Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2400 Location: Moody, AL
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Dec 26, 2013 7:56 am Post subject: |
| Mike Fisher wrote: |
The new ones have black & white wiring diagrams I think. If you buy a used 1971 edition on www.amazon.com it will have the Color wiring diagrams in it. Take it to Kinkos and have the color wiring diagram blown up to 11X17 and laminated for the Electrical!  |
Hoping for used to cut costs anyway. Just couldnt find any last time i looked...i gotta look harder though. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Dec 26, 2013 7:58 am Post subject: |
206-841-7324
[email protected] |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18052 Location: Eugene, OR
Posted: Thu Dec 26, 2013 8:04 am Post subject: |
Try www.books4cars.com in Seattle too. _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Jan 06, 2014 12:31 am Post subject: |
eh oh!
thanks JSMSkater for the help! turns out the distributor we put in had a flipped drive tooth, so it was 180! swapped the wires and fired up. then it woulding go above an idle, so we swapped on a spare throttle position sensor and she revved ! also, before figuring out the spark issue, there was a lack of fuel for some reason. ....turns out i hadnt gotten the pump trigger wire all the way back on so it wasnt turning on. works now!
the smoke was oil spilled from the air cleaner onto the header, no biggy.
the popping however is a biggy! each pop soulds like a hammer on glass, and is accompanied by a puff of black! im suspecting a sticky valve or something along those lines.
next on the list:
FUEL LINES! leaking badely, got all the new stuff, just gotta install. i suspect a tank leak, so gonna have that hot tanked and pressure tested somehow....and got new tank screen and fittings and filter and spare pumps from joe. thanks again!
TUNE IT! this includes: dynamic timing, valve adjust, valve cover gaskets, oil change, run with a full case of AFT for a hour or so, then drain and refill with oil to really wash the gunk out. stuffs been sitting for 12 years or so....then new plugs, and maybe wires, and all new vacuum lines and a full once over with joe again if i dont have a purring engine yet.
THEN:
drive it around the block, and make a new list of to dos!  _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Mon Jan 06, 2014 12:37 am Post subject: |
Popping: sounds like timing way off or two wires crossed. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Posted: Mon Jan 06, 2014 12:40 am Post subject: |
| Tram wrote: |
| Popping: sounds like timing way off or two wires crossed. |
ill do a dynamic time next time i tear into it...what should i set it to and how will i know where its at?
and ill triple check wires, but if they are off, we can all give joe a hard time since he is the one who told me where to put them....as if i didnt know... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Jan 06, 2014 1:15 am Post subject: |
| Stuartzickefoose wrote: |
| Tram wrote: |
and ill triple check wires, but if they are off, we can all give joe a hard time since he is the one who told me where to put them....as if i didnt know... |
Also could be two injector plugs reversed. Are your boots intact- a grey and black boot on each side? _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
Those who can- do.
Posted: Mon Jan 06, 2014 11:58 am Post subject: |
| Tram wrote: |
| Tram wrote: |
Also could be two injector plugs reversed. Are your boots intact- a grey and black boot on each side? |
joe took the right two off and put em back on....i have no idea if any are placed correctly...
i really gotta get that book, im gonna order it now and my text books for class to.  _________________ Stuart Zickefoose
206-841-7324
[email protected] |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36364 Location: Conejo Valley, CA
Posted: Mon Jan 06, 2014 1:25 pm Post subject: |
| Black boots go to the FRONT (as in front of car) pair of injectors, greys to the REAR. |
compdrag Samba Member
Joined: May 06, 2013 Posts: 336 Location: Jacksonville
Posted: Mon Jan 06, 2014 2:26 pm Post subject: |
Progress can't wait to see this thing drive down the road! _________________ 61 Type 1 Patina
61 Type 1 Convertible
68 Type 2 Rivi |
Joeys1969 Samba Member
Posted: Tue Mar 04, 2014 8:26 am Post subject: |
Awesome Stuart! I have been out of the loop so long I didn't even know you got a squareback! They great cars, my grandpa had one as his work car for 15 years.
Good luck to you on this project, what are the overall plans?
Joey _________________ Old VW's and Old Motorcycles. |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2336 Location: Cleveland, OH
Posted: Wed Mar 05, 2014 8:23 pm Post subject: |
Great looking square  _________________ 1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile |
Posted: Wed Mar 19, 2014 7:46 am Post subject: |
ill be getting out to the garage again today to clean around the square...who knows...maybe ill dig in and see if it will start again.....let it run for a bit....
i should be makings some fresh progress soon, i JUST finished school monday, so time should free up a bit....assuming the Girl doesnt mind giving up a bit of her time with me... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Mar 19, 2014 12:14 pm Post subject: |
i should be makings some fresh progress soon, i JUST finished school monday, so time should free up a bit....assuming the Girl doesnt mind giving up a bit of her time with me... |
She called me looking for 3 or 4 more projects for you. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
Those who can- do.
Posted: Wed Mar 19, 2014 1:53 pm Post subject: |
she would... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Jun 30, 2014 10:58 pm Post subject: |
so its been a while....
i moved the square out to monroe for storage...we are selling our house and it had to be out of the garage.... so its sitting again
but ill be back at it someday...promise. if not...i have many offers for buyers....which i would rather not do yet. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Jul 16, 2014 5:07 pm Post subject: |
but ill be back at it someday...promise. if not...i have many offers for buyers....which i would rather not do yet. |
It happens man I had to sell my bus due to moving
Good luck on keeping it!
Posted: Wed Aug 27, 2014 12:40 am Post subject: |
its still in my head i promise i havent lost the motivation yet. rather, the curiosity is building, and im about ready to drag it back home to get to work on it. saving a bit at work here and maybe this winter will drag it back to the garage and tackle the fuel lines and oil seals it needs. first i gotta get the transmission done on my 78 bus.  _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Sep 17, 2014 11:05 pm Post subject: |
visited the square last friday...
really getting motivated to get it on the road soon! got a transmission install to do to my bus, and once thats going well, i really want to drag this thing back onto the road. may even make a trip out to just work on it where it is, rather then transport it back to continue the work.
suggestions on the tank...i suspect rusted holes in it.....thoughts on checking for leaks? i dont , repeat, DONT want to reseal it with a POR kit or anything...never heard anything good about those. just want to clean it out....
really just getting excited overall for VW's....bus transmission, looking for a splitty, and wanna get this running so i can use it! just super pumped up overall! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
