oasis Samba Member
Posted: Sat Jul 28, 2007 12:34 am Post subject: What wheels fit - a simple supplement |
I know there is an ultimate thread running and some day I will consume enough coffee and aspirin to try to weed through it. Let me ask something simple before I go there ...
Do all 1980-91 Vanagons use the same bolt pattern and offset. If not, do they differ by year, syncro and non-syncro, and/or anything else? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
iceracer Samba Member
Joined: February 28, 2006 Posts: 981 Location: Milwaukee, Wisconsin
Posted: Sat Jul 28, 2007 5:11 am Post subject: |
YES, Well let me see. All buses from 71-91 use the same bolt pattern. 5x112. As for offset, offhand I do not know what the steel wheels are but the alloys are 30et. And same goes for the syncro. _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Sat Jul 28, 2007 6:37 am Post subject: |
2wd has a much larger front spindle/grease cap than the syncro. Requires the center of some wheels to be modified to fit.
Alloy wheels require longer bolts/studs than steelies. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
Posted: Sat Jul 28, 2007 7:04 am Post subject: |
......and the Syncro can handle a higher offset wheel better than a 2wd due to it's differing uprights and control arms. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Sat Jul 28, 2007 8:53 pm Post subject: alloy wheels |
Hello everyone
I know that the subject of alternate choices for Vanagon wheels has been beaten to death, however, even after reading 99% of the posts on the subject there is an issue that has never, hmm or almost not been clearly established.
Most of the lucky chaps who have adapted other wheels than stock to their Vanagons do not state whether they were upgrading from stock steel or alloy wheels which leads to my question as Hiram6 has said
| hiram6 wrote: |
| Alloy wheels require longer bolts/studs than steelies. |
Very clear. but should one then believe that Vanagon which are factory equipped with alloy wheels have longer bolts/studs originally and those factory equipped with steel wheels have shorter bolts/studs ?
Which leads to the second question/assumption. Should Vanagon originally fitted with factory alloys need longer blots/studs or can they keep their original bolts/studs when changing to other alloy wheels, such as but not limited to Mercedes, Audi, etc...
My questions basically apply to 15" wheels, not being interested in the 16, 17 or whatever larger wheels.
Thanks for all and any informative response |
Posted: Sat Jul 28, 2007 9:38 pm Post subject: |
All 2wd and Syncro Vanagons came with the same stud lengths in the rear. The Syncro's all came with studs in the front however, 2wd's used bolts. The bolts and nuts for the steel wheels have a ball seat. The bolts and nuts for the factory alloy wheels have a conical (tapered). The factory alloys themselves are thinner than most other alloys where the shank passes through the wheel. This is what allows them to be used with the short rear studs. Most alloy wheels are thick enough in this area that they require longer studs and bolts.
There are a few wheels out there that can be installed using the stock, short wheels studs but these wheels have a somewhat high offset. This is okay on a Syncro and the rear of a 2wd but the front of the 2wd would need a spacer in order to clear the suspension components. This means longer wheel bolts obviously. What's a little less obvious is that if you add spacers to the front and not the rear (adding spacers to the rear would necessitate longer studs), the front track width will be greater than the rear. Not that it is the end of the world but it's not the best for handling or for looks. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
freshintulsa Samba Member
Posted: Sun Jul 29, 2007 9:28 am Post subject: |
i just put some 16s from a 2007 jetta on my westy. gotta enlargethe center holes for 2wd but they fit with spacers, look sweet too. anything with 5x112 will fit, just might need some modifications here or there. _________________ "go slower, go lower!!!"
85 westy svx
Fresh front end rebuild
Front cab changed from brown to black with new homemade door panels, etc.
Soon to remove fridge/sink/cabinet and make custom bench seat!!!
89 wolfsburg/ bluestar.... finished the stick to automatic conversion,
tiico motor
Daily driver, 20mpgs and has enough hair in it to make a few dogs. |
faith2es Samba Member
Posted: Tue May 22, 2012 5:41 pm Post subject: Looking for tires for EV (225 60/16) >102 load rating |
I am new to your website and would like direction to where i might find this info as i am sure that others are having a hard time finding tires this side with a load rating of >102.
thanks for your patience and directions to this info!
New Member |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Wed May 23, 2012 12:02 am Post subject: |
Probably Nokian will have a 16 in that 225 /60 that will meet your 102 goals.
If not, I can't imagine anyone else that would.
If you want that 102 or better, you might have to be willing to flex a little on your tire size. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
chmielex Samba Member
Posted: Mon Sep 17, 2012 12:27 am Post subject: |
Ive got a pair of mercedes c class steel rims for my syncro and im planning on putting 29,5x9,5 15 maxxis buckshot on there but someone told me the rims themselves were weaker in the construction and might crack?
I was also planning on widening them (the rims) and was figuring it isnt very fun to put alot of time and work in a set of rims that is less than perfect? |
kwikarl Samba Member
Joined: August 14, 2009 Posts: 1 Location: Greeley, CO
Posted: Mon Oct 01, 2012 7:43 pm Post subject: |
| Help! Will stock Eurovan 15's fit straight across to a 2wd 84 vanagon? If spacers needed how thick? I cant get to try one on first. |
AdrianC Samba Member
Joined: January 13, 2012 Posts: 526 Location: Wherever the road's gone
Posted: Tue Oct 02, 2012 12:05 am Post subject: |
| kwikarl wrote: |
No, centre bore is too small, as with other VAG rims.
If you want easy 15" steels, then Merc is (AIUI) the way to go. I've been doing a lot of looking into this, but the one potential gotcha seems to be that most older Mercs use M12 studs/bolts, whilst we use M14. Lots of people over on 80-90 have said they're using older Merc steels without any mod - but nobody's really confirmed for sure that our M14 studs/bolts will pass through the undrilled Merc M12-intended holes. Can anybody here confirm that for me?
| chmielex wrote: |
| Ive got a pair of mercedes c class steel rims for my syncro and im planning on putting 29,5x9,5 15 maxxis buckshot on there but someone told me the rims themselves were weaker in the construction and might crack? |
Steels don't tend to crack, they bend. Alloys crack. But a quick google suggests GVW for a W202 C-class is about 1900kg, vs our 2500kg. I seem to recall finding that for a W201 190 it's higher - about 2250kg. That sounds close enough for me, but if you're looking mid-90s onwards, then I'd probably look at W210 E-class rather than C-class. With Mercedes, my gut says "the older the better" - it's well known and documented that the W210 era was where the rot set in (quite literally...) with de-contenting and down-speccing the engineering. _________________ Adrian
Zookeeper of a miscellany of motoring silliness, from 0.75bhp to 9ft tall.
Living life on the road in an '88 2.1DJ Westfalia Club Joker Hightop.
www.WhereverTheRoadGoes.com |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Tue Oct 02, 2012 8:11 am Post subject: |
| kwikarl wrote: |
I just picked up a set of 15 x 6 MBenz steel wheels so that I can have a spare that fits over my Audi brakes up front AND goes in the clamshell.
Trial fit one the other day and it slipped right on. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Tue Oct 02, 2012 8:13 am Post subject: |
| Jake de Villiers wrote: |
| I just picked up a set of 15 x 6 MBenz steel wheels so that I can have a spare that fits over my Audi brakes up front AND goes in the clamshell. |
That sounds perfect. If you look at the part number on the wheel, what're the first three digits? They're the W-code model number of the car they're off.
What size tyres do you have on 'em, btw? _________________ Adrian
Posted: Tue Oct 02, 2012 8:31 am Post subject: |
| AdrianC wrote: |
No, centre bore is too small, as with other VAG rims. |
Agreed! The Eurovan wheels also have higher offsets, so you will definitely need spacers and new wheel hardware.
| AdrianC wrote: |
| If you want easy 15" steels, then Merc is (AIUI) the way to go. I've been doing a lot of looking into this, but the one potential gotcha seems to be that most older Mercs use M12 studs/bolts, whilst we use M14. Lots of people over on 80-90 have said they're using older Merc steels without any mod - but nobody's really confirmed for sure that our M14 studs/bolts will pass through the undrilled Merc M12-intended holes. Can anybody here confirm that for me? |
I have helped many, many people install Mercedes steel wheels onto their Vanagons and every one of the steel wheels that were designed for 12mm wheel hardware (202, 203, 124, 208, etc.) have fit over the 14mm wheel hardware just fine (alloy wheels are a completely different story though). The stock Vanagon steel wheel lugs don't fit those wheels very well though, so small ball seat lugs are highly recommended. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Oct 02, 2012 8:58 am Post subject: |
| Christopher Schimke wrote: |
| I have helped many, many people install Mercedes steel wheels onto their Vanagons and every one of the steel wheels that were designed for 12mm wheel hardware (202, 203, 124, 208, etc.) have fit over the 14mm wheel hardware just fine |
Why didn't I just drop you a PM? <grin> I'll take that as utterly authoritative. Thank you very much.
Standard nuts & bolts? _________________ Adrian
Posted: Tue Oct 02, 2012 1:01 pm Post subject: |
| AdrianC wrote: |
What size tyres do you have on 'em, btw? |
The wheel's part number is: 124 400 0602 ET49
I'm looking for a 195/75-15 or 205/65-15 to match the circumference of the 225/55-16s mounted on the road wheels. _________________ '84 Vanagon GL 1.9 WBX
Far_West Samba Member
Joined: October 09, 2011 Posts: 10 Location: Idaho Falls
Posted: Thu Oct 04, 2012 9:35 am Post subject: MK4 wheels |
| Would 15" wheels off a 2000 MK4 fit a 87' vanagon? Any help would be great. |
kamzcab86 Samba Moderator
Posted: Thu Oct 04, 2012 11:14 am Post subject: Re: MK4 wheels |
| Far_West wrote: |
| Would 15" wheels off a 2000 MK4 fit a 87' vanagon? |
The Mk4s use 5x100; so, no, they are not direct fits. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
bigdog1189 Samba Member
Posted: Sat Nov 02, 2013 5:40 pm Post subject: |
Hi All,
would oem wheels (alloys) from 1999 audi A4, 15x7 with an ET39 fit an 86 2wd vanagon without needing any mods to the wheels? thanks!
Ps, this is an awesome site! |
