Sherlock77 Samba Member
Joined: June 08, 2011 Posts: 19 Location: Orlando, FL
Posted: Sun Oct 20, 2013 7:48 am Post subject: Speedometer and indicator lights |
How is the speedometer held to the dash? The buggy I bought doesn't seem to be attached, it was a tight fit so it was fine but I removed it to fix the fuel gauge and now it moves around and wiggles. Are there supposed to be clamps or something? it is an original speedo from a '76 i think, that is what the buggy was built on. Also, the buggy speedometer has no lights or light sockets in it, I looked to buy them but at 6-7 dollars each plus the bulbs that seems a bit pricy for a tiny metal socket, are there any alternatives out there? _________________ ----------
( (O)\ w /(O) )
\__ o \ _ / o __/
|_| |_| |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20816 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Oct 20, 2013 8:14 am Post subject: |
Hold it in any way possible... IF you have to add clamps so be it... Most speedo's have some mounting ears (tabs) or clamp system... IF yours is missing these you will have to adapt...
As for lamp sockets did you try in classified?
http://www.thesamba.com/vw/classifieds/detail.php?id=1457368
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Kevinwterry Samba Member
Joined: December 31, 2010 Posts: 102 Location: Bellingham wa
Posted: Sun Oct 20, 2013 8:48 am Post subject: |
im assuming it looks like mine. mine was from a 74 superbeatle. it was loose in the donor bug so i have no idea how they are supposed to be mounted. i ended up jb weldeing it to my dash panel. i thought about maybe taking a piece of pvc piping and makig it fit around the body of the speedo and clamping it down with a big hose clamp. that would only hold it in the dash, not stop it from rotating. you could try asking the late beatle forum about mounting it.
as far as lights go, i got mine from wolfsberg west. i think i remember getting them alot cheaper than 6 bucks each. |
Rathbone Samba Member
Joined: February 25, 2006 Posts: 235 Location: Palm Coast, Florida
Posted: Sun Oct 20, 2013 5:32 pm Post subject: |
In order to get the lights to work in a dune buggy this gauge must be grounded. Can I ground to any of the prongs on the housing or do I have to ground all of them? _________________ (o\_i_/o) what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul - Mr. Oblaski, Principal |
Posted: Sun Oct 20, 2013 5:45 pm Post subject: |
ya, i grounded the speedo via one of the ground prongs on the speedo housing. works good. i think there were at least 4. the extra 3 worked good as a ground for other stuff like my gauges and stuff that i forgot to run a ground wire to.
basically once you ground the housing, everything on the speedo is is grounded. |
Posted: Sun Oct 20, 2013 5:54 pm Post subject: |
well hold on now... now i cant remember. i know i grounded the speedo case via the ground prong to the right of the speedo cable. there is a couple ground prongs above the speedo cable to the right. i used those for my volt meter and temp gauge.
you can barely see them in the picture, but there are also two ground prongs between the idiot lights on the bottom of the speedo. i cant remember if i had to run another ground to those or not. im thinking not, but not sure. those three lights on the bottom look like they might be seperate. im not home so i cant look. |
Posted: Sun Oct 20, 2013 6:01 pm Post subject: |
Kevinwterry wrote: |
The three idiot lamps (OIL-ALT-SIGNAL) require 12 volts on prong that feeds "shell" of lamp sockets... Usually key switched 12 volts.... Tab on lamp sockets go to the the oil sender or turn signal flasher or terminal 61 of voltage regulator or D+ of alternator...
Only put a ground wire on main shell of speedo...
Posted: Sun Oct 20, 2013 6:24 pm Post subject: |
thats it!! now i remember. dales right. those 3 lower idiot lights that are isolated from the rest of the speedo are wired "backwards" in my mind. 12 volts go to what looks like the ground prong. |
Posted: Mon Oct 21, 2013 3:10 pm Post subject: |
thanks everyone, that helps. it does look like the one in the photo, guess i'll have to figure the best way to hold it, the hose clamp may be the way to go. I guess i'll look in the classifieds for sockets, $3 is much better then $6 or more. _________________ ----------
( (O)\ w /(O) )
\__ o \ _ / o __/
|_| |_| |
OutCasted Samba Member
Joined: November 06, 2010 Posts: 140 Location: Southgate,Mi
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Oct 21, 2013 7:57 pm Post subject: |
Very informative thread. I hope the bulbs from my old 6v gauge are still made in 12v. _________________ 1958 Karmann Ghia owner |
Posted: Tue Oct 22, 2013 7:14 am Post subject: |
Northof49 wrote: |
Very informative thread. I hope the bulbs from my old 6v gauge are still made in 12v. |
Yep....
Posted: Tue Oct 22, 2013 6:49 pm Post subject: |
I pulled a bulb from my 58 speedometer and the bulb appears to say "Hejalux 0,12". I'm guessing its an original 6v bulb. Is 0.12 the wattage? _________________ 1958 Karmann Ghia owner |
Posted: Sat Oct 26, 2013 9:23 am Post subject: |
got the bulb holders from wolfsberg west, they got here quick. I did decide to try led bulbs but I found them a lot cheaper here:
http://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba7s-led-bulb-1-led/10/
and they were the same price as a regular bulb, they got here the same day, looking good. now to figure out how to fix the dash to put everything back together! _________________ ----------
( (O)\ w /(O) )
\__ o \ _ / o __/
|_| |_| |
Posted: Sat Oct 26, 2013 5:51 pm Post subject: |
Post up pics of it lit up with the leds. |
Posted: Sat Oct 26, 2013 6:04 pm Post subject: |
