Truck tilt thread FAQ
stevo
stevo is offline
PostPosted: Fri Oct 02, 2009 11:26 pm    Post subject: Truck tilt thread FAQ Reply with quote
after months and months of storage i am able to use the tilt on my 68 doublecab. the wood is bowed and the canvas needs attention but it is functional and very enjoyable. i hope to have it entirely restored in a short while. the canopy is a heavy duty type vinyl perfect for everyday use in the pacific northwest. i will be replacing hardware, a little patching, and assorted improvements. haven't seen too many like this one.
busworks
busworks is offline
PostPosted: Mon Jul 08, 2013 12:09 pm    Post subject: Reply with quote
Think I may have one of these same tilt for a single.
Does it have a stitched in badge by DSU?
Like this?
I have one of the same material I've had in storage for roughly a decade.
babysnakes
babysnakes is offline
PostPosted: Mon Jul 08, 2013 12:19 pm    Post subject: Reply with quote
Yes, I got Jorma! If you don't know Jorma, you don't know Jack. Very Happy
I'd love to see some more tilt action on this thread. Might be a year before I start working on mine.
jtauxe Premium Member
jtauxe is offline
PostPosted: Fri Sep 13, 2013 12:00 pm    Post subject: Reply with quote
If it's heavy-duty vinyl looking stuff, I think that is what VW called a PVC canopy (M-code 209).
B-snakes - Stay tuned. Once I get my hoops and wooden stringers in order, I'll be putting up the original canopy on the single cab, and a repaired original one on the double cab. I have original hoops and canopy material, but will have to have the middle single cab bow and all of the end hoop caps (or whatever they would be called) fabbed up by DG Creations.
http://www.thesamba.com/vw/classifieds/detail.php?id=1173743
I'm shooting for next summer.
But I still need some attachment details... information appreciated:
How exactly do the feet of the hoops attach to the bed? I have what I think are M-10 threads on the two single mounting holes on the front, but just open holes on the back -- two on each side.
How exactly does the front hoop attach to the back of the cab? Is there supposed to be a captured nut on the inside or something?
Any photos of these attachment details would be most appreciated!
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Sep 13, 2013 12:42 pm    Post subject: Reply with quote
Bolts to bed in the corners and back of cab, by the handle. Iirc there are 2 bolts per leg and one for the back of the cab
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
jtauxe is offline
PostPosted: Fri Sep 13, 2013 12:50 pm    Post subject: Reply with quote
That much I figured from the holes in the hoops and in the trucks. But how exactly do these work? For example, the PO on the single cab just schmeared over the old bolt holes into the cab with filler, and the analogous holes on the DC were just badly ripped open holes in the body.
What is supposed to be there?
And what is supposed to be in the back to bolt into?
John
http://vw.tauxe.net
VDubTech
VDubTech is offline
PostPosted: Fri Sep 13, 2013 1:36 pm    Post subject: Reply with quote
IIRC from when I took the hoops off of the SC I parted out....the through bolts replace one of the bolts on each side that hold the female connector that latches the gates up.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Sep 13, 2013 2:03 pm    Post subject: Reply with quote
what is suppose to be there is a capitve 8x1.25 nut that a bolt would attach the frame to.
from the factory there was a 8x1.25 bolt, washer and rubber gasket in place there. you would remove them to put the framework on there.
the bolt's, washers etc were on every truck to plug the hole weather or not you bought the hoops
you guys are going to make me take pictures, huh?
Jake Raby wrote:
jtauxe is offline
PostPosted: Fri Sep 13, 2013 2:10 pm    Post subject: Reply with quote
The DC has those captive 8x1.25 threads on the bed up front, and I have them plugged with bolts. So, I get what you are saying.
Are you also saying that a similar (or exactly the same?) setup originally existed for the pairs of holes at the back of the bed, and for the two holes that go forward into the back of the cab?
That makes sense -- I just want to confirm that that is the original setup.
If so, then I will go about getting all that welded back as it should be.
John
http://vw.tauxe.net
babysnakes
PostPosted: Fri Sep 13, 2013 2:50 pm    Post subject: Reply with quote
Applause Dancing
It won't be long until we put down the bed and bulkhead. Captive nuts make total sense.
jtauxe is offline
PostPosted: Fri Sep 13, 2013 3:08 pm    Post subject: Reply with quote
Good timing! It will be a snap to put those in before assembly.
John
http://vw.tauxe.net
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Sep 13, 2013 7:20 pm    Post subject: Reply with quote
hrer is a teaser pic. i will need to go out and take more tomorrow
Jake Raby wrote:
jtauxe is offline
PostPosted: Fri Sep 13, 2013 7:44 pm    Post subject: Reply with quote
Consider me teased. Cool
Seriously, detail photos would be much appreciated. I can't find anything in the gallery pertaining to the mounting of hoops to the truck.
John
http://vw.tauxe.net
babysnakes
PostPosted: Sat Sep 14, 2013 8:25 pm    Post subject: Reply with quote
All nuts welded.
Left rear corner of bed, deck removed. 2 nuts left to right, 2 blank holes front to back.
Front side of Gersons bulkhead.
Back side of OG bulkhead.
I don't have a pick of the forward bed, but I think there is only one mounting point on each side.
Brian
Brian is offline
PostPosted: Sun Dec 08, 2013 8:56 pm    Post subject: Reply with quote
Does anyone have measurements for the hoops?
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
babysnakes
PostPosted: Mon Dec 09, 2013 9:56 am    Post subject: Reply with quote
Looking for this?
http://busware.biz/Hoop_Details.html
jtauxe is offline
PostPosted: Sun Oct 26, 2014 8:11 pm    Post subject: Reply with quote
Here are photos of the original (and unrepaired) canopy for a 1978 Irish double cab. Note that the front and back have separated from the main part.
John
http://vw.tauxe.net
jtauxe is offline
PostPosted: Sun Oct 26, 2014 8:27 pm    Post subject: Reply with quote
Here are photos of an original PVC canopy (tilt) for a 1975 single cab from Mexico.
John
http://vw.tauxe.net
jtauxe is offline
PostPosted: Fri Jan 09, 2015 1:40 pm    Post subject: Reply with quote
Now I have another question.
Did VW ever make a cab-height canopy?
Like this:
I wonder if it is legitimately NOS, since I did not know VW ever made this. But, here is a part number written on it:
Thoughts?
John
http://vw.tauxe.net
Tcash
Tcash is offline
PostPosted: Fri Jan 09, 2015 3:19 pm    Post subject: Reply with quote
This parts manual list one part number for the bows.
The part number on the tilt is correct. Who knows who wrote it.
The seller is not sure of Mnf.
Early Baywindow Bus Parts BookDouble Cab Doka Bed Cover Tilt NOS Bay Window
Thanks to Jerseylooker
M209
Tilt made of PVC instead of sail-cloth(with M070 only) Model type 261,264
Tilt made of PVC instead of sail-cloth(with M207 only) Model type 265,268
