Bret Young Samba Member
Joined: August 26, 2006 Posts: 760 Location: Turlock, CA
Posted: Sun Sep 15, 2013 10:12 pm Post subject: Need help troubleshooting my blinkers |
Okay guys. Quick question for you all. I have a fresh wiring harness run through my 64 panel (65 Wiring Works harness, they don't carry a 64 one), and despite following the supplied diagram along with the Bentley manual, I have still been troubleshooting piece by piece. I have figured out all of the problems so far, but the current one has be kinda dumbfounded.
So when I push my turn signal lever towards the front of the bus (passenger side blinkers), the turn signal relay (Wolfsburg West 12v relay), it clicks, the lights in the speedometer flash, but when you get out to inspect the lights, nothing up front, but both rear lights flash. Looks like my hazards are on.
I figured to myself maybe i just have two wires switched around at the relay. So i go back into the bus and pull the lever towards me to activate the drivers side turn signals. Same thing happened. Relay clicks like normal, speedometer indicators flash but still just flashing rear lights. So nothing from the front blinkers.
And its not a ground issue or a bulb issue because if I turn on the emergency lights/hazards, they work flawlessly.
Anyone ever deal with this problem when running a new harness? I followed the instructions to a T and hooked up the corresponding colored wires with what the manual/Bentley said. I will crawl back up in there tomorrow to double check, but wanted to see if you guy had any experience with it. |
Jerry Samba Member
Posted: Mon Sep 16, 2013 3:28 am Post subject: |
Sounds like a ground issue.... also check your 9-pin connections one more time. _________________ Looking for SO34 parts.
thevwcompound *instagram* |
landkholdings Samba Member
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15469 Location: Casa de Oro, California
Posted: Mon Sep 16, 2013 8:26 am Post subject: |
| On a '65 the green arrows' bulb holder's outer contact is powered constantly from the domelight toggle on the speedo pod. The flasher grounds the bulb to illuminate it. Does it work right when the key is on? How did you wire yours? |
Posted: Mon Sep 16, 2013 11:10 am Post subject: |
| Jerry wrote: |
| Sounds like a ground issue.... also check your 9-pin connections one more time. |
My bus doesn't have a 9 pin flasher.
| BarryL wrote: |
All that testing was with the key in the on position. Or are you asking if the blinkers work when the key is off?
And regarding the post at the arrows on the speedometer, that had to be run to a constant power from the fuse box. If you search about the people running the Wolfsburg West turn signal relays, if you run the wiring off the Bentley, it buzzes like crazy. Everett checked his stock bus and discovered that the wire is supposed to be constant power for the hazards. I can find the thread for it later. It fixed it and allowed the hazards to work like they were supposed to.
Here is that link:
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...mp;start=0
Any other questions? |
Posted: Tue Sep 17, 2013 10:09 am Post subject: |
So nobody has had this problem with their blinkers? I hooked up all color-coded wires from the turn signal assembly to the corresponding color-coded wires as specified wires in the wiring diagram from the technical page here and the Wiring Works harness instructions.
I crawled in the bus last night to double check that all the colors were correct, and everything checked out. Trying to figure out what else it could be that is causing the problem.
Any help is appreciated. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3447 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Sep 17, 2013 10:37 am Post subject: |
| mrblyoung wrote: |
Just humor us and add ground wires to the rear housings. Funky grounds can do different things based on what is operating. |
Posted: Tue Sep 17, 2013 11:09 am Post subject: |
| ToolBox wrote: |
To the rear tail light assemblies? I already have grounds from the housing to the body. The ground wires came with the harness, and I cleaned up all contacts on the tail light housing assemblies before hooking up the ground wires.
The rear blinkers do flash, but they flash together. If I actuated the passenger side blinkers at the switch and the rear passenger light worked correctly and just didn't have front passenger blinker working, then I would troubleshoot that front one, but regardless of what side I actuate at the switch, I keep getting both rear lights to flash. |
Posted: Tue Sep 17, 2013 11:20 am Post subject: |
| mrblyoung wrote: |
| ToolBox wrote: |
Start looking at the turn signal switch. Could be FUBAR insde. |
Posted: Tue Sep 17, 2013 11:26 am Post subject: |
| I sure hope its not FUBAR. I bought it off someone here to replace the wrong year one that came with my bus. It is not in its housing (just hanging right now because the last coat of paint is drying on the housing). I am not an electrical genius, but is there any tell-tale signs that I should look for? I don't really know the problem areas in the turn signal switches... |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Tue Sep 17, 2013 12:52 pm Post subject: |
If it's not in the housing then it'll be easy to check. It should look like this:
If you look closely at the little board that the wires are soldered to, you will see letters and a couple numbers that should correspond to the wiring diagram. Your switch should be the same, with the same colors in the same spots. It's kind of hard to tell from the pic but from top to bottom, the wires are black-purple (brake switch), black-yellow (left rear), black-white (left front), black-green (right front), black-red (right rear), and black-green-white (flasher). Also, notice that there are two insulated jumpers going across the switch. If they are not insulated and a wire is touching them then it won't work right. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3630 Location: San Diego (Encinitas)
Posted: Tue Sep 17, 2013 8:57 pm Post subject: |
I think the best way to debug this problem is to disconnect the turn signal switch and power up the light wires, one at a time, and see what works and what doesn't. I'd make up one of these (use the proper voltage bulb for your battery voltage):
Use it as the jumper between the battery power source (somewhere on the fuse block) and the light being tested. That way, if anything is shorted, the headlight will harmlessly light up (instead of melting wires).
The post above gives the harness color codes:
- black-yellow = left rear
- black-red = right rear
- black-white = left front
- black-green = right front
- black-purple = power from brake switch
- black-green-white = power from flasher
You want to apply power to the first four (the turn lamps), one at a time, and verify that all the bulbs light up individually. If they don't, then there's a harness issue that you need to solve before messing with the turn switch.
If they all work properly, the next thing to do is to connect a test light between the brake light switch wire and ground, and verify that the brake switch works. Then do the same with the flasher wire.
If all that's OK, then there's likely an issue with the turn switch.
Here's a closer view of the switch (photoshopped version of pic above):
Here's what it does (ignore the high beam wires - you don't have those):
Take your ohmmeter and verify that, with the switch centered, there's a connection between the brake switch input wire and the two rear taillight wires. Do the same for the flasher wire to either the left or right turn light wires with the switch in the left or right turn positions. Make a note of any wire color discrepancies.
If all this works as it should, hook the switch back up and see if all works properly.
If you get stuck somewhere in this (long) process, post here and we'll analyze the issue.
While it seems complicated, it's just a process of elimination. It's do-able. You just have to plug your way through it. Good luck. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Last edited by telford dorr on Wed Sep 18, 2013 9:48 am; edited 2 times in total |
BarryL  Samba Member
Posted: Wed Sep 18, 2013 8:30 am Post subject: |
| Do what these last two posters said. Since two rear lights light simultaneously could you have something in the emergency system haywire? All that system does, in your year bus, is tie all 4 corners together and make them blink. |
Posted: Wed Sep 18, 2013 1:31 pm Post subject: |
| You guys were right. It was a messed up switch. Upon further inspection of the switch, the moving peices inside the switch dont move back and forth with the switch arm and sporadically move where they want. So upon further diagnosis, and working with it, I found that sometimes I would get one front one, then I would get both rears, then I would get none, then I would get ones on opposite corners. Never know what your gonna get. Glad I found it before I started driving it, people around me wouldn't know what the hell was going on. |
Posted: Sun Nov 24, 2013 11:55 am Post subject: |
Wanted to bump this thread back up.
I know others have had problems with their blinkers when running the wiring works harness and the WW turn signal relay. I followed the fix in this thread and the other thread I linked further up in this thread, where you have to run a constant power wire from the fuse box to the post on the speedometer, which effectively fixed the grounding issue and the buzzing noise and my blinkers work correctly, but now the turn signal lights in my speedometer don't work.
I know most people would look at this inquiry as odd because the turn signals are working as needed, but I a bit OCD regarding this restoration and want that turn signal light to work in my speedometer.
Has anyone figured out a way to fix both at the same time? It's not like I can plug in double prong onto that terminal and plug a constant power on one side (the fix) and a ground (the wire that made the light operate, but caused the turn signals to go haywire) on the other. I am not an electrical wizard by any standard, but I am sure there is a way to fix this. Right? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53208 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Nov 24, 2013 1:17 pm Post subject: |
Try moving the blue K wire to S on the relay (you'll need a piggyback connector). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Sun Nov 24, 2013 2:26 pm Post subject: |
After going through the wiring, and finally getting it all hooked up right, I still have intermittent turn signal problems on my '60 bus. Using the test rig shown above with the alligator clips, I have confirmed that it is my turn signal switch, acutually three different used turn signal switches.
I'd like to keep it as stock as possible, and WW doesn't seem to make a commercial turn signal switch (black).
My question is, can I buy the WW switch and just swap the switch and wire part into an original housing? Anybody done this?
Thanks,
j.
Also, I can confirm the S pin (49a) is the one where the blue wire should go, assuming the other lead to the speedo blinker is hooked to the black pos. lead from the ignition switch. _________________ Founder and Chairman Emeritus, ECMSAS
| BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
| Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
BarryL  Samba Member
Posted: Sun Nov 24, 2013 2:38 pm Post subject: |
| mrblyoung wrote: |
Pull out your turn bulb socket and wire, take out the bulb, use an ohm meter with the dial set to DC, put one probe touching the now vacated bulb contact and the other to ground and report what happens when you turn signal.
If that gives you no reading, put one probe on the bulb contact and the other to +DC and tell what you get. |
quartermilecamel Samba Member
Posted: Tue Nov 26, 2013 1:10 am Post subject: |
So basically, barrys trying to see if you have signal at all on that light socket. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
shortwing Samba Member
Joined: August 18, 2006 Posts: 54 Location: The Sunshine State
Posted: Sun Nov 22, 2020 12:41 pm Post subject: Speedo signal indicator light |
| Bret Young wrote: |
Brett, did you ever figure this out? I have a 1960 commercial bus and I’m having the same problem with the indicator lights in the speedometer not flashing when the blinkers are blinking. |
