Kadron Setup problems
Page: Previous  1, 2, 3, 4, 5, 6
thewreckingsoul
thewreckingsoul is offline
PostPosted: Mon Jan 27, 2014 12:38 pm    Post subject: Reply with quote
Subscribing!
Having similar issue. Passenger side carb makes bubbling sound when engine is shut off. While idling, I can screw the pass side idle mix screw all the way in and no change in idle. If i unscrew the 2 1/2 - 3 turns, exhaust pops. Driver side is tunable. Reacts almost instantly to idle adj screw.
32mm venturis
rebuilt throttle bodies (Jeff Lain)
Jetted by Jeff Lain
Ad
In action
In action again
andk5591
andk5591 is offline
PostPosted: Mon Jan 27, 2014 2:08 pm    Post subject: Reply with quote
Have you read through this completely? Mix screw not making difference is usually bad synch.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
thewreckingsoul
PostPosted: Mon Jan 27, 2014 3:38 pm    Post subject: Reply with quote
Yes I have. Lots of good info that I will attempt. I'm subscribing to see the outcome for the OP.
thanks!
Ad
In action
In action again
Page 6 of 6
