j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Wed May 25, 2011 7:48 pm Post subject: |
K58 wrote: |
Thanks Guy's
that's what I thought
Any other items I should address with the dash out? |
Have you tried a coat hanger?
The squirter line feeds from the driver side.. Should not be at all difficult to pull it close to top and then grab with some hemostats (sp?)
I don't think it can fall down very far.
I'd work that wire a good amount of time before I'd resort to pulling the dash.
Some light directed from below (glove box open) may help you see a little down inside, too. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Wed May 25, 2011 8:30 pm Post subject: |
j_dirge wrote: |
K58 wrote: |
Thanks Guy's
Some light directed from below (glove box open) may help you see a little down inside, too. |
thank you X10
I tried for awhile from the outside with a hanger but your idea of the hemostats (correct sp) is excellent
I actually have a pair  |
JeffRobenolt  Samba Member
Joined: February 25, 2007 Posts: 1531 Location: Wisconsin
Posted: Thu May 26, 2011 7:31 am Post subject: |
I just got done putting my van together after painting and the hardest part was fishing out the washer lines. I used a hemo on the passenger side.
With the gauge cluster out I could snake my arm in for the drivers side.
Jeff _________________ For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com |
K58 Samba Member
Posted: Fri May 27, 2011 1:26 pm Post subject: |
I got the new nozzles on but only after unbolting the wiper motor on the passenger side, moving it out of the way enough to have access to the small space just under the windshield. After positioning the hose and using a flashlight I was able to fish it out with the Hemostats. Great suggestion!!
A tip for anyone doing this mod is to get a Hemostat locked onto the washer tube while removing the nozzle. It will make your life a lot easier.
Thanks to everyone's suggestions! |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
K58 Samba Member
Posted: Sat Jul 21, 2012 10:49 pm Post subject: |
kuleinc wrote: |
did we decide which nozzles are best? The 50 euro ones? The Porsche ones from pelican parts? I can't stand the stupid OE ones... |
All I can tell you is that the Porsche nozzles I got from Pelican work great. It took a bit of trial and error to get them positioned just right but they have worked flawlessly since. 1000X better than OE!
http://www.pelicanparts.com/cgi-bin/smart/more_inf...1976-85%29 _________________ Westy HID Projector Retrofit |
insyncro Banned
Posted: Sat Jul 21, 2012 10:50 pm Post subject: |
The triple nozzle units are plug and play.
I have had them for years and love them.
The only limiting factor seems to be price for some.
Since owning my sets I have heated them and the lines.
A really treat to drive with in winter weather. |
designer Samba Member
Joined: November 05, 2009 Posts: 523 Location: Idaho-but just the tip
Posted: Fri Feb 21, 2014 10:19 pm Post subject: |
[quote=
alistair[/quote]
I need a new dichtung. My dichtung leaks. The Fullrohr just isn't as tight going into the Dichtung as it used to be. It's been stretched out over time. I guess with 27 years of useage it just gets that way. Maybe my Fullrohr has just gotten smaller?
Just replaced my pumpe fur Scheibenwisch Und Washanlage and man does that ever make a difference. Is there a way to adjust the Dusentralger mit Spitzduse's? I'm talking the stock Dusentraglers, though.
My new Pumpe shoots the fluid up to my sunroof. in 30degree weather on the highway.
I've thought about changing to a two prong approach, but i'm getting good distance, it's just the accuracy that needs attention.  |
Posted: Fri Feb 21, 2014 10:21 pm Post subject: |
[quote=
alistair[/quote]
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Fri Feb 21, 2014 10:36 pm Post subject: |
Designer,
At least you don't have a bent Winkelstuck, right? |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12318 Location: Santa Cruz, CA
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8413 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Feb 22, 2014 8:13 am Post subject: |
The leak at the dichtung is the improved "FULL" indicator for the tank.
Stop filling when your shoes get wet...
The washer nozzles themselves are adjustable. There is a small metal ball which
rotates in the nozzle - just use a pushpin or needle to aim it however you like. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Sat Feb 22, 2014 10:15 am Post subject: |
I'm not sure if it's been mentioned in this thread, but I recently noticed that LR Discovery rear wiper squirters are dual outlet and stand off a bit from the body. Might be a decent option if a part number and source can be identified. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
kalispell365 Samba Member
Posted: Sat Feb 22, 2014 2:39 pm Post subject: |
K58 wrote: |
kuleinc wrote: |
http://www.pelicanparts.com/cgi-bin/smart/more_inf...1976-85%29 |
I think sometimes people think spending a ton on a simple item somehow gets them a "superior" product
These pelican nozzles are also made by SWF,and look great,work even better!
These are the ones to get,IMHO. |
madspaniard Samba Member
Posted: Sat Feb 22, 2014 4:47 pm Post subject: |
kalispell365 wrote: |
I'll bite since I'm the only one that has admitted here to buying the ones from Germany. To set the record straight, the 50€ ones are three-way nozzles. The German two-way nozzles that I bought are 17€. The Pelican are two-way nozzles. At the time, I bought other items not available in NorthAmerica like headlight guards so I didn't specifically pay for shipping of the nozzles. How much are the Pekican with shipping? Not really that big of a difference. I actually like the looks of the German better but that is just my taste. I would expect both to work about the same. No rocket science here.
If you are not purchasing other stuff from the German website then I don't think it makes sense to buy the German ones, go with the Pelican (unless you don't like them) _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Sat Feb 22, 2014 6:19 pm Post subject: |
I got these:
http://t3technique.com/accessories/dual-nozzle-windshield-squirters/
I almost lost the passenger side line... but gladly i didn't...
they're a bit of a chore to aim, but i finally got them dialed in. _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
K58 Samba Member
Posted: Sun Feb 23, 2014 8:55 am Post subject: |
Revisiting this post after noticing that my Jeep has a "spray" nozzle that works superior to anything I've seen. What about a spray type nozzle < $50 for a Vanagon? Ideas? _________________ Westy HID Projector Retrofit |
