dgsaz Samba Member
Joined: November 04, 2008 Posts: 584 Location: Phoenix / San Diego
Posted: Wed Sep 04, 2013 1:01 pm Post subject: Wiring Diagram for Oil Cooler Fan |
Hello all,
Would you have a look at my wiring diagram for an oil cooler fan with a relay and an in-line thermostat switch.
As my oil temp has yet to go much over 180 degrees I'm not sure if it's wired right or it has never gotten hot enough to turn on the fan.
I'm thinking about hitting the t-stat switch with a hot air gun and see if that will cause the fan and indicator light to come on. Then on the other hand it could be wired wrong.
Here's how I have it wired now. Right or wrong, or just not hot enough yet?
Thanks for looking.
dgsaz
[img][/img] |
risk Samba Member
Joined: June 24, 2004 Posts: 724 Location: Stumpbroke, Arkansas
Posted: Wed Sep 04, 2013 1:16 pm Post subject: |
85 should be ground and 86 is trigger from your thermostat... try it that way and I bet the fan comes on. |
dgsaz Samba Member
risk Samba Member
Posted: Wed Sep 04, 2013 3:16 pm Post subject: |
There are a few different ways to wire it up depending on how you are using it.. for your application I think you need to swap 85 & 86. |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Wed Sep 04, 2013 3:40 pm Post subject: |
Something else to consider is adding a diode to the warning light from your alternator. If the cooling fan is running when you go to shut off the engine, the fan blades spinning to a stop can cause feedback into the charging system. MSD recomends using a 1 amp, 100 volt diode. I think the Radio Shack part # is 276-1103. Just wire it inline of the wire between the alternator, and charging light. The diode should have a stripe on it, and the stripe end goes to the alternator. Another thing to consider is running the thermostat after the cooler, so the cooler has an opportunity to cool some without the fan. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4488 Location: viroqua wi.
Posted: Wed Sep 04, 2013 3:42 pm Post subject: |
85 is the ground. Edit, Or 86, should not matter |
dgsaz Samba Member
Posted: Wed Sep 04, 2013 4:10 pm Post subject: |
risk wrote: |
Thanks for the answers. I'll try it and report back.
dgsaz |
risk Samba Member
Posted: Wed Sep 04, 2013 4:58 pm Post subject: |
bsairhead wrote: |
Yeah I guess it could go either way.. I have always wired them the same way, 85 to ground and never had an issue. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20807 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Sep 04, 2013 9:42 pm Post subject: |
Should work either way unless there is a diode across internal coil of relay..... The relay is just a electromagnetic switch and in most cases does not care what polarity is on 85/86...
But the correct way is...
85 ground
86 12 volts
87 Output
30 + 12 volts input...
http://www.motor.com/magazine/pdfs/042003_07.pdf
To test total circuit, just take a jumper wire and go across the two terminals of t-stat switch, fan should start up.......
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Wed Sep 04, 2013 9:48 pm Post subject: |
[email protected] wrote: |
Fan is not going to generate enough electricity to keep engine running.... Besides, if wired correctly relay coil 12 volts should be sourced by ignition switch and once key is off, relay contacts "open" and there is no electrical path from fan motor to possibly cause run on condition...
Diode that MSD supplies and shows in its diagrams do nothing to stop run on unless there is a malfunction in MSD box and it puts out a voltage on IGN (control off-on) wire.... Which under normal circumstances it should not do....
jason Samba Member
Posted: Wed Sep 04, 2013 10:10 pm Post subject: |
I do mine backwards, do all the triggering with the ground legs and the fan will stay on after the car is turned off. |
jason Samba Member
Posted: Wed Sep 04, 2013 10:16 pm Post subject: |
My fan usually only comes on after shutting the motor off. I think it has something to do with the motor not blowing the air to cool. It's usually only a minute or two. |
Posted: Thu Sep 05, 2013 4:33 am Post subject: |
IF fan is running after car shuts off, its because of two things, temperature rise at t-stat because oil is no longer flowing and not cooling t-stat and control circuit for fan (relay) is not wired for control by key switch, its wired direct to battery which is not necessary or desirable...
Posted: Thu Sep 05, 2013 4:45 am Post subject: Re: Wiring Diagram for Oil Cooler Fan |
dgsaz wrote: |
Hello all,
Thanks for looking.
dgsaz
Actually T-stat should be on out put side of cooler.... IF cooler is doing its job of cooling oil with out fan running then t-stat does not need to trigger fan into coming on by temperature of hot oil coming into cooler, fan only needs to run if COOLER is not capable of cooling oil to below t-stat temp because there is not enough ambient temp change in cooling coil of cooler by natural air flow through cooler IE: cooler buried someplace deep in vehicle where there is no natural air flow.......
And as I mentioned above, control circuit should be under ignition switch control, there is no reason for fan to run if oil is not flowing through cooler...
jason Samba Member
Posted: Thu Sep 05, 2013 8:37 am Post subject: |
Dale you are correct, key does not not actuate fan. I prefer not having extra hot wires all over. I also don't see a problem with the fan on after the car is off, my new car does it. |
jason Samba Member
Posted: Thu Sep 05, 2013 8:39 am Post subject: |
Also make sure your fuse is as close as possible to the battery. |
Posted: Thu Sep 05, 2013 12:30 pm Post subject: |
jason wrote: |
And the cooling fan conversion I put on my JEEP specifically has relay (fan) controlled with ignition switch..... Go Figure....
mondshine Samba Member
Joined: October 27, 2006 Posts: 2813 Location: The World's Motor Capital
Posted: Thu Sep 05, 2013 4:41 pm Post subject: |
Try this:
Good luck, Mondshine |
dgsaz Samba Member
Posted: Wed Sep 11, 2013 4:52 pm Post subject: |
risk wrote: |
Ok, I finally got around to troubleshooting the wiring. When I split the relay and took a good look at the internals I realized that the ground from the 86 terminal was run to the thermo switch and the 85 terminal was running to ground.
If I would have followed my own diagram it would have worked, but noooo....
I write this off to the mirror image when the relay is split. Right is left and left is right. That and I'm a part time dyslectic just a pinch of adult ADD.
Tested the new set up with a jumper at the thermo switch and both the fan and indicator light work.
Now all I need is a good blast up the I-5 and see what happens when I pass 180 degrees.
Better late that never.
dgsaz |
Ellis' Bug Samba Member
Joined: November 15, 2006 Posts: 650 Location: Phoenix
Posted: Thu Sep 12, 2013 1:35 pm Post subject: |
Sorry guys but I'm a little electrically challenged. I have one side of the t-stat grounded..... and my fan isn't coming on.
Can someone re-do the drawing above so that it is correct...... or is it already correct? _________________ 74 Super drag car
63 Bus, work in progress
65 Bug project
63/64 Ragtop
2006 Beck 356 |
