusting to get it perfect.
The vanagon I'm picking up doesn't have cruise in it and this will be one of the first things I'll be installing.
Gizmoman
Gizmoman is offline
PostPosted: Sun Aug 18, 2013 6:19 pm    Post subject: Reply with quote
Yea, I checked out the GW one - looks simple.
Any idea of how it would do on a diesel?
insyncro
Banned
insyncro is offline
PostPosted: Sun Aug 18, 2013 7:22 pm    Post subject: Reply with quote
Absolutely love the action of the factory system.
I have been buying up all of the good used and still new parts that I can find.
Sorry for that.
I have not had issue including them with conversions I do.
Zeitgeist 13
PostPosted: Sun Aug 18, 2013 7:43 pm    Post subject: Reply with quote
The T3 cruise system has so far been the most trouble-free factory system I've ever encountered. Vacuum switches on the brake/clutch pedals are the only point sources of issue I've experienced.
Casey--
y u rune klassik?
Witless Joe
Witless Joe is offline
PostPosted: Sun Aug 18, 2013 8:25 pm    Post subject: Reply with quote
Your AAZ won't be able to give your cruise control any info about engine speed, as it lacks a coil, of course. It's highly unlikely that either GoWesty or OEM cruise units would be able to interpret the "W" signal from your alternator, which is probably what drives your diesel tach (if equipped).
I'm not sure about the GoWesty or OEM cruise on a diesel, but the old Audiovox cruise control would work ok with no tach sensor, as long as it had road speed input from either the speedometer or from magnets mounted on an axle. Unfortunately that thing went out of production for a while, and when it came back into production it was priced double IIRC.
Have a look here, with all the correct dip switch settings, should you pursue this route.
http://www.vwdiesel.net/forum/index.php?topic=101.0
Zeitgeist 13
PostPosted: Sun Aug 18, 2013 9:20 pm    Post subject: Reply with quote
OEM VW cruise speed signal is derived from a hall sender in the speedo from the cable. So, it's agnostic as to which engine is providing the motivation.
Casey--
y u rune klassik?
Witless Joe
PostPosted: Sun Aug 18, 2013 10:36 pm    Post subject: Reply with quote
Ah, ok, two ways to skin the same cat.
So if I understand your point, the Audiovox has only one pedal switch input and also a tach input (ie. brake pedal switch only). But the VW has no tach input and two pedal switches instead (ie. both brake and clutch pedal switches).
Audiovox just taps the brake light circuit, so it is 1-size-fits-all without needing to design a mechanical switch for the inumerable clutch pedals on which the unit might be mounted. Hence the RPM-sensitive kill mechanism in its software.
Zeitgeist 13
PostPosted: Mon Aug 19, 2013 5:15 am    Post subject: Reply with quote
There's no tach signal, and the brake/clutch switches are just used to break the circuit and turn off the cruise. It's an ingeniously simple system. I will be using it on my mTDI build.
My old '80 van had an Audiovox cruise system, but it didn't work. I think they're prone to losing their speed signals, which are derived from magnets glued to one of the CV joints. Maybe the newer versions are set up differently now, but I wasn't too impressed the kludgey design.
Casey--
y u rune klassik?
Ahwahnee
Ahwahnee is offline
PostPosted: Mon Aug 19, 2013 6:22 am    Post subject: Reply with quote
I've had the Audiovox system on our Westy for 25 years w/o a problem -- prior to that I had the same unit on several other vehicles and moved it when I got rid of the cars (one was even a VW diesel pickup).
Possibly a bit fussy to set up as I use the magnets and the pickup needs to be adjusted very close but once done it is reliable and the sensitivity can be dialed in quite precisely.
Gizmoman
Gizmoman is offline
PostPosted: Mon Aug 19, 2013 6:38 am    Post subject: Reply with quote
The GW cruise page says "This GoWesty Cruise Control Kit is designed specifically for the Vanagon application. It will fit any year* Vanagon with any engine." http://www.gowesty.com/ec_view_details.php?id=23793&category_id=&category_parent_id=
The asterisk denotes the speedometer cable must be the snap-in style (not screw-in) which mine is the former.
Based on that, it will work. Now I just need the courage to crack open my wallet. I would want the kit with the wireless steering wheel switch and my transmission is manual so the total is 400 + shipping! Thats a lot of dough just to let my right foot relax every now and then.
Gizmoman
Gizmoman is offline
PostPosted: Mon Aug 19, 2013 6:43 am    Post subject: Reply with quote
Another 100 bucks and I could upgrade the brakes - which would benefit my right foot as well. WTH*** - I'll just plop down 900 and let it atrophy Very Happy
HoustonPhotog
HoustonPhotog is offline
PostPosted: Wed Aug 21, 2013 6:27 am    Post subject: Reply with quote
that totally sounds like me... ha!
Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now
Gizmoman
Gizmoman is offline
PostPosted: Wed Aug 21, 2013 6:53 am    Post subject: Reply with quote
Yeah, finding that "sweet spot" between an endless money vacuum and a barely running van is tough. Given the two (assuming 900 bucks is over the limits), I suppose the better brakes are "smarter" than the cruise.
I've had a few wheel clenching scenarios getting off the freeway with the small stock discs.
HoustonPhotog
PostPosted: Wed Aug 21, 2013 6:56 am    Post subject: Reply with quote
im new to the vanagon world with my 87 westy... it was the GW big brake kit Gen 1 and i still get a bit timid while braking. Cant imagine how it was with stock sized rotors/brakes.
Abel Longoria
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Aug 21, 2013 3:14 pm    Post subject: Reply with quote
Gizmoman wrote:
...Based on that, it will work. Now I just need the courage to crack open my wallet. I would want the kit with the wireless steering wheel switch and my transmission is manual so the total is 400 + shipping! Thats a lot of dough just to let my right foot relax every now and then.
There are cheaper alternatives. It's pretty old school (like our vans) but the Audiovox CCS100 was the ubiquitous aftermarket kit 20-30 years ago and is pretty effective.
With a quick look I see:
Reproductions of the original for $175.
Old uninstalled units in an auction or Buy-it-Now for a bit more.
Also this on Amazon (would need to 2 other kits shown to complete, total cost $268).
All of these will take some craftiness to fit up but can be made to work well. I have used a CCS100 for many decades and 100s of 1000s of miles.
BTW, I have never had a clutch cut-out switch -- just don't punch the clutch before the brake (I never do).
vanis13
vanis13 is offline
PostPosted: Fri Aug 23, 2013 12:46 pm    Post subject: Reply with quote
I forget the name now, but I put in one of those that is electronic rather than vacuum. worked very well even when climbing hills. maybe 8" years ago now and still ticking.
