Opinion on painting engine parts
SweetCars
SweetCars is offline
PostPosted: Sun Jan 26, 2014 9:05 pm    Post subject: Opinion on painting engine parts Reply with quote
I am rebuilding my engine and painted the intake manifold, throttle body and alternator stand in black/brownich paint. It is a Rustoleum paint, i suposed to be BLACK but got a kind of brown color.
I weanted to know your opinion about the painted parts and the original aluminium color part.
Here are some pictures.
I got 2 alternator stands, one which is brand new and the old one wich i painted.
vwracerdave
vwracerdave is offline
PostPosted: Sun Jan 26, 2014 9:16 pm    Post subject: Reply with quote
Be sure the surface the Alt straps to is unpainted so is has a good strong electrical ground.
baja2000
baja2000 is offline
PostPosted: Sun Jan 26, 2014 9:18 pm    Post subject: Reply with quote
nice
SweetCars
PostPosted: Sun Jan 26, 2014 9:25 pm    Post subject: Reply with quote
GOOD POINT! Didnt think about that. as well as the surface a bolt on the alt stand to case.
slalombuggy
slalombuggy is offline
PostPosted: Sun Jan 26, 2014 10:34 pm    Post subject: Reply with quote
Make sure the saddle of the stand is unpainted as well as the alternator body where it sits in the saddle. I've always painted my straps but left these areas clean.
brad
Danwvw
Danwvw is offline
PostPosted: Sun Jan 26, 2014 10:56 pm    Post subject: Reply with quote
There is certainly no shame in a nice un-painted VW engine as far as the Magnesium goes! But the Iron does need to be painted so it won't rust. Cylinders and Pushrod tubes, Flywheel and clutch too. Gray does not look to bad on the alternator. Clear coat is what I would use on the Magnesium if anything at all.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
slalombuggy
PostPosted: Mon Jan 27, 2014 7:03 am    Post subject: Reply with quote
I paint all my steel parts to stop rust and I've painted most of the bolt on aluminum bits on my Bonneville engine to stop corrosion. That $#!^ is corrosive as hell. I've always painted mag cases as I think they look like hell even when clean. Never seen any difference in heat painted or raw.
brad
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jan 27, 2014 7:21 am    Post subject: Reply with quote
Danwvw wrote:
Pushrod tubes,
Stainless steel push rod tubes don't rust.
These have 25,000 miles on them.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Danwvw
Danwvw is offline
PostPosted: Mon Jan 27, 2014 11:50 am    Post subject: Reply with quote
Yes if you spring for the extra $ for the stainless push rod tubes, don't paint them as they would handle heat exchange better un-painted. It's hard to say which is going to be hotter though: The air off the heads or the oil off the heads in the push rod tubes. (Probably the Oil) at least when the outside air temp is cool and the engine is hot.
