73 Bus valve cover valve cover spring
texaspro
texaspro is offline
PostPosted: Mon Oct 07, 2013 9:26 am    Post subject: 73 Bus valve cover valve cover spring Reply with quote
Ok so with tools in hand went to adjust valves for the first time on my new project. Got the valve cover spring to drop down on the passenger side but it is stopped by a manifold enough that I can't get the valve cover off. So what am I doing wrong?
obx71super
obx71super is offline
PostPosted: Mon Oct 07, 2013 9:27 am    Post subject: Reply with quote
Mine are a tight squeeze, try tilting the top of the valve cover back towards you
71 super auto stick basically original minus a couple resprays
73 Westy automatic with a 2 liter gex, soon to be a 1.8 liter Headflow masters
Newest Addition!! Solid straight 74 thing totally disassembled!! YEEEWWWW
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Oct 07, 2013 9:30 am    Post subject: Reply with quote
Is it possible that the bale that holds the cover on is upside down?
texaspro
texaspro is offline
PostPosted: Mon Oct 07, 2013 9:35 am    Post subject: Reply with quote
I tried pulling back on the top but had some resistance and didn't want to damage the gasket. Thought about removing the spring but figured I'd ruin the tension
Randy in Maine
PostPosted: Mon Oct 07, 2013 10:35 am    Post subject: Reply with quote
That bale will come out of the head using a prying instrument (I use a bake adjustment spoon). Remove it, take out the valve cover, adjust the valves. When you re-install it, you may need to take it over to the bench vise (or whatever) and give it a little bend to make sure that pressure is being applied evenly over the whole valve cover/.
By the way, usually the "tab" on the valve cover goes in the upper right hand corner when it is back in there.
VDubTech
VDubTech is offline
PostPosted: Mon Oct 07, 2013 2:53 pm    Post subject: Reply with quote
The gasket should be the least of your worries when adjusting valves and should always be replaced when doing so.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
texaspro
texaspro is offline
PostPosted: Mon Oct 07, 2013 3:30 pm    Post subject: Reply with quote
My concern was if I couldn't get the cover off and screwed up the gasket and resulting in a major leak. I have new gaskets ready to go...
