Jordan's 67 fastback build
Page: 1, 2, 3  Next
qoopwn
qoopwn is offline
PostPosted: Thu Jan 17, 2013 6:30 pm    Post subject: Jordan's 67 fastback build Reply with quote
Hey guys so I already have another thread up about my 69 fastback that I'm working on, but I figured I would make a new thread because the 67 fastback I have will be my main project and daily driver when it is finished! The 69 will get back into running order and I'll sell it to fund the rest of the 67 project.
So without further ado, the 67 and all its glory. So far I have the engine rebuild going on, and after that I'll drive it for awhile and then get the pans blasted and powder coated along with all the rest of the under side.
LOT OF PICTURES:
THE CAR:
OLD: ENGINE TEAR DOWN
PAINTED ENGINE TIN
CARB REBUILD
qoopwn
qoopwn is offline
PostPosted: Thu Jan 17, 2013 6:34 pm    Post subject: Reply with quote
The visor and roof rack will be will be put on the 67 and I have the majority of the plans ready for it already. Here's my type 3 selecta of what I want it to be:
Theres my engine, in boxes..
Sqrbckguy38
Sqrbckguy38 is offline
PostPosted: Thu Jan 17, 2013 9:51 pm    Post subject: Reply with quote
i like the idea. love the fasty's, even my big pig nosed 70, soon to have a subaru conversion.
It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal
qoopwn
qoopwn is offline
PostPosted: Sun Jan 20, 2013 10:12 pm    Post subject: Reply with quote
I do have a question about the paint and interior though. The VIN indicates that this car was made between Feb and March or 1967, and the paint is original L650 Granada Red (I'm assuming) so that makes the interior 90 platinum..but from the pictures 90 platinum looks so much more..silver and grey to me. My interior, which is all stock to my knowledge since everything is the same and the headliner has never been replaced looks more like a creamy color. More like 93 balearic beige...or somewhere along those lines. Does anyone have a picture of the 90 platinum laying around? I'm trying to get as close to stock as possible
qoopwn
qoopwn is offline
PostPosted: Thu Jan 24, 2013 5:38 pm    Post subject: Reply with quote
Not much to report on, but today I finished up some of the painting for my engine and now All I have to do it wait for the rod to be rebushed and the flywheel resurfaced! Then off for the rebuild! If anyone could give some advice of the interior question I posted before this though I'd appreciate it haha.
Adam
Adam is offline
PostPosted: Thu Feb 28, 2013 8:54 pm    Post subject: Reply with quote
Looks good so far Razz
qoopwn
qoopwn is offline
PostPosted: Mon Mar 11, 2013 3:43 pm    Post subject: Reply with quote
Final pieces of the car are here, and if all goes according to plan the big heater exchanges with the tar wrapped are getting blasted and powder coated so I wont have to worry about those and on Saturday the engine will be rebuilt. Expect loads of pictures!
dailyt3
dailyt3 is offline
PostPosted: Mon Mar 11, 2013 4:08 pm    Post subject: Reply with quote
cool looks good
1973 Squareback Stock F.I - Hazel
2005- 2012 Sitting in dirt lot in Compton Ca.
Purchased Aug-2012
Revived and on the road March 1, 2013
qoopwn
qoopwn is offline
PostPosted: Sat Mar 16, 2013 10:03 pm    Post subject: Reply with quote
Pretty eventful day, got all of the pistons and cylinders on today and in another week or so will have the whole engine assembled. Here are some pictures!
Rome
Rome is offline
PostPosted: Sun Mar 17, 2013 3:01 pm    Post subject: Reply with quote
I hate to reduce your enthusiasm, but it appears as though the connecting rod for #2 piston is installed upside-down in your second photo above. That rod is the one closest to the crank pulley. The small rectangular bump on the rod's shank must face upwards, like on all other rods. Hopefully you noticed and corrected that before you closed up the case.
qoopwn
qoopwn is offline
PostPosted: Sun Mar 17, 2013 6:52 pm    Post subject: Reply with quote
Hmmm...now that you mention it..well in the book the crank is oriented a different way, could there be a possibility that the rod is supposed to be flipped "down" and have the hump be facing up? Because I'm almost positive that we installed them correctly. But I will for sure double check since we did not see that until right now already having the case sealed and everything Sad
Thank you for catching it, curious though what are the repercussions if it was ran with it being wrong?
Slow 1200
Slow 1200 is offline
PostPosted: Mon Mar 18, 2013 5:20 am    Post subject: Reply with quote
the bumps must face up on all the rods, so I see some disassemblying in your future
qoopwn
qoopwn is offline
PostPosted: Sun Jun 16, 2013 3:10 pm    Post subject: Reply with quote
Its been awhile since I've posted anything but dont worry I've been moving right along. I just got the finishing touches on the engine and itll be put in the car within the follow week or so hopefully. I just refurbished my heater boxes to make them look and feel and work like new so I thought I'd show everyone. I also got all the locks rekeyed on the car.
Heaterbox Rebuild
First, they were sand blasted down to bare metal by my dad, and they actually came out really clean which I was surprised to find since they were covered in old oil.
Then I sprayed everything with Dupli-Color engine enamel super high temp primer and gloss black. The gloss black comes out really thick and jet-like so be careful when using this stuff..
Then I bought super high temp wrap that stands up to 2000 degrees continuous heat and wrapped them up. I also used generic stainless clamps.
jefftrish
jefftrish is offline
PostPosted: Sun Jun 16, 2013 3:31 pm    Post subject: Reply with quote
You should consider being more liberal with the grease, just in case you don't get oil pressure right away Shocked
Just giving you a hard time, looking good, and I am looking forward to seeing it running
Regards,
Jeff
qoopwn
qoopwn is offline
PostPosted: Sun Jul 07, 2013 10:17 pm    Post subject: Reply with quote
This weekend marked the first time the car has run in a very long time, and it ran great and strong. It isnt quite home yet as there are still some things to do to it at my grandpa's shop, but so far it is looking and sounding extremely good. Well not necessarily looking good Razz
Before the trailer
Brand new rebuilt engine finally completed
In the air
I'm hoping within the next week or so she'll be home and I'll be able to drive her like she wants to be driven. After that its time for slow body work panel by panel and eventually a body off pan resto. Thats all for later though Razz
joey1320
joey1320 is offline
PostPosted: Mon Jul 08, 2013 11:02 am    Post subject: Reply with quote
Congrats on the process. Engine came out super nice Smile
1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile
bent_karma
bent_karma is offline
PostPosted: Thu Jul 11, 2013 5:29 pm    Post subject: Reply with quote
Heaterbox Rebuild
Hey im doing some of the same thing you did where did you find that high temperature wrap?
'71 VW Westfalia Bay [Bowie]
'23 Toyota Tacoma 4x4TrD 6sp
'71 VW Bay Window Deluxe Bus [Busness] sold
'73 VW Thing [Agent Orange]
'71 VW Squareback (first air cooled/vw ever) sold
'07 Mazda3 Hatchback GT [the Mazda] sold
'06 Nissan Sentra 1.8 S sold
'18 Subaru Forester 2.5i [Sue Bee]
"Water is for drinking"
qoopwn
qoopwn is offline
PostPosted: Tue Dec 10, 2013 8:10 pm    Post subject: Reply with quote
Hey guys I know its been awhile, but as for an update I've just been driving and working on little things here and there. New master cylinder so the brakes work great, this baby runs like a champ. Its extremely fun to drive and its so responsive. Grandpa did a great job on the engine Twisted Evil
But I do have some updates, I'm starting to do some body work to make it look cosmetically pleasing for my eyes.
Body Work
Passenger front fender had some rust issues on the bottom corner
High grade honda metal was used as the donor metal (lol)
This is the fender on the top, found amazingly close to stock red paint for dirt cheap. Rolling Eyes
Nothing like some panel bond. This stuff is literally amazing. Bare metal + panel bond = no more rust and amazing strength. Didnt want to be bothered with welding just yet.
Cleaned up the inner fender, looks nice to me.
NEXT UP, THE FRONT APRON. I've already got a start on that and boy..theres some work to be done..Might just get a replacement front apron who knows.
hentotheree
hentotheree is offline
PostPosted: Wed Dec 11, 2013 11:12 am    Post subject: Reply with quote
very nice job! keep up the good work!
mattmcgee21
mattmcgee21 is offline
PostPosted: Mon Dec 16, 2013 5:40 pm    Post subject: Reply with quote
This project is pumping me up man. I have a 67 fastback sitting in the garage waiting for me to start ripping it apart and this is giving the needed motivation. Great job man, keep us posted with the progress!
Page: 1, 2, 3  Next
