ddye Samba Member
Joined: July 14, 2010 Posts: 357 Location: Dallas, TX
Posted: Sun Nov 17, 2013 6:56 am Post subject: Clutch Slave Cylinder Bad? |
Yesterday I noticed that the clutch was VERY soft and didn't engage until 3/4 of the way to the floor. I pulled the instrument cluster and the brake fluid reservoir was half empty. I checked under the van and looked for leaks but didn't find any right off the bat. I then had the wife engage the clutch and the slave cylinder seemed to actuate as designed. I then pressed lightly on the side of the slave cylinder boot and fluid (a fair amount) came out of the bottom of the boot.
Couple questions:
1. Is my clutch slave cylinder bad?
2. If the answer to (1.) is yes; is there anything else I need to replace when I replace the slave?
3. Is replacing the slave a fairly easy job or should I just take it to the mechanic?
I'm fairly good mechanically but time is limited.
Thank you,
David _________________ 1988 Westy
2.1 Boston Bob Rebuild
"Nelly" |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1125 Location: over by 'der
Posted: Sun Nov 17, 2013 7:05 am Post subject: |
replacing the slave cylinder is not a technically hard job, its just a pain because of the location. i would replace it if its leaking. they arent expensive. The clutch system takes fluid from the brake master cylinder reservoir at a braided hose on the side. If the fluid level drops below that hose, air will be sucked into the system. a dry seal in a hydraulic cylinder will cause leaks like yours. i would also check the clutch master cylinder for leaks. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
ddye Samba Member
Posted: Sun Nov 17, 2013 7:07 am Post subject: |
Thank you NavyVW
Dang I didn't realize there was a clutch Master and Slave. I am looking at the cylinder on the drivers side of the transmission. Is this Master or Slave? Where is the other  _________________ 1988 Westy
"Nelly" |
ddye Samba Member
Posted: Sun Nov 17, 2013 7:15 am Post subject: |
NM I found it. it is dry as a bone...no leaks there. _________________ 1988 Westy
"Nelly" |
you are looking at the slave cylinder. the master cylinder is above the clutch pedal. you have to squirm in there and you can see it with a flashlight (use a mirror if handy). you'll notice the hose comes off the reservoir and goes down to the master cylinder. the pedal pushes a pushrod to actuate the master cylinder which actuates the slave cylinder. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3669 Location: Dartmouth, Mass.
Posted: Sun Nov 17, 2013 8:49 am Post subject: |
This is entirely up to you, but you may want to bleed the old slave first. When I replaced mine and then bled my new shiny slave, the old fluid was black. Kind of bummed me out to take a new unit and bleed all that crap through until new clean fluid came out.
Probably has no effect, but sure did not make me feel great about it. _________________ John - 86 Wolfsburg Westfalia "Weekender"
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Sun Nov 17, 2013 9:55 am Post subject: |
| vanagonjr wrote: |
Probably has no effect, but sure did not make me feel great about it. |
good advice here. bleed the old stuff through the old cylinder so that you are only introducing new clean fluid to the new cylinder. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
mikls63rag Samba Member
Joined: May 13, 2006 Posts: 555 Location: Antioch, CA
Posted: Fri Jun 12, 2015 11:12 am Post subject: |
How long of a job is it and can it be all bleed out with one person...My extra help is limited. _________________ Michael
63' Rag
65' Bug
13' Passat S |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3419 Location: Vancouver, B.C.
Posted: Fri Jun 12, 2015 5:54 pm Post subject: |
It takes about one hour to replace both the clutch master cylinder and the slave cylinder if the slave is not rusted into place and to bleed the system without a helper. (A syncro slave is harder to replace).
I recommend that you replace both the master and slave if only the slave was leaking, mainly because the master usually craps out shortly after you replace the slave cylinder.
You can bleed the system easily yourself if you lift the front of the van or drive the front wheels onto ramps. Place a clear hose over the slave bleed nipple, open it up, place the end of the hose in a clear container with brake fluid just covering the bottom of the bleed hose. Now pump away, add brake fluid to the reservoir as necessary, and close the bleeder to check if your clutch operates. Raising the front of the van ensures that the master cylinder and the reservoir are both higher than the slave, forcing any air out. Thankfully, the slave bleeder nipple is actually at the highest point on the item needing bleeding - - a rare occurrence in a VW. _________________ '86 Syncro Westy SVX |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 735 Location: Bellevue
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Sat Jun 13, 2015 4:22 am Post subject: |
You can also bleed it using a 2x4 or similar piece of wood long enough to fit between the clutch pedal when fully pushed down and seat box.
Pump the pedal down and put the wood in place to hold it down.
Then go to the slave cylinder and open the bleed port to release the pressure and close it. A clear bleeding tube on the bleed port running down to a container to catch the fluid lets you see the fluid that comes out.
I like this method better as you are flushing out the old fluid. |
Posted: Sat Jun 13, 2015 3:05 pm Post subject: |
| Steve M. wrote: |
That's how I do it most of the time. The lady of the house doesn't like to be tasked with such things as putting her foot on the pedal and pumping a few times.  _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
