Merlin Samba Member
Joined: August 19, 2004 Posts: 2119 Location: South Africa
Posted: Sat Jan 11, 2014 11:12 pm Post subject: Is this dizzy & cap correct for a NOV '54 bus? |
Morning all,
I've referenced this dizzy on two websites but one of my mates is adamant that it's not correct, so I'm hoping you lot will act as adjudication panel between the two of us... Please?
Bosch VJ4BR8
Thank you.
Nic _________________
| iowegian wrote: |
| People who are allowed to have signature lines annoy me. |
bubblehead Samba Member
Posted: Sun Jan 12, 2014 6:49 am Post subject: |
I believe that's correct for 54. The cap is for an earlier 383 and not compatible. Not sure about the rotor. Also the cast body should be black; looks like a poor quality repaint? Here's the cap you need:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111905207B _________________
| Lind wrote: |
| I think that buses attract weirdos that do weird things in weird places. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80536 Location: Sneaking up behind you
Posted: Sun Jan 12, 2014 7:00 am Post subject: |
The cap is not for s 383, it's also not for a VW. There were Bosch distributors for other makes that used that cap.
It should look like this:
The cap originally was dark brown like the ones in the back. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun Jan 12, 2014 7:04 am Post subject: |
^yeah, I thought that cap looked kinda strange. Flat top like 383 but taller? Any idea what it's for? _________________
| Lind wrote: |
Merlin Samba Member
Posted: Sun Jan 12, 2014 7:18 am Post subject: |
Thanks, chaps.
Glenn, can you confirm or deny the rotor's correctness, please?
I'll have the dizzy body sprayed black once I've found all of the tin and send that lot in together.
Pity...all of the real neat 'early-looking' stuff is for 25 Hps.  _________________
| iowegian wrote: |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71952 Location: Phoenix 602
Merlin Samba Member
Posted: Sun Jan 12, 2014 9:57 am Post subject: |
Thanks, Everett.
My mate is also pushing the point of spring clips, however, when I do a Google Image search for this dizzy, it shows a mix of solid and spring-style clips, which is confusing the matter immensely.
I'm thinking that perhaps it was a different batch or something to that effect?
My rotor is slightly different to the one in your '55 photo, but it is the correct shape. _________________
| iowegian wrote: |
Merlin Samba Member
Posted: Sun Jan 12, 2014 10:12 am Post subject: |
Alright, I'm giving up my hope that this is the correct dizzy. Darn. :/
Thanks.
I'll have to save pennies to bring in the right one...  _________________
| iowegian wrote: |
Glenn  Mr. 010
Posted: Sun Jan 12, 2014 11:04 am Post subject: |
Ev,
I've seen early 383s (no o-ring) with both style of cap clips... along with VJU4BR8 and VJ4BR8. There's no pattern and it seems to be more related to who was the supplier at the time.
Left side is NOS correct.
A VJ4BR8 used a non-resistor rotor which the VJR4BR8 used a resistor rotor. Not sure if it matters. _________________ Glenn
Member #1009
#BlueSquare
Merlin Samba Member
Posted: Sun Jan 12, 2014 12:20 pm Post subject: |
Thanks for that, Glenn.
Excuse my (seemingly severe) dizzy ignorance here, but mine is missing its o-ring, but is a VJ4BR8...
Wait for the stupid question...
Is it possibly correct then or definitely incorrect?
My rotor is a little different to the one in the photo (LHS) and looks to use the points shown on the RHS. What a wierd mix this appears to be. _________________
| iowegian wrote: |
Glenn  Mr. 010
Posted: Sun Jan 12, 2014 12:57 pm Post subject: |
| Merlin wrote: |
Excuse my (seemingly severe) dizzy ignorance here, but mine is missing its o-ring, but is a VJ4BR8... |
The groove is there, just the rubber must of cracked and fallen off.
Member #1009
#BlueSquare
Merlin Samba Member
Posted: Sun Jan 12, 2014 1:15 pm Post subject: |
I was rather unclear with my last message. My apologies.
Based on your input about "early 383s with no o-rings"...
My understanding is that my cap, points and rotor are wrong, but that the dizzy (with solid clips) may be correct? _________________
| iowegian wrote: |
Glenn  Mr. 010
Posted: Sun Jan 12, 2014 1:26 pm Post subject: |
The one is my picture would be correct.
Don't get crazy over "correct" tuneup parts.
01001 points
02170 condenser
03019 cap
04008 rotor _________________ Glenn
Member #1009
#BlueSquare
Glenn  Mr. 010
Posted: Sun Jan 12, 2014 1:36 pm Post subject: |
The wire and solid cap clips were both used in the middle 50's.
Here's a early 383, no o-ring, with solid clips.
And a later one with the o-ring and wire clips.
Member #1009
#BlueSquare
Merlin Samba Member
Posted: Sun Jan 12, 2014 2:09 pm Post subject: |
Thanks Glenn.  _________________
| iowegian wrote: |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2395 Location: Graz, Austria, Europe
Merlin Samba Member
Posted: Mon Jan 13, 2014 12:23 am Post subject: |
| djfordmanjack wrote: |
| I have several VJ4 and they are all solid clips. |
Thanks djfordmanjack.  _________________
| iowegian wrote: |
D-train Samba Member
Posted: Mon Jan 13, 2014 2:11 am Post subject: |
should it look like this one?
wire clips, no vacuum advance
_________________ shiny paint doesnt make it worth any more |
