Silicone hoses
allsierra123
allsierra123 is offline
PostPosted: Thu Apr 23, 2009 5:57 pm    Post subject: Silicone hoses Reply with quote
Just curious as to the difference in the types. I am looking for some hose to use on my coolant lines. But I dont see any differences in them is it all the same or is there special type of hose you use for collant system applications.
95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold
allsierra123
PostPosted: Fri Apr 24, 2009 5:36 am    Post subject: Reply with quote
anyone
Raynor Shine
Raynor Shine is offline
PostPosted: Fri Apr 24, 2009 7:35 am    Post subject: Reply with quote
On my SS connection, the blue hose Terry Kay supplied, has to be the best hose I have worked with. from my engine block, i used reinforced high pressure marine hose. and for the heater hoses just the good year rubber hose. kock wood, no leaks....
jimeg
jimeg is offline
PostPosted: Sun Oct 06, 2013 9:11 pm    Post subject: Reply with quote
Any difference in quality out there? Geebee seems to be the one for VW sets, but what standard heater hose? Or Geebee for that too?
This stuff OK? Anything better quality or better priced?
http://www.amazon.com/High-Performance-Silicone-Heater-Hose/dp/B009PZRJD2/ref=pd_sim_sbs_indust_2
1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490
IdahoDoug
IdahoDoug is offline
PostPosted: Sun Oct 06, 2013 11:32 pm    Post subject: Reply with quote
I've kind of shied away from silicone hose due to its tendancy to leak when cold. I'd heard this but used some anyhow and it would seep overnight. Something about it not having as strong a "memory" to grip a given nipple when compared to quality rubber hose. Rubber also seems to stick on after a while and you have to break it loose, where silicone comes right off just like the day you put it on with no apparent sticking. So, you have to use a special "constant tension" clamp with it. I got some of those and still got the odd drip over the year I used it.
At the end of the day, between the hose cost and the pricey clamps it was quite expensive and did not seem to ever seal well. So I dropped its use.
Somewhere I have a package of sweet clamps, and even another thing I was going to try to stop the leak - clamps you heat shrink into place.
DougM
vanagonjr
vanagonjr is offline
PostPosted: Mon Oct 07, 2013 3:19 am    Post subject: Reply with quote
An interesting read on Silicone hose.
http://www.stevesturgess.com/2011/07/truck-maintenance-tip-hose-hints.html
I had read about the permeability before - which I am not a big fan of, i.e., if something is leaking or evaporating out, it is one more thing going into the environment.
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
jimeg
jimeg is offline
PostPosted: Mon Oct 07, 2013 7:42 am    Post subject: Reply with quote
Good read. There is another post here where a van owner was losing coolant and couldn't find a leak anywhere. Something to research and consider a little more. The lifetime warranty on the silicone is what makes them attractive to me.
Christopher Schimke
PostPosted: Mon Oct 07, 2013 7:54 am    Post subject: Reply with quote
This has been brought up before. Watch the video in the other thread. It shows that silicone hoses permeate water at "10 or more times" that of a rubber hose, but not coolant since the ethylene Glycol molecules are larger than water molecules.
http://www.thesamba.com/vw/forum/viewtopic.php?t=502976&highlight=coolant
jimeg
jimeg is offline
PostPosted: Mon Oct 07, 2013 7:57 am    Post subject: Reply with quote
Yes. This was the thread I was thinking of, and that is right - he was losing water not coolant.
Did you end up running silicone or rubber?
Christopher Schimke
PostPosted: Mon Oct 07, 2013 7:59 am    Post subject: Reply with quote
Rubber!
jimeg
jimeg is offline
PostPosted: Mon Oct 07, 2013 8:01 am    Post subject: Reply with quote
Rubber!
Where do you find new rubber hoses for your I4 conversion(same for diesel, correct?).
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 07, 2013 8:04 am    Post subject: Reply with quote
I have using silicone hoses on various vehicles including Vanagons for over 10 years without issue.
Not all hoses are created equally.
The GeeBee hoses I have had in service for over 2 years have been awesome.
Christopher Schimke
PostPosted: Mon Oct 07, 2013 8:33 am    Post subject: Reply with quote
Rubber!
Everything that I did at the rear was custom. The only stock VW hoses left in the system are the two at the front coming from/going to the radiator.
Yeah, I'm not knocking the silicone hoses at all. It just seems that some amount of care needs to be taken to ensure that the hoses stay tight on the fittings/tubes and monitor any water permeation. I chose rubber because it was much cheaper and much more convenient given the custom nature of what I was doing.
furrylittleotter
furrylittleotter is offline
PostPosted: Mon Oct 07, 2013 8:51 am    Post subject: Reply with quote
I have been contemplating upgrading to silicone and this writeup has helped me make the decision to stick with rubber. I do enough weeping over the van, I don't need silicone hoses that weep as well. For some reason I though silicone would "last longer" but hell my 30 year old hoses are still fine. There is obviously more to this than my small brain can contemplate.
Neil2
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 07, 2013 10:36 am    Post subject: Reply with quote
A rubber vs silicone hose debate should produce as much of a stalemate as the stainless vs aluminum pipe debate.
Go with what you resonate with.
insyncro
Banned
insyncro is offline
PostPosted: Mon Oct 07, 2013 10:37 am    Post subject: Reply with quote
